    MMM-Awesome-Alexa & MMM-Scoreboard
    6 Posts 3 Posters 3.5k Views 3 Watching
      stalker401
      I finally got MMM-Awesome-Alexa to work… FYI anyone that needs help should use the following link: Best MMM-Awesome-Alexa Walkthrough
      However I was using MMM-Scoreboard to go with it. Now since i got the alexa installed MMM-scoreboard now lists the recent scores horizontally across the screen instead of vertical as it did before. It basically messes up the formatting of the display. Any idea why this happens, and how to fix it? or are just some of the mods not compatible together?
      B D 2 Replies Last reply Reply Quote 0
        berne @stalker401
        @stalker401 sorry for op, bur i have problem install alexa, i got get to the last part, to get this:
        https://imgur.com/a/6DbYlKA
        i think i have done it right:
        Enter your Product ID from Alexa Voice Service (AVS): berne88_MM_Alexa
        (is the namn i will put in you self)?
        i am using this link: https://magic-mirror-avs.github.io/Alexa-Web-Helper/authresponse
        on the return URL
        have i done anything wrong?
          stalker401
          I’ll be honest, I haven’t gotten to test it yet, but it should be the name you made up as you were making your Amazon Dev AVS. Like I used MagicMirror_2.
            berne @stalker401
            @stalker401 400 Bad Request
            The redirect URI you provided has not been whitelisted for your application. Please add your redirect URI in the ‘Allowed Return URLs’ section under ‘Web Settings’ for your Security Profile on Amazon Developer Portal. is what i get, but i am using this link: https://magic-mirror-avs.github.io/Alexa-Web-Helper/authresponse i boothe of the links, did u use the same?
              stalker401
              Just curious if anyone has had a chance to look into this… I’m looking at other mods to work around it, but they just don’t seem as good as this one (you know that moment when you find something perfect).
                dyard @stalker401
                @stalker401 did you ever get this resolved? Im having the same issue my others mods get all messed up
