    Blank mm after update
    48 Posts 4 Posters 25.6k Views 4 Watching
    • evroomE
      evroom
      @kvicksson
      Doesn’t look too bad.
      Probably you saw the previous errors in your log output, that it is why flushing (pm2 flush) sometimes cannot hurt.
      In order to know a bit about your environment, can you post the output of the following commands ?
      I am assuming you are using a Raspberry Pi
      $ cat /proc/device-tree/model
      $ lsb_release -a
      $ npm --version
      $ node --version
      $ pm2 --version
      $ cat /boot/config.txt | egrep -v '^$|^#|^\['
      I also would suggest to see if npm shows any errors:
      $ cd ~/MagicMirror
      $ npm audit
      In my case a
      $ npm audit fix
      solved the dependency issues it found.
      Perhaps others have different ideas, but as a hobbyist, I would take these steps first myself.
      MagicMirror version: 2.37.0
      • lavolp3L
        lavolp3 Module Developer
        @evroom said in Blank mm after update:
        In my case a
        $ npm audit fix
        The npm audit warnings do not create any problems in running the mirror as far as I know. They also do not show up in the pm2 logs.
        I would even be very careful as an inexperienced user to do that. “Fixing” these npm warnings on the root MM install could break the whole mirror (not the mirror itself of course :-)). Especially if you mess with the electron/chromium dependencies.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • K
          kvicksson @evroom
          @evroom got an error on the egrep command:
          pi@raspberrypi:~ $ cat /proc/device-tree/model
          Raspberry Pi 3 Model B Rev 1.2pi@raspberrypi:~ $ lsb_release -a
          No LSB modules are available.
          Distributor ID: Raspbian
          Description:    Raspbian GNU/Linux 8.0 (jessie)
          Release:        8.0
          Codename:       jessie
          pi@raspberrypi:~ $ npm --version
          5.6.0
          pi@raspberrypi:~ $ node --version
          v9.11.2
          pi@raspberrypi:~ $ pm2 --version
          3.5.1
          pi@raspberrypi:~ $ cat /boot/config.txt | egrep -v '^$|^#|^['
          grep: Invalid regular expression
          • evroomE
            evroom
            @kvicksson said in Blank mm after update:
            Forgot to escape the [, try this:
            EDIT: Did not forget to escape it, it is this shitty forum that removes it.
            There needs to a backslash \ before the last [
            • evroomE
              evroom @lavolp3
              @lavolp3 said in Blank mm after update:
              The npm audit itself suggests to fix it using the fix option.
              I personally never had any issues with this command, but perhaps I was lucky till now.
              Sometimes it cannot resolve an issue, but it never broke anything.
              But, if it appears to be that dangerous, then indeed it is perhaps to refrain from it when not really necessary.
              • evroomE
                evroom @kvicksson
                (node:2465) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                I saw this error once for a specific module.
                Needed a small code change.
                Will try to find what is was.
                • evroomE
                  evroom
                  This is a command to list all your modules that are in the config.js and which ones are enabled/disabled:
                  $ cat ~/MagicMirror/config/config.js | egrep 'module:|disabled' | sed -e 's/^[ \t]*//'
                    sdetweil @evroom
                    @evroom cool… how can u tell which module ‘disabled’ applies to?
                    system 1
                    module: "alert",
                    disabled: false,
                    module: "updatenotification",
                    module: "clock",
                    disabled: false,
                    disabled: false,
                    module: "MMM-SleepWake",
                    module: "newsfeed",
                    disabled: false,
                    disabled: false,
                    module: 'WaterLevels',
                    disabled: false,
                    module: "MMM-ImagesPhotos",
                    disabled: true,
                    module: 'MMM-MQTTfloorplan',
                    disabled: false,
                    module: "MMM-AssistantMk2",
                    module: "MMM-Hotword",
                    disabled: false,
                    disabled: true,
                    module: "default/SampleModule",
                    disabled: true,
                    module: "MMM-GoogleMapsTraffic",
                    disabled: true,
                    module: "MMM-PC-Stats",
                    disabled: true,
                    module: 'mmm-weatherchart',
                    system 2
                    module: "alert",
                    //                      module: "updatenotification",
                    module: "clock",
                    //                      module: "calendar",
                    //                      module: 'MMM-WunderGround',
                    //                      module: "newsfeed",
                    disabled: false,
                    module: 'MMM-voice',
                    disabled: false,
                    module: 'MMM-WatchDog',
                    system 3
                    module: "alert",
                    module: "clock",
                    disabled: true,
                    module: "compliments",
                    module: "currentweather",
                    module: "weatherforecast",
                    module: "newsfeed",
                    disabled: false,
                    i wrote this little piece of node js to find active modules for my upgrade script
                    const config = require('../config/config.js');const fs=require('fs');
                    for(let m of config.modules){
                    	if(!(m.disabled || false)){
                           	console.log(m.module);
                    • evroomE
                      evroom
                      @sdetweil said in Blank mm after update:
                      I am assuming it is sequential and that disabled: comes after module:, when present. Don’t think a ‘runaway’ disabled could exist.
