    Blank mm after update
    48 Posts 4 Posters 26.0k Views 4 Watching
    • evroomE
      evroom
      @sdetweil said in Blank mm after update:
      the module doesn’t work, but doesn’t kill MagicMirror anymore…
      Correct.
      I have a few questions.
      In the original module there is no package.json file, where in the cloned one there is.
      So, when using the original module, you should NOT use npm install, right ?
      First of all it will no do anything useful, but it WILL delete your /home/pi/MagicMirror/modules/node_modules/node_helperdirectory and its index.js file.
      When using the cloned module, you should run npm installin order to install the dependencies mentioned in it, right ?
      No harm is done to the node_helper dir.
      Or is it all BS I am telling here (and made the wrong observations) ??
      MagicMirror version: 2.37.0
      S 2 Replies Last reply
        sdetweil @evroom
        @evroom i cloned and got no package.json
        i cloned this
        https://github.com/paphko/mmm-weatherchart
          sdetweil @evroom
          @evroom yes, to all your observations…
          • evroomE
            evroom
            When I use
            $ git clone https://github.com/szech/mmm-weatherchart.git
            then it works.
            The README.md from szech point to papkto.
            When corrected and doing npm install in the mmm-weatherchart directory, it works
              sdetweil @evroom
              @evroom yes, that module has it…
              • K
                kvicksson @sdetweil
                @sdetweil Thanks! This worked for me as it doesn’t kill it anymore. Hope for a quick fix. Can I follow the process somewhere?
                S evroomE 3 Replies Last reply
                • evroomE
                  evroom
                  Hi @kvicksson ,
                  To me it seems there are 3 problems here.
                  You could have a look what the pm2 log says:
                  $ pm2 logs --lines 100
                  You will either have:
                  Error: Cannot find module 'del'
                  or:
                  Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/mmm-weatherchart/cache/map-1567097174409.
                  or something completely different.
                  The 3 problems and potential solutions:
                  You’re config.js entries:
                  updateInterval: '3600000',
                  hideBorder: 'true'
                  should be:
                  updateInterval: 3600000,
                  hideBorder: true
                  even if the module could potentially handle it.
                  If your mmm-weatherchart instal has this file present:
                  /home/pi/MagicMirror/modules/mmm-weatherchart/package.json
                  then you should run:
                  $ cd /home/pi/MagicMirror/modules/mmm-weatherchart/
                  $ npm install
                  If your mmm-weatherchart instal has this file NOT present:
                  then you should NOT run npm instal, has it will cause havoc to you MagicMirror install.
                  I would do this in this situation:
                  $ mv mmm-weatherchart mmm-weatherchart.saved
                  $ npm install
                  $ pm2 restart pm2
                  When it works:
                  $ rm -rf mmm-weatherchart.saved
                  Good luck !!
                  PS @sdetweil : please comment if I am wrong or made mistakes somewhere & thanks for your input.
                  S K 2 Replies Last reply
                    sdetweil @kvicksson
                    @kvicksson said in Blank mm after update:
                    this is all volunteer… you could post an issue to the module owners github repo… maybe he or someone else will respond… I am like you, just another user…
                    • evroomE
                      evroom @kvicksson
                      I should type faster :-)
                        sdetweil @evroom
                        @evroom think u have good instructions…
                        ps, 2 of my three systems do not have pi as the user, so the path is wrong, and in the module defaults too
                        • evroomE
                          evroom
                          Yes, I assumed user pi and the install under the user pi home directory.
                          Will try to remember that in the future.
                          Tilde for the home directory should work on all platforms, is my understanding.
                          ~/MagicMirror
                          My keyboard is lacking a tilde and I always forget the right keystrokes.
                          So /home/pi is faster. :-)
                          • K
                            kvicksson @evroom
                            @evroom I sat right now and installed a new calendar module and suddenly the mmm-weatherchart started working… :thinking_face:
                            Did the $ pm2 logs --lines 100 and got a lot of errors, but I guess because everything’s working fine so don’t have to bother right now?!
                            • K
                              kvicksson
                              And of course it didn’t work now when I tried to switch back to default calendar module and then back to the other calendar module…
                              • evroomE
                                evroom
                                As long as the errors are no fatal errors that do not prevent the MagicMirror from starting or prevent a certain module from working right, you might chose to ignore them.
                                But the problem is, that when you add something new or update something existing, it becomes more and more difficult to debug and/or correct in case of problems.
                                When you do this:
                                $ pm2 flush
                                $ pm2 restart mm
                                what is the first error you see ?
                                Perhaps you post the first 50 to 100 lines of the log.
                                But only if you want to spend some time on it, when not that’s fine too.
                                K 1 Reply Last reply
                                • K
                                  kvicksson @evroom
                                  @evroom actually no errors like I got before…
                                  PM2        | 2019-08-29T21:46:00: PM2 log: pid=1331 msg=failed to kill - retrying in 100ms
                                  PM2        | 2019-08-29T21:46:00: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                  PM2        | 2019-08-29T21:46:00: PM2 log: pid=1331 msg=process killed
                                  PM2        | 2019-08-29T21:46:00: PM2 log: App [mm:0] starting in -fork mode-
                                  PM2        | 2019-08-29T21:46:00: PM2 log: App [mm:0] online
                                  0|mm       | Shutting down server...
