    Blank mm after update
    48 Posts 4 Posters 23.9k Views 4 Watching
      sdetweil @evroom
      @evroom think u have good instructions…
      ps, 2 of my three systems do not have pi as the user, so the path is wrong, and in the module defaults too
      • evroomE Offline
        evroom
        @sdetweil said in Blank mm after update:
        Yes, I assumed user pi and the install under the user pi home directory.
        Will try to remember that in the future.
        Tilde for the home directory should work on all platforms, is my understanding.
        ~/MagicMirror
        My keyboard is lacking a tilde and I always forget the right keystrokes.
        So /home/pi is faster. :-)
        MagicMirror version: 2.37.0
        • K Offline
          kvicksson @evroom
          @evroom I sat right now and installed a new calendar module and suddenly the mmm-weatherchart started working… :thinking_face:
          Did the $ pm2 logs --lines 100 and got a lot of errors, but I guess because everything’s working fine so don’t have to bother right now?!
          • K Offline
            kvicksson
            And of course it didn’t work now when I tried to switch back to default calendar module and then back to the other calendar module…
            • evroomE Offline
              evroom
              @kvicksson said in Blank mm after update:
              As long as the errors are no fatal errors that do not prevent the MagicMirror from starting or prevent a certain module from working right, you might chose to ignore them.
              But the problem is, that when you add something new or update something existing, it becomes more and more difficult to debug and/or correct in case of problems.
              When you do this:
              $ pm2 flush
              $ pm2 restart mm
              what is the first error you see ?
              Perhaps you post the first 50 to 100 lines of the log.
              But only if you want to spend some time on it, when not that’s fine too.
              • K Offline
                kvicksson @evroom
                @evroom actually no errors like I got before…
                PM2        | 2019-08-29T21:46:00: PM2 log: pid=1331 msg=failed to kill - retrying in 100ms
                PM2        | 2019-08-29T21:46:00: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                PM2        | 2019-08-29T21:46:00: PM2 log: pid=1331 msg=process killed
                PM2        | 2019-08-29T21:46:00: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2019-08-29T21:46:00: PM2 log: App [mm:0] online
                0|mm       | Shutting down server...
                0|mm       | Stopping module helper: updatenotification
                0|mm       | Stopping module helper: mmm-systemtemperature
                0|mm       |
                0|mm       | > magicmirror@2.8.0 start /home/pi/MagicMirror
                0|mm       | > sh run-start.sh
                0|mm       |
                0|mm       | Starting MagicMirror: v2.8.0
                0|mm       | Loading config ...
                0|mm       | Loading module helpers ...
                0|mm       | No helper found for module: alert.
                0|mm       | Initializing new module helper ...
                0|mm       | Module helper loaded: updatenotification
                0|mm       | Module helper loaded: mmm-systemtemperature
                0|mm       | No helper found for module: clock.
                0|mm       | Module helper loaded: calendar
                0|mm       | Module helper loaded: MMM-YrThen
                0|mm       | Module helper loaded: mmm-weatherchart
                0|mm       | Module helper loaded: newsfeed
                0|mm       | All module helpers loaded.
                0|mm       | Starting server on port 8080 ...
                0|mm       | Server started ...
                0|mm       | Connecting socket for: updatenotification
                0|mm       | Connecting socket for: mmm-systemtemperature
                0|mm       | Starting node helper: mmm-systemtemperature
                0|mm       | Connecting socket for: calendar
                0|mm       | Starting node helper for: calendar
                0|mm       | Connecting socket for: MMM-YrThen
                0|mm       | MMM-YrThen 8/29/2019 9:46:08 PM: Starting helper for MMM-YrThen
                0|mm       | Connecting socket for: mmm-weatherchart
                0|mm       | Starting node helper: mmm-weatherchart
                0|mm       | Connecting socket for: newsfeed
                0|mm       | Starting module: newsfeed
                0|mm       | Sockets connected & modules started ...
                0|mm       | Launching application.
                0|mm       | /home/pi/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /home/pi/MagicMirror/node_modules/electron/dist/electron)
                0|mm       | (node:2465) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                0|mm       | /proc/self/exe: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /proc/self/exe)
                0|mm       | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                I really appreciate you want to look into my errors, I’m not too good on this :)
                evroomE 2 Replies Last reply Reply Quote 0
                • evroomE Offline
                  evroom
                  @kvicksson
                  Doesn’t look too bad.
                  Probably you saw the previous errors in your log output, that it is why flushing (pm2 flush) sometimes cannot hurt.
                  In order to know a bit about your environment, can you post the output of the following commands ?
