    Magic Mirror Black Screen after "pm2 start mm"
    10 Posts 3 Posters 1.9k Views 3 Watching
      Parity
      Hey everyone! First time posting, so please be gentle…
      Have had my MM and modules running for 3+ months at this point - no issues. I had this Pi running in a case for this entire time, however, decided to remove it and put the case to use for another Pi while I have another on order (the other needed the cooling more than this one).
      After removing the case and starting back up - no issues. Raspberry Pi loaded to desktop no issues. The magicmirror service is set to start after x amount of seconds (forgot off-hand) but first thing I noticed is once the module loaded, all I get is a black screen. Returned to desktop using “pm2 stop mm”, which works successfully. If I run “pm2 start mm”, the service begins to run, but enters a black screen again. This was working 10 mins ago before I shut down the Pi for case removal.
      I’ve ran the following commands, thinking updating my Pi would help (it’s been a while) but with no avail:
      -sudo apt-get update
      -sudo apt upgrade
      -sudo apt install
      Raspian Stretch 9.9
      Please let me know what information I can provide to help troubleshoot! Any help is appreciated!
        sdetweil @Parity
        @Parity run
        pm2 logs
          Parity @sdetweil
          pi@raspberrypi:~ $ pm2 logs
          /home/pi/.pm2/pm2.log last 15 lines:
          PM2        | 2019-08-24T14:27:57: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
          PM2        | 2019-08-24T14:27:57: PM2 log: App [mm:0] starting in -fork mode-
          PM2        | 2019-08-24T14:27:57: PM2 log: App [mm:0] online
          PM2        | 2019-08-24T14:28:06: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
          PM2        | 2019-08-24T14:28:06: PM2 log: App [mm:0] starting in -fork mode-
          PM2        | 2019-08-24T14:28:06: PM2 log: App [mm:0] online
          PM2        | 2019-08-24T14:28:15: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
          PM2        | 2019-08-24T14:28:15: PM2 log: App [mm:0] starting in -fork mode-
          PM2        | 2019-08-24T14:28:15: PM2 log: App [mm:0] online
          PM2        | 2019-08-24T14:28:56: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
          PM2        | 2019-08-24T14:28:56: PM2 log: App [mm:0] starting in -fork mode-
          PM2        | 2019-08-24T14:28:56: PM2 log: App [mm:0] online
          PM2        | 2019-08-24T14:29:34: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
          PM2        | 2019-08-24T14:29:34: PM2 log: App [mm:0] starting in -fork mode-
          PM2        | 2019-08-24T14:29:34: PM2 log: App [mm:0] online
          0|mm       | Expected directory: electron-v3.1-linux-arm-glibc
          0|mm       | Found: [electron-v2.0-linux-arm-glibc, node-v64-linux-arm-glibc]
          0|mm       | This problem can often be fixed by running "npm rebuild" on the current system
          0|mm       | Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.1-linux-arm-glibc/grpc_node.node'
          0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
          0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:63:3)
          0|mm       |     at Module._compile (internal/modules/cjs/loader.js:711:30)
          0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
          0|mm       |     at Module.load (internal/modules/cjs/loader.js:620:32)
          0|mm       |     at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
          0|mm       |     at Function.Module._load (internal/modules/cjs/loader.js:551:3)
          0|mm       |     at Module.require (internal/modules/cjs/loader.js:658:17)
          0|mm       |     at require (internal/modules/cjs/helpers.js:20:18)
          0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12) code: 'MODULE_NOT_FOUND' }
          0|mm       | ATTENTION: default value of option force_s3tc_enable overridden by environment.
          0|mm       | Module helper loaded: calendar
          0|mm       | No helper found for module: compliments.
          0|mm       | Whoops! There was an uncaught exception...
          0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          0|mm       | Launching application.
          0|mm       | Shutting down server...
          0|mm       | Stopping module helper: updatenotification
          0|mm       | Stopping module helper: calendar
          0|mm       |
          0|mm       | > magicmirror@2.8.0 start /home/pi/MagicMirror
          0|mm       | > sh run-start.sh
          0|mm       |
          PM2      | Stopping app:mm id:0
          PM2      | App [mm:0] exited with code [0] via signal [SIGINT]
          PM2      | pid=4352 msg=process killed
          PM2      | App [mm:0] starting in -fork mode-
          PM2      | App [mm:0] online
          0|mm     | Starting MagicMirror: v2.8.0
          0|mm     | Loading config ...
          0|mm     | Loading module helpers ...
          0|mm     | No helper found for module: alert.
          0|mm     | Initializing new module helper ...
          0|mm     | Module helper loaded: updatenotification
          0|mm     | No helper found for module: clock.