                      And for the purpose it serves, it does its job, IMHO.
                      Perhaps it is better to first remove the leading blank space and then do the grep (and to ignore the comment parts):
                      $ cat ~/MagicMirror/config/config.js | sed -e 's/^[ \t]*//' | egrep -w '^module:|^disabled:'
                      Your piece of node.js looks nice, but how to run it standalone ?
                      If used as part of a script, it makes more sense to do it this way (more control, more flexible).
                      • evroomE
                        evroom
                        module: “newsfeed”,
                        disabled: false,
                        disabled: false,
                        I see now, that this is rather odd, not correct, without thinking too much about it.
                        Does my modified command give the same result ?
                        It sort of contradicts my statement on being sequential, etc.
                        Or do you really have ?
                        module: "newsfeed",
                        disabled: false,
                        disabled: false,
                        disabled: false,
                        disabled: true,
                          sdetweil @evroom
                          @evroom
                          easy to run
                          node scriptname.js
                            sdetweil @evroom
                            @evroom i have disabled, before and after module all thruout the config.js
                            it is not positional
                                  diabled: true,
                                  module: "alert",
                                  disabled: false,
                                  position: "top_bar",
                                    updateInterval: 3 * 60 * 1000,
                                    refreshInterval: 10 * 60 * 1000
                                  module: "clock",
                            				showWeek: false,
                            				sendNotitifications: false
                                  disabled: false,
                                    showEnd: false,
                                    timeFormat: 'relative',
                                    //fetchInterval: 10000,
                                        symbol: "family ",
                                        //url: "https://www.ojrsd.com//site/handlers/icalfeed.ashx?MIID=11",
                                      //url: "http://localhost:8086/modules/cals/basic.ics"
                                    disabled: false,
                                        delay: 5, // minutes , default = 15 minutes
                                        "source":
                                            "External",
                                            // choices are PIR       -- uses the Raspberry pi hardware dection pins and PIR sensor
                                            //      	or
                                            //             External  -- uses some external source for motion detection, like a video camera
                                            //                       -- see the github motion project
                                            // mode
                                            // HOW to go to sleep
                                            //    use hardware(hdmi), software (dpms), or simulate (hide content leaving black screen)
                                        "mode":"hide",
                                            // mode choices are
                                            //  'pi':
                                            //        executes the tvservice command
                                            //  'dpms'
                                            //        executes the 'xset dpms force' command
                                            //  'hide'
                                            //        hides all modules. modules hidden when the sleep is issued will be hidden on wakeup
                                            //        for energyStar monitors and TVs, this allows the screen to remain powered on so it will come alive on movement
                                        //detectionDir: '/home/odroid/MagicMirror/modules/MMM-SleepWake/motion'
                                            // detectionDir: folder containing externally generated file when motion starts
                                            //               will be created if needed
                                            // detectionFile:  filename generated for motion start. default = 'detected'
                                  module: "newsfeed",
                                  disabled: false,
                                  position: "bottom_bar",
                            				ignoreOldItems:false,
                                    feeds: [
                                        title: "New York Times",
                                        title: "BBC",
                                        url: "http://feeds.bbci.co.uk/news/world/rss.xml",
                                        title: "SRS",
                                        url: "http://feeds.news24.com/articles/news24/SouthAfrica/rss",
                                    showSourceTitle: true,
                                    showPublishDate: true
                            				disabled: false,
                            				position: 'top_right',
                            				config : {
                            							width: 400,
                            							height: 400,
                            							Pins: [ 'v14','v3' ],
                            								labels:['Water Usage','Water level'],
                            								yaxis_legend: ['gallons used','gallons'],
                            								ranges: [{"min":0,"max":200,"stepSize":100}, {"min":0,"max":2029,"stepSize":500}],
                            								pinLimits: [20,1700],
                            							dayrange: 3,
                            							updateInterval: 5,
                            							stacked: true,
                            				disabled: false,
                            				position: "fullscreen",
                            					opacity: 0.9,
                            					animationSpeed: 0,
                            					updateInterval: 15000,
                            					backgroundColor: "#808080",
                            					path: "/selectedpics",
                            					debug:true
                            				disabled: true,
                            				position: 'center', // this can be any of the regions
                            					mqttServer: {
                            						url: "192.168.0.110",
                            						user: "",
                            						password: ""
                            					floorplan: {
                            						image: "floorplan.png", // image in subfolder 'images'; change to floorplan.png to avoid git repository changes
                            						width: 634, // this must be the width of the image above
                            						height: 392, // this must be the height of the image above
                            					subscriptions: [
                            						topic: '', // MQTT Topic name
                            						label: 'Living Light',	// Not displayed anywhere!