                  I am assuming you are using a Raspberry Pi
                  $ cat /proc/device-tree/model
                  $ lsb_release -a
                  $ npm --version
                  $ node --version
                  $ pm2 --version
                  $ cat /boot/config.txt | egrep -v '^$|^#|^\['
                  I also would suggest to see if npm shows any errors:
                  $ cd ~/MagicMirror
                  $ npm audit
                  In my case a
                  $ npm audit fix
                  solved the dependency issues it found.
                  Perhaps others have different ideas, but as a hobbyist, I would take these steps first myself.
                  • lavolp3L Offline
                    lavolp3 Module Developer
                    @evroom said in Blank mm after update:
                    In my case a
                    $ npm audit fix
                    The npm audit warnings do not create any problems in running the mirror as far as I know. They also do not show up in the pm2 logs.
                    I would even be very careful as an inexperienced user to do that. “Fixing” these npm warnings on the root MM install could break the whole mirror (not the mirror itself of course :-)). Especially if you mess with the electron/chromium dependencies.
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                    • K Offline
                      kvicksson @evroom
                      @evroom got an error on the egrep command:
                      pi@raspberrypi:~ $ cat /proc/device-tree/model
                      Raspberry Pi 3 Model B Rev 1.2pi@raspberrypi:~ $ lsb_release -a
                      No LSB modules are available.
                      Distributor ID: Raspbian
                      Description:    Raspbian GNU/Linux 8.0 (jessie)
                      Release:        8.0
                      Codename:       jessie
                      pi@raspberrypi:~ $ npm --version
                      5.6.0
                      pi@raspberrypi:~ $ node --version
                      v9.11.2
                      pi@raspberrypi:~ $ pm2 --version
                      3.5.1
                      pi@raspberrypi:~ $ cat /boot/config.txt | egrep -v '^$|^#|^['
                      grep: Invalid regular expression
                      • evroomE Offline
                        evroom
                        Forgot to escape the [, try this:
                        EDIT: Did not forget to escape it, it is this shitty forum that removes it.
                        There needs to a backslash \ before the last [
                        • evroomE Offline
                          evroom @lavolp3
                          @lavolp3 said in Blank mm after update:
                          The npm audit itself suggests to fix it using the fix option.
                          I personally never had any issues with this command, but perhaps I was lucky till now.
                          Sometimes it cannot resolve an issue, but it never broke anything.
                          But, if it appears to be that dangerous, then indeed it is perhaps to refrain from it when not really necessary.
                          • evroomE Offline
                            evroom @kvicksson
                            I saw this error once for a specific module.
                            Needed a small code change.
                            Will try to find what is was.
                            • evroomE Offline
                              evroom
                              This is a command to list all your modules that are in the config.js and which ones are enabled/disabled:
                              $ cat ~/MagicMirror/config/config.js | egrep 'module:|disabled' | sed -e 's/^[ \t]*//'
                                sdetweil @evroom
                                @evroom cool… how can u tell which module ‘disabled’ applies to?
                                system 1
                                module: "alert",
                                disabled: false,
                                module: "updatenotification",
                                module: "clock",
                                disabled: false,
                                disabled: false,
                                module: "MMM-SleepWake",
                                module: "newsfeed",
                                disabled: false,
                                disabled: false,
                                module: 'WaterLevels',
                                disabled: false,
                                module: "MMM-ImagesPhotos",
                                disabled: true,
                                module: 'MMM-MQTTfloorplan',
                                disabled: false,
                                module: "MMM-AssistantMk2",
                                module: "MMM-Hotword",
                                disabled: false,
                                disabled: true,
                                module: "default/SampleModule",
                                disabled: true,
                                module: "MMM-GoogleMapsTraffic",
                                disabled: true,
                                module: "MMM-PC-Stats",
                                disabled: true,
                                module: 'mmm-weatherchart',
                                system 2
                                module: "alert",
                                //                      module: "updatenotification",
                                module: "clock",
                                //                      module: "calendar",
                                //                      module: 'MMM-WunderGround',
                                //                      module: "newsfeed",
                                disabled: false,
                                module: 'MMM-voice',
                                disabled: false,
                                module: 'MMM-WatchDog',
                                system 3
                                module: "alert",
                                module: "clock",
                                disabled: true,
                                module: "compliments",
                                module: "currentweather",
                                module: "weatherforecast",
                                module: "newsfeed",
                                disabled: false,
                                i wrote this little piece of node js to find active modules for my upgrade script
                                const config = require('../config/config.js');const fs=require('fs');
                                for(let m of config.modules){
                                	if(!(m.disabled || false)){
                                       	console.log(m.module);
                                • evroomE Offline
                                  evroom
                                  I am assuming it is sequential and that disabled: comes after module:, when present. Don’t think a ‘runaway’ disabled could exist.
                                  And for the purpose it serves, it does its job, IMHO.