                                  0|mm       | Stopping module helper: updatenotification
                                  0|mm       | Stopping module helper: mmm-systemtemperature
                                  0|mm       |
                                  0|mm       | > magicmirror@2.8.0 start /home/pi/MagicMirror
                                  0|mm       | > sh run-start.sh
                                  0|mm       |
                                  0|mm       | Starting MagicMirror: v2.8.0
                                  0|mm       | Loading config ...
                                  0|mm       | Loading module helpers ...
                                  0|mm       | No helper found for module: alert.
                                  0|mm       | Initializing new module helper ...
                                  0|mm       | Module helper loaded: updatenotification
                                  0|mm       | Module helper loaded: mmm-systemtemperature
                                  0|mm       | No helper found for module: clock.
                                  0|mm       | Module helper loaded: calendar
                                  0|mm       | Module helper loaded: MMM-YrThen
                                  0|mm       | Module helper loaded: mmm-weatherchart
                                  0|mm       | Module helper loaded: newsfeed
                                  0|mm       | All module helpers loaded.
                                  0|mm       | Starting server on port 8080 ...
                                  0|mm       | Server started ...
                                  0|mm       | Connecting socket for: updatenotification
                                  0|mm       | Connecting socket for: mmm-systemtemperature
                                  0|mm       | Starting node helper: mmm-systemtemperature
                                  0|mm       | Connecting socket for: calendar
                                  0|mm       | Starting node helper for: calendar
                                  0|mm       | Connecting socket for: MMM-YrThen
                                  0|mm       | MMM-YrThen 8/29/2019 9:46:08 PM: Starting helper for MMM-YrThen
                                  0|mm       | Connecting socket for: mmm-weatherchart
                                  0|mm       | Starting node helper: mmm-weatherchart
                                  0|mm       | Connecting socket for: newsfeed
                                  0|mm       | Starting module: newsfeed
                                  0|mm       | Sockets connected & modules started ...
                                  0|mm       | Launching application.
                                  0|mm       | /home/pi/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /home/pi/MagicMirror/node_modules/electron/dist/electron)
                                  0|mm       | (node:2465) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                                  0|mm       | /proc/self/exe: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /proc/self/exe)
                                  0|mm       | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                                  I really appreciate you want to look into my errors, I’m not too good on this :)
                                  evroomE 2 Replies Last reply
                                  • evroomE
                                    evroom
                                    @kvicksson
                                    Doesn’t look too bad.
                                    Probably you saw the previous errors in your log output, that it is why flushing (pm2 flush) sometimes cannot hurt.
                                    In order to know a bit about your environment, can you post the output of the following commands ?
                                    I am assuming you are using a Raspberry Pi
                                    $ cat /proc/device-tree/model
                                    $ lsb_release -a
                                    $ npm --version
                                    $ node --version
                                    $ pm2 --version
                                    $ cat /boot/config.txt | egrep -v '^$|^#|^\['
                                    I also would suggest to see if npm shows any errors:
                                    $ cd ~/MagicMirror
                                    $ npm audit
                                    In my case a
                                    $ npm audit fix
                                    solved the dependency issues it found.
                                    Perhaps others have different ideas, but as a hobbyist, I would take these steps first myself.
                                    • lavolp3L
                                      lavolp3 Module Developer
                                      @evroom said in Blank mm after update:
                                      In my case a
                                      $ npm audit fix
                                      The npm audit warnings do not create any problems in running the mirror as far as I know. They also do not show up in the pm2 logs.
                                      I would even be very careful as an inexperienced user to do that. “Fixing” these npm warnings on the root MM install could break the whole mirror (not the mirror itself of course :-)). Especially if you mess with the electron/chromium dependencies.
                                      How to troubleshoot modules
                                      MMM-soccer v2, MMM-AVStock
                                      evroomE 1 Reply Last reply
                                      • K
                                        kvicksson @evroom
                                        @evroom got an error on the egrep command:
                                        pi@raspberrypi:~ $ cat /proc/device-tree/model
                                        Raspberry Pi 3 Model B Rev 1.2pi@raspberrypi:~ $ lsb_release -a
                                        No LSB modules are available.
                                        Distributor ID: Raspbian
                                        Description:    Raspbian GNU/Linux 8.0 (jessie)
                                        Release:        8.0
                                        Codename:       jessie
                                        pi@raspberrypi:~ $ npm --version
                                        5.6.0
                                        pi@raspberrypi:~ $ node --version
                                        v9.11.2
                                        pi@raspberrypi:~ $ pm2 --version
                                        3.5.1
                                        pi@raspberrypi:~ $ cat /boot/config.txt | egrep -v '^$|^#|^['
                                        grep: Invalid regular expression
                                        • evroomE
                                          evroom
                                          Forgot to escape the [, try this:
                                          EDIT: Did not forget to escape it, it is this shitty forum that removes it.
                                          There needs to a backslash \ before the last [
                                          • evroomE
                                            evroom @lavolp3
                                            @lavolp3 said in Blank mm after update:
                                            The npm audit itself suggests to fix it using the fix option.
                                            I personally never had any issues with this command, but perhaps I was lucky till now.
                                            Sometimes it cannot resolve an issue, but it never broke anything.
                                            But, if it appears to be that dangerous, then indeed it is perhaps to refrain from it when not really necessary.
                                            • 2 / 3