                            						type: 'door',			// Using 'door' instead 'light' to get 2-state icon
                            						display: { left: 50, top: 50 },
                            						topic: '',
                            						label: 'First Floor Corr PIR',
                            						type: 'motion',
                            						display: { left: 100, top: 150 },
                            						topic: 'LivT',
                            						label: 'Living Temp',
                            						type: 'label',
                            						display: { left: 44, top: 159, prefix: "", suffix: " °C", decimals: 1 },
                            						topic: 'LivH',
                            						label: 'Living Humidity',
                            						type: 'label',
                            						display: { left: 44, top: 179, prefix: "", suffix: " %RH", decimals: 0 },
                            						topic: 'GuestT',
                            						label: 'Guest Room Temp',
                            						type: 'label',
                            						display: { left: 255, top: 193, prefix: "", suffix: " °C", decimals: 1 },
                            						topic: 'GuestH',
                            						label: 'Guest Room Humidity',
                            						type: 'label',
                            						display: { left: 255, top: 213, prefix: "", suffix: " %RH", decimals: 0 },
                            						topic: 'eStatus',
                            						label: 'Weather',
                            						type: 'label',
                            						  fields: ['OAT','OAH'],
                            						//key: 'OAT', //I would like to have configurable keyword for each name of object that I want display.
                            						//jsonpointer: '/OAT',
                            						display: { left: 55, top: 337, prefix: "", suffix: " °C", decimals: 1 },
                                disabled: false,
                                  record: {
                                    recordProgram : "arecord",
                                    device        : "default",
                                  notifications: {
                                    ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                                    ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                                disabled: false,
                                  record: {
                                    device        : "default",
                                  snowboy: [
                                    hotwords: "smart mirror", //this will be sent to other module for distinguishing which hotword is detected.
                                    file: "resources/models/smart_mirror.umdl",
                                    sensitivity: '0.5',
                                  autostart:true,
                                  autorestart: false,
                                  onDetected: {
                                    notification: function (payload) {
                                      return "ASSISTANT_ACTIVATE"
                                    payload: function (payload){
                                      return {
                                        profile: payload.hotword
                            		disabled: true,
                            		position:'middle'
                            					disabled: true,
                            		      position: "bottom_right",
                            			                        lat: 41.8816281,
                            															lng: -87.6608605,
                            			                height: "300px",
                            			                width: "300px",
                            					mapTypeId: "roadmap",
                            			                styledMapType: "transparent",
                            			                disableDefaultUI: "true",
                            					updateInterval: "60000",
                            			                backgroundColor: "hsla(0, 0%, 0%, 0)",
                            			                markers: [
                            			                        lat: 41.8816281,
                            															lng: -87.6608605,
                            			                        fillColor: "#9966ff"
                            			  disabled: true,
                            				position: "middle",
                            		disabled: true,
                            		position: 'bottom_left', // this can be any of the regions
                            			country: 'Germany', // as determined above
                            			area: 'North_Rhine-Westphalia', // as determined above
                            			city: 'Duisburg', // as determined above
                            			updateInterval: 60 * 60 * 1000, // update every hour
                            			hideBorder: true, // whether or not a border with city name should be shown
                            			negativeImage: true, // whether or not the default white image should be inverted
                            			mmDirectory: "/home/odroid/MagicMirror/" // required for caching; adjust if it differs
                              sdetweil @evroom
                              @evroom modified results at least lose the comments
                              module: "alert",
                              disabled: false,
                              module: "clock",
                              disabled: false,
                              disabled: false,
                              module: "newsfeed",
                              disabled: false,
                              disabled: false,
                              disabled: false,
                              disabled: true,
                              disabled: false,
                              disabled: false,
                              disabled: true,
                              disabled: true,
                              disabled: true,
                              disabled: true,
                              • evroomE
                                evroom @kvicksson
                                @kvicksson
                                If these are the only ‘errors’ you see in the pm2 log, then it looks you are quite okay.
                                As said, I personally would like to ged rid of npm audit errors, but if other board-members think it imposes a hazard to a good running system, then I would leave it. I remember that sometimes some dependencies just did not want to go away and I left it that way.
                                The only thing to consider, is that you are still running on Debian jessie, where the majority probably runs using stretch and fast adopters on buster.
                                I would leave this until you setup a new system.
                                So, when it runs as you expect it to run, then you can close this topic and enjoy your mirror. Otherwise we will hear from you.
                                • evroomE
                                  evroom @sdetweil
                                  Okay, then it makes sense.
                                  I have module: always first and then disabled:.
                                  So you see that you never can assume something :-)
                                  Using your script now :thumbs_up:
                                    sdetweil @kvicksson
                                    @kvicksson can u mark your issue resolved?
                                    • 3 / 3
