    Help figuring out what portion of this code is erroring out?
    10 Posts 2 Posters 3.1k Views 2 Watching
      stalker401
      I can’t figure out what portion of the MMM-awesome-alexa code is causing my MM error:
        			"module": "MMM-awesome-alexa",
        			"position": "bottom_bar",
        			"config": {
          				"wakeWord": "Alexa",
          				"clientId": amzn1.application-oa2-client.54a08c41875f4xxxxxxxxxxxxxxx,
          				"clientSecret": 8ce8425cb89e02a7302a60d27d10b51d2f137d8fxxxxxxxxxxxxxxxxxxxxxxxxxx,
          				"deviceId": MagicMirror_1
      I put it in as a comment for now, so the MM will work but I’d like to try the magic mirror with alexa…
        sdetweil @stalker401
        @stalker401 for the future, all u need to do is add
        disabled: true,
        To the module definition
          stalker401 @sdetweil
          Thanks. Any idea why it might be causing an error when i start mm though?
            @stalker401 the text to the right of config words need to be quoted
            clientID, clientSecret and deviceId
              Only thing on the right side that doesn’t need to be quoted is true/false, or a number
                Also, typically the words used to the left don’t need to be quoted
                module: "somestring",
                config:{
                   Something: true,
                   something_Else: "some string"
                All words on the left are case sensitive
                  stalker401
                  @stalker401 said in Help figuring out what portion of this code is erroring out?:
                  MMM-awesome-alexa
                  Thanks everyone ill try it after work today
                    stalker401
                    So I went in this morning and made the corrections, but instead of the typical error, when I started MagicMirror it was black screen that had my mouse cursor on it. The code i used is:
                      			"config": {
                        				"clientId": "amzn1.application-oa2-client.54a08c41875f4xxxxxxxxxxxxxxx",
                        				"clientSecret": "8ce8425cb89e02a7302a60d27d10b51d2f137d8fxxxxxxxxxxxxxxxxxxxxxxxxxx",
                        				"deviceId": "MagicMirror_1"
                      @stalker401 ok, open the developers window, ctrl-shift-i, select the console tab and scroll up to see any errors. Usually red text
                        stalker401
                        Thanks, I’ll look at it tonight.
