    Blank mm after update
    48 Posts 4 Posters 24.2k Views 4 Watching
      warning, warning… copy and save
      MagicMirror/modules/node_modules/node_helper (folder, which contains index.js)
      then
      cd ~/MagicMirror/modules/mmm-weatherchart
      npm install del
      check for a missing
      MagicMirror/modules/node_modules/node_helper folder
      and if so, copy it back
      i opened an issue with mmm-weatherchart
      • evroomE Offline
        evroom
        @sdetweil said in Blank mm after update:
        seems odd that there would be two invocations of these modules…
        I have only one mmm-weatherchart module present.
        When disabled everything is fine.
        However, I forgot to remove the single quotes, as I just copy/pasted the config from the thread.
        Corrected it, but now I get even stronger things.
        0|mm  | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'del'
        I do not have any string with ‘del’ in my config :worried_face:
        MagicMirror version: 2.37.0
          sdetweil @evroom
          @evroom see my prior most about the missing module
          • evroomE Offline
            evroom
            I was typing while you answered.
            Will have a look at it and try it out.
            • evroomE Offline
              evroom
              The module is running now, but I get this error:
              0|mm  | Downloading weather map with signal: FETCH_MAP From URL: www.yr.no/place/Germany/Bavaria/Nuremberg/meteogram.png
              0|mm  | Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/mmm-weatherchart/cache/map-1567097174409.png'
              pi@raspberrypi:~/MagicMirror/modules/mmm-weatherchart $ ll /home/pi/MagicMirror/modules/mmm-weatherchart/cache
              total 12
              4 drwxr-xr-x 2 pi pi 4096 Aug 29 18:49 .
              4 drwxr-xr-x 4 pi pi 4096 Aug 29 18:44 ..
              4 -rw-r--r-- 1 pi pi    6 Aug 29 18:44 .gitignore
              Then I read somewhere there is a clone of this module that is more recent, so I tried that:
              https://github.com/szech/mmm-weatherchart
              Same result: module runs but no file in the cache dir.
              When opening the URL in the browser, it does show the picture that I do not see on my screen.
              Oh boy/girl, thought it was a simple syntax thingy in config.js …
                the module doesn’t work, but doesn’t kill MagicMirror anymore…
                • evroomE Offline
                  evroom
                  Correct.
                  I have a few questions.
                  In the original module there is no package.json file, where in the cloned one there is.
                  So, when using the original module, you should NOT use npm install, right ?
                  First of all it will no do anything useful, but it WILL delete your /home/pi/MagicMirror/modules/node_modules/node_helperdirectory and its index.js file.
                  When using the cloned module, you should run npm installin order to install the dependencies mentioned in it, right ?
                  No harm is done to the node_helper dir.
                  Or is it all BS I am telling here (and made the wrong observations) ??
                    sdetweil @evroom
                    @evroom i cloned and got no package.json
                    i cloned this
                    https://github.com/paphko/mmm-weatherchart
                      sdetweil @evroom
                      @evroom yes, to all your observations…
                      • evroomE Offline
                        evroom
                        When I use
                        $ git clone https://github.com/szech/mmm-weatherchart.git
                        then it works.
                        The README.md from szech point to papkto.
                        When corrected and doing npm install in the mmm-weatherchart directory, it works
                          sdetweil @evroom
                          @evroom yes, that module has it…
                          • K Offline
                            kvicksson @sdetweil
                            @sdetweil Thanks! This worked for me as it doesn’t kill it anymore. Hope for a quick fix. Can I follow the process somewhere?
                            S evroomE 3 Replies Last reply Reply Quote 0
                            • evroomE Offline
                              evroom
                              Hi @kvicksson ,
                              To me it seems there are 3 problems here.
                              You could have a look what the pm2 log says:
                              $ pm2 logs --lines 100
                              You will either have:
                              or:
                              or something completely different.
                              The 3 problems and potential solutions:
                              You’re config.js entries:
                              updateInterval: '3600000',
                              hideBorder: 'true'
                              should be:
                              updateInterval: 3600000,
                              hideBorder: true
                              even if the module could potentially handle it.
                              If your mmm-weatherchart instal has this file present:
                              /home/pi/MagicMirror/modules/mmm-weatherchart/package.json
                              then you should run:
                              $ cd /home/pi/MagicMirror/modules/mmm-weatherchart/
                              $ npm install
                              If your mmm-weatherchart instal has this file NOT present:
                              then you should NOT run npm instal, has it will cause havoc to you MagicMirror install.
                              I would do this in this situation:
                              $ mv mmm-weatherchart mmm-weatherchart.saved
                              $ npm install
                              $ pm2 restart pm2
                              When it works:
                              $ rm -rf mmm-weatherchart.saved
                              Good luck !!
                              PS @sdetweil : please comment if I am wrong or made mistakes somewhere & thanks for your input.
                              S K 2 Replies Last reply Reply Quote 0
                                sdetweil @kvicksson
                                @kvicksson said in Blank mm after update:
                                this is all volunteer… you could post an issue to the module owners github repo… maybe he or someone else will respond… I am like you, just another user…
                                • evroomE Offline
                                  evroom @kvicksson
                                  I should type faster :-)
                                    sdetweil @evroom
                                    @evroom think u have good instructions…
                                    ps, 2 of my three systems do not have pi as the user, so the path is wrong, and in the module defaults too
                                    • evroomE Offline
                                      evroom
                                      Yes, I assumed user pi and the install under the user pi home directory.
                                      Will try to remember that in the future.
                                      Tilde for the home directory should work on all platforms, is my understanding.
                                      ~/MagicMirror
                                      My keyboard is lacking a tilde and I always forget the right keystrokes.
                                      So /home/pi is faster. :-)
                                      • K Offline
                                        kvicksson @evroom
                                        @evroom I sat right now and installed a new calendar module and suddenly the mmm-weatherchart started working… :thinking_face:
                                        Did the $ pm2 logs --lines 100 and got a lot of errors, but I guess because everything’s working fine so don’t have to bother right now?!
                                        • K Offline
                                          kvicksson
                                          And of course it didn’t work now when I tried to switch back to default calendar module and then back to the other calendar module…
                                          • evroomE Offline
                                            evroom
                                            As long as the errors are no fatal errors that do not prevent the MagicMirror from starting or prevent a certain module from working right, you might chose to ignore them.
                                            But the problem is, that when you add something new or update something existing, it becomes more and more difficult to debug and/or correct in case of problems.
                                            When you do this:
                                            $ pm2 flush
                                            $ pm2 restart mm
                                            what is the first error you see ?
                                            Perhaps you post the first 50 to 100 lines of the log.
                                            But only if you want to spend some time on it, when not that’s fine too.
                                            • 2 / 3
