    Blank mm after update
    48 Posts 4 Posters 23.9k Views 4 Watching
    • K Offline
      kvicksson @evroom
      @evroom got an error on the egrep command:
      pi@raspberrypi:~ $ cat /proc/device-tree/model
      Raspberry Pi 3 Model B Rev 1.2pi@raspberrypi:~ $ lsb_release -a
      No LSB modules are available.
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 8.0 (jessie)
      Release:        8.0
      Codename:       jessie
      pi@raspberrypi:~ $ npm --version
      5.6.0
      pi@raspberrypi:~ $ node --version
      v9.11.2
      pi@raspberrypi:~ $ pm2 --version
      3.5.1
      pi@raspberrypi:~ $ cat /boot/config.txt | egrep -v '^$|^#|^['
      grep: Invalid regular expression
      • evroomE Offline
        evroom
        @kvicksson said in Blank mm after update:
        Forgot to escape the [, try this:
        cat /boot/config.txt | egrep -v '^$|^#|^\['
        EDIT: Did not forget to escape it, it is this shitty forum that removes it.
        There needs to a backslash \ before the last [
        MagicMirror version: 2.37.0
        • evroomE Offline
          evroom @lavolp3
          @lavolp3 said in Blank mm after update:
          Fixing” these npm warnings on the root MM install could break the whole mirror
          The npm audit itself suggests to fix it using the fix option.
          I personally never had any issues with this command, but perhaps I was lucky till now.
          Sometimes it cannot resolve an issue, but it never broke anything.
          But, if it appears to be that dangerous, then indeed it is perhaps to refrain from it when not really necessary.
          • evroomE Offline
            evroom @kvicksson
            (node:2465) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
            I saw this error once for a specific module.
            Needed a small code change.
            Will try to find what is was.
            • evroomE Offline
              evroom
              This is a command to list all your modules that are in the config.js and which ones are enabled/disabled:
              $ cat ~/MagicMirror/config/config.js | egrep 'module:|disabled' | sed -e 's/^[ \t]*//'
                sdetweil @evroom
                @evroom cool… how can u tell which module ‘disabled’ applies to?
                system 1
                module: "alert",
                disabled: false,
                module: "updatenotification",
                module: "clock",
                disabled: false,
                disabled: false,
                module: "MMM-SleepWake",
                module: "newsfeed",
                disabled: false,
                disabled: false,
                module: 'WaterLevels',
                disabled: false,
                module: "MMM-ImagesPhotos",
                disabled: true,
                module: 'MMM-MQTTfloorplan',
                disabled: false,
                module: "MMM-AssistantMk2",
                module: "MMM-Hotword",
                disabled: false,
                disabled: true,
                module: "default/SampleModule",
                disabled: true,
                module: "MMM-GoogleMapsTraffic",
                disabled: true,
                module: "MMM-PC-Stats",
                disabled: true,
                module: 'mmm-weatherchart',
                system 2
                module: "alert",
                //                      module: "updatenotification",
                module: "clock",
                //                      module: "calendar",
                //                      module: 'MMM-WunderGround',
                //                      module: "newsfeed",
                disabled: false,
                module: 'MMM-voice',
                disabled: false,
                module: 'MMM-WatchDog',
                system 3
                module: "alert",
                module: "clock",
                disabled: true,
                module: "compliments",
                module: "currentweather",
                module: "weatherforecast",
                module: "newsfeed",
                disabled: false,
                i wrote this little piece of node js to find active modules for my upgrade script
                const config = require('../config/config.js');const fs=require('fs');
                for(let m of config.modules){
                	if(!(m.disabled || false)){
                       	console.log(m.module);
                • evroomE Offline
                  evroom
                  @sdetweil said in Blank mm after update:
                  I am assuming it is sequential and that disabled: comes after module:, when present. Don’t think a ‘runaway’ disabled could exist.
                  And for the purpose it serves, it does its job, IMHO.
                  Perhaps it is better to first remove the leading blank space and then do the grep (and to ignore the comment parts):
                  $ cat ~/MagicMirror/config/config.js | sed -e 's/^[ \t]*//' | egrep -w '^module:|^disabled:'
                  Your piece of node.js looks nice, but how to run it standalone ?
                  If used as part of a script, it makes more sense to do it this way (more control, more flexible).
                  • evroomE Offline
                    evroom
                    module: “newsfeed”,
                    disabled: false,
                    disabled: false,
                    I see now, that this is rather odd, not correct, without thinking too much about it.
                    Does my modified command give the same result ?
                    It sort of contradicts my statement on being sequential, etc.