                                  Perhaps it is better to first remove the leading blank space and then do the grep (and to ignore the comment parts):
                                  $ cat ~/MagicMirror/config/config.js | sed -e 's/^[ \t]*//' | egrep -w '^module:|^disabled:'
                                  Your piece of node.js looks nice, but how to run it standalone ?
                                  If used as part of a script, it makes more sense to do it this way (more control, more flexible).
                                  • evroomE Offline
                                    evroom
                                    module: “newsfeed”,
                                    disabled: false,
                                    disabled: false,
                                    I see now, that this is rather odd, not correct, without thinking too much about it.
                                    Does my modified command give the same result ?
                                    It sort of contradicts my statement on being sequential, etc.
                                    Or do you really have ?
                                    module: "newsfeed",
                                    disabled: false,
                                    disabled: false,
                                    disabled: false,
                                    disabled: true,
                                      sdetweil @evroom
                                      @evroom
                                      easy to run
                                      node scriptname.js
                                        sdetweil @evroom
                                        @evroom i have disabled, before and after module all thruout the config.js
                                        it is not positional
                                              diabled: true,
                                              module: "alert",
                                              disabled: false,
                                              position: "top_bar",
                                                updateInterval: 3 * 60 * 1000,
                                                refreshInterval: 10 * 60 * 1000
                                              module: "clock",
                                        				showWeek: false,
                                        				sendNotitifications: false
                                              disabled: false,
                                                showEnd: false,
                                                timeFormat: 'relative',
                                                //fetchInterval: 10000,
                                                    symbol: "family ",
                                                    //url: "https://www.ojrsd.com//site/handlers/icalfeed.ashx?MIID=11",
                                                  //url: "http://localhost:8086/modules/cals/basic.ics"
                                                disabled: false,
                                                    delay: 5, // minutes , default = 15 minutes
                                                    "source":
                                                        "External",
                                                        // choices are PIR       -- uses the Raspberry pi hardware dection pins and PIR sensor
                                                        //      	or
                                                        //             External  -- uses some external source for motion detection, like a video camera
                                                        //                       -- see the github motion project
                                                        // mode
                                                        // HOW to go to sleep
                                                        //    use hardware(hdmi), software (dpms), or simulate (hide content leaving black screen)
                                                    "mode":"hide",
                                                        // mode choices are
                                                        //  'pi':
                                                        //        executes the tvservice command
                                                        //  'dpms'
                                                        //        executes the 'xset dpms force' command
                                                        //  'hide'
                                                        //        hides all modules. modules hidden when the sleep is issued will be hidden on wakeup
                                                        //        for energyStar monitors and TVs, this allows the screen to remain powered on so it will come alive on movement
                                                    //detectionDir: '/home/odroid/MagicMirror/modules/MMM-SleepWake/motion'
                                                        // detectionDir: folder containing externally generated file when motion starts
                                                        //               will be created if needed
                                                        // detectionFile:  filename generated for motion start. default = 'detected'
                                              module: "newsfeed",
                                              disabled: false,
                                              position: "bottom_bar",
                                        				ignoreOldItems:false,
                                                feeds: [
                                                    title: "New York Times",
                                                    title: "BBC",
                                                    url: "http://feeds.bbci.co.uk/news/world/rss.xml",
                                                    title: "SRS",
                                                    url: "http://feeds.news24.com/articles/news24/SouthAfrica/rss",
                                                showSourceTitle: true,
                                                showPublishDate: true
                                        				disabled: false,
                                        				position: 'top_right',
                                        				config : {
                                        							width: 400,
                                        							height: 400,
                                        							Pins: [ 'v14','v3' ],
                                        								labels:['Water Usage','Water level'],
                                        								yaxis_legend: ['gallons used','gallons'],
                                        								ranges: [{"min":0,"max":200,"stepSize":100}, {"min":0,"max":2029,"stepSize":500}],
                                        								pinLimits: [20,1700],
                                        							dayrange: 3,
                                        							updateInterval: 5,
                                        							stacked: true,
                                        				disabled: false,
                                        				position: "fullscreen",
                                        					opacity: 0.9,
                                        					animationSpeed: 0,
                                        					updateInterval: 15000,
                                        					backgroundColor: "#808080",
                                        					path: "/selectedpics",
                                        					debug:true
                                        				disabled: true,
                                        				position: 'center', // this can be any of the regions
                                        					mqttServer: {
                                        						url: "192.168.0.110",
                                        						user: "",
                                        						password: ""
                                        					floorplan: {
                                        						image: "floorplan.png", // image in subfolder 'images'; change to floorplan.png to avoid git repository changes
                                        						width: 634, // this must be the width of the image above
                                        						height: 392, // this must be the height of the image above
                                        					subscriptions: [
                                        						topic: '', // MQTT Topic name
                                        						label: 'Living Light',	// Not displayed anywhere!