          0|mm     | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
          0|mm     | App threw an error during load
          0|mm     | Error: Failed to load gRPC binary module because it was not installed for the current system
          0|mm     | { Error: Failed to load gRPC binary module because it was not installed for the current system
          PM2      | pid=4410 msg=failed to kill - retrying in 100ms
          PM2      | pid=4410 msg=process killed
          One more piece of information:
          I took a backup of my config.js file (/home/pi/MagicMirror/config) and then removed it. I then took the sample “config.sample.js” and used that as my config.js – this worked. Loaded fine. Then I removed this same config, made my backup config my actual config.js, and that worked ONE time. After I quit and then tried reloading, I got a black screen again. Is this some sort of RAM issue?
            Parity
            I apologize for the above log.
            Below are the Pm2 logs for starting both the “config.sample.js” (which works) and the “config.js” (which does not work)
            SAMPLE CONFIG – WORKS
            0|mm     | No helper found for module: currentweather.
            0|mm     | No helper found for module: weatherforecast.
            0|mm     | Module helper loaded: newsfeed
            0|mm     | All module helpers loaded.
            0|mm     | Starting server on port 8080 ...
            0|mm     | Server started ...
            0|mm     | Connecting socket for: updatenotification
            0|mm     | Connecting socket for: calendar
            0|mm     | Starting node helper for: calendar
            0|mm     | Connecting socket for: newsfeed
            0|mm     | Starting module: newsfeed
            0|mm     | Sockets connected & modules started ...
            0|mm     | Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
            0|mm     | Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
            0|mm     | Stopping module helper: newsfeed
            PM2      | pid=5011 msg=failed to kill - retrying in 100ms
            PM2      | pid=5011 msg=process killed
            NORMAL CONFIG.JS (does not work)
            PM2      | pid=5206 msg=failed to kill - retrying in 100ms
            PM2      | pid=5206 msg=process killed
            Thanks!
              Parity
              So I’m assuming from my own readings, it would appear that the Pi is expecting Electron-v3.1-linux-arm-glibc but that is not found. I tried rebuilding my /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules directory but ended up accidentally deleting it.
              So now the same applies, it’s expecting Electron-v3.1-linux-arm-glibc, however it finds “[node-v64-linux-arm-glibc]”. I tried npm rebuild, but no avail. I’m assuming all I need to do is rebuild that node_modules directory and get it to Electron-v3.1-linx-arm-glibc?
              Here is the below “pm2 logs” with the latest error:
              PM2        | 2019-08-24T15:11:15: PM2 log: pid=11133 msg=failed to kill - retrying in 100ms
              PM2        | 2019-08-24T15:11:15: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
              PM2        | 2019-08-24T15:11:15: PM2 log: pid=11133 msg=process killed
              PM2        | 2019-08-24T15:12:36: PM2 log: App [mm:0] starting in -fork mode-
              PM2        | 2019-08-24T15:12:36: PM2 log: App [mm:0] online
              PM2        | 2019-08-24T15:16:18: PM2 log: Stopping app:mm id:0
              PM2        | 2019-08-24T15:16:18: PM2 log: pid=11236 msg=failed to kill - retrying in 100ms
              PM2        | 2019-08-24T15:16:19: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
              PM2        | 2019-08-24T15:16:19: PM2 log: pid=11236 msg=process killed
              PM2        | 2019-08-24T15:16:27: PM2 log: App [mm:0] starting in -fork mode-
              PM2        | 2019-08-24T15:16:27: PM2 log: App [mm:0] online
              PM2        | 2019-08-24T15:23:43: PM2 log: Stopping app:mm id:0
              PM2        | 2019-08-24T15:23:43: PM2 log: pid=11476 msg=failed to kill - retrying in 100ms
              PM2        | 2019-08-24T15:23:44: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
              PM2        | 2019-08-24T15:23:44: PM2 log: pid=11476 msg=process killed
              0|mm       | Found: [node-v64-linux-arm-glibc]
              PM2      | pid=11675 msg=failed to kill - retrying in 100ms
              PM2      | pid=11675 msg=process killed
              Thanks again!
                See the instructions in the MMM-AssistantMk2 module readme.md on how to fix the gprc issue
                  Parity @sdetweil
                  I’m assuming this is what you’re referring to?
                  "grpc Electron-rebuild or Raspbian Buster issues. (on Raspbian Buster) Downgrade your gcc to gcc7. (default of Buster would be gcc8)
                  sudo apt-get install gcc-7
                  sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-7 10
                  sudo update-alternatives --config gcc
                  Then select gcc-7
                  Then try electron-rebuild again."
                  Just for confirmation - would this rebuild my node_modules directory? The most recent log I posted shows I don’t even have any electron version. I will attempt this later tonight.
                  As a side question - if I delete my Mmm-assistantmk2 module and rebuild it from scratch, would that affect the configurations of my mirror at all? Correct me if I’m wrong, but couldn’t I just reinstall this module since the config.js just references this module?
                    sdetweil @Parity
                    @Parity no, but u will end up at the same recovery steps
                      Parity @sdetweil
                      @sdetweil okay thanks. So just try what I posted above and it will automatically rebuild electron in the process? If not, just do Mmm-assistantmk2 from scratch?
                        smassy
                        Had the same problem, change directory to MagicMirror and execute npm start. Hope it help