                                        						type: 'door',			// Using 'door' instead 'light' to get 2-state icon
                                        						display: { left: 50, top: 50 },
                                        						topic: '',
                                        						label: 'First Floor Corr PIR',
                                        						type: 'motion',
                                        						display: { left: 100, top: 150 },
                                        						topic: 'LivT',
                                        						label: 'Living Temp',
                                        						type: 'label',
                                        						display: { left: 44, top: 159, prefix: "", suffix: " °C", decimals: 1 },
                                        						topic: 'LivH',
                                        						label: 'Living Humidity',
                                        						type: 'label',
                                        						display: { left: 44, top: 179, prefix: "", suffix: " %RH", decimals: 0 },
                                        						topic: 'GuestT',
                                        						label: 'Guest Room Temp',
                                        						type: 'label',
                                        						display: { left: 255, top: 193, prefix: "", suffix: " °C", decimals: 1 },
                                        						topic: 'GuestH',
                                        						label: 'Guest Room Humidity',
                                        						type: 'label',
                                        						display: { left: 255, top: 213, prefix: "", suffix: " %RH", decimals: 0 },
                                        						topic: 'eStatus',
                                        						label: 'Weather',
                                        						type: 'label',
                                        						  fields: ['OAT','OAH'],
                                        						//key: 'OAT', //I would like to have configurable keyword for each name of object that I want display.
                                        						//jsonpointer: '/OAT',
                                        						display: { left: 55, top: 337, prefix: "", suffix: " °C", decimals: 1 },
                                            disabled: false,
                                              record: {
                                                recordProgram : "arecord",
                                                device        : "default",
                                              notifications: {
                                                ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                                                ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                                            disabled: false,
                                              record: {
                                                device        : "default",
                                              snowboy: [
                                                hotwords: "smart mirror", //this will be sent to other module for distinguishing which hotword is detected.
                                                file: "resources/models/smart_mirror.umdl",
                                                sensitivity: '0.5',
                                              autostart:true,
                                              autorestart: false,
                                              onDetected: {
                                                notification: function (payload) {
                                                  return "ASSISTANT_ACTIVATE"
                                                payload: function (payload){
                                                  return {
                                                    profile: payload.hotword
                                        		disabled: true,
                                        		position:'middle'
                                        					disabled: true,
                                        		      position: "bottom_right",
        lat: 41.8816281,
                                        															lng: -87.6608605,
                                        			                height: "300px",
                                        			                width: "300px",
                                        					mapTypeId: "roadmap",
                                        			                styledMapType: "transparent",
                                        			                disableDefaultUI: "true",
                                        					updateInterval: "60000",
                                        			                backgroundColor: "hsla(0, 0%, 0%, 0)",
                                        			                markers: [
        lat: 41.8816281,
                                        															lng: -87.6608605,
        fillColor: "#9966ff"
                                        			  disabled: true,
                                        				position: "middle",
                                        		disabled: true,
                                        		position: 'bottom_left', // this can be any of the regions
                                        			country: 'Germany', // as determined above
                                        			area: 'North_Rhine-Westphalia', // as determined above
                                        			city: 'Duisburg', // as determined above
                                        			updateInterval: 60 * 60 * 1000, // update every hour
                                        			hideBorder: true, // whether or not a border with city name should be shown
                                        			negativeImage: true, // whether or not the default white image should be inverted
                                        			mmDirectory: "/home/odroid/MagicMirror/" // required for caching; adjust if it differs
                                          sdetweil @evroom
                                          @evroom modified results at least lose the comments
                                          module: "alert",
                                          disabled: false,
                                          module: "clock",
                                          disabled: false,
                                          disabled: false,
                                          module: "newsfeed",
                                          disabled: false,
                                          disabled: false,
                                          disabled: false,
                                          disabled: true,
                                          disabled: false,
                                          disabled: false,
                                          disabled: true,
                                          disabled: true,
                                          disabled: true,
                                          disabled: true,
                                          • evroomE Offline
                                            evroom @kvicksson
                                            @kvicksson
                                            If these are the only ‘errors’ you see in the pm2 log, then it looks you are quite okay.
                                            As said, I personally would like to ged rid of npm audit errors, but if other board-members think it imposes a hazard to a good running system, then I would leave it. I remember that sometimes some dependencies just did not want to go away and I left it that way.
                                            The only thing to consider, is that you are still running on Debian jessie, where the majority probably runs using stretch and fast adopters on buster.
                                            I would leave this until you setup a new system.
                                            So, when it runs as you expect it to run, then you can close this topic and enjoy your mirror. Otherwise we will hear from you.
                                            • 2 / 3