                    Or do you really have ?
                    module: "newsfeed",
                    disabled: false,
                    disabled: false,
                    disabled: false,
                    disabled: true,
                      sdetweil @evroom
                      @evroom
                      easy to run
                      node scriptname.js
                        sdetweil @evroom
                        @evroom i have disabled, before and after module all thruout the config.js
                        it is not positional
                              diabled: true,
                              module: "alert",
                              disabled: false,
                              position: "top_bar",
                                updateInterval: 3 * 60 * 1000,
                                refreshInterval: 10 * 60 * 1000
                              module: "clock",
                        				showWeek: false,
                        				sendNotitifications: false
                              disabled: false,
                                showEnd: false,
                                timeFormat: 'relative',
                                //fetchInterval: 10000,
                                    symbol: "family ",
                                    //url: "https://www.ojrsd.com//site/handlers/icalfeed.ashx?MIID=11",
                                  //url: "http://localhost:8086/modules/cals/basic.ics"
                                disabled: false,
                                    delay: 5, // minutes , default = 15 minutes
                                    "source":
                                        "External",
                                        // choices are PIR       -- uses the Raspberry pi hardware dection pins and PIR sensor
                                        //      	or
                                        //             External  -- uses some external source for motion detection, like a video camera
                                        //                       -- see the github motion project
                                        // mode
                                        // HOW to go to sleep
                                        //    use hardware(hdmi), software (dpms), or simulate (hide content leaving black screen)
                                    "mode":"hide",
                                        // mode choices are
                                        //  'pi':
                                        //        executes the tvservice command
                                        //  'dpms'
                                        //        executes the 'xset dpms force' command
                                        //  'hide'
                                        //        hides all modules. modules hidden when the sleep is issued will be hidden on wakeup
                                        //        for energyStar monitors and TVs, this allows the screen to remain powered on so it will come alive on movement
                                    //detectionDir: '/home/odroid/MagicMirror/modules/MMM-SleepWake/motion'
                                        // detectionDir: folder containing externally generated file when motion starts
                                        //               will be created if needed
                                        // detectionFile:  filename generated for motion start. default = 'detected'
                              module: "newsfeed",
                              disabled: false,
                              position: "bottom_bar",
                        				ignoreOldItems:false,
                                feeds: [
                                    title: "New York Times",
                                    title: "BBC",
                                    url: "http://feeds.bbci.co.uk/news/world/rss.xml",
                                    title: "SRS",
                                    url: "http://feeds.news24.com/articles/news24/SouthAfrica/rss",
                                showSourceTitle: true,
                                showPublishDate: true
                        				disabled: false,
                        				position: 'top_right',
                        				config : {
                        							width: 400,
                        							height: 400,
                        							Pins: [ 'v14','v3' ],
                        								labels:['Water Usage','Water level'],
                        								yaxis_legend: ['gallons used','gallons'],
                        								ranges: [{"min":0,"max":200,"stepSize":100}, {"min":0,"max":2029,"stepSize":500}],
                        								pinLimits: [20,1700],
                        							dayrange: 3,
                        							updateInterval: 5,
                        							stacked: true,
                        				disabled: false,
                        				position: "fullscreen",
                        					opacity: 0.9,
                        					animationSpeed: 0,
                        					updateInterval: 15000,
                        					backgroundColor: "#808080",
                        					path: "/selectedpics",
                        					debug:true
                        				disabled: true,
                        				position: 'center', // this can be any of the regions
                        					mqttServer: {
                        						url: "192.168.0.110",
                        						user: "",
                        						password: ""
                        					floorplan: {
                        						image: "floorplan.png", // image in subfolder 'images'; change to floorplan.png to avoid git repository changes
                        						width: 634, // this must be the width of the image above
                        						height: 392, // this must be the height of the image above
                        					subscriptions: [
                        						topic: '', // MQTT Topic name
                        						label: 'Living Light',	// Not displayed anywhere!
                        						type: 'door',			// Using 'door' instead 'light' to get 2-state icon
                        						display: { left: 50, top: 50 },
                        						topic: '',
                        						label: 'First Floor Corr PIR',
                        						type: 'motion',
                        						display: { left: 100, top: 150 },
                        						topic: 'LivT',
                        						label: 'Living Temp',
                        						type: 'label',
                        						display: { left: 44, top: 159, prefix: "", suffix: " °C", decimals: 1 },
                        						topic: 'LivH',
                        						label: 'Living Humidity',
                        						type: 'label',
                        						display: { left: 44, top: 179, prefix: "", suffix: " %RH", decimals: 0 },
                        						topic: 'GuestT',
                        						label: 'Guest Room Temp',
                        						type: 'label',
                        						display: { left: 255, top: 193, prefix: "", suffix: " °C", decimals: 1 },
                        						topic: 'GuestH',
                        						label: 'Guest Room Humidity',
                        						type: 'label',
                        						display: { left: 255, top: 213, prefix: "", suffix: " %RH", decimals: 0 },
                        						topic: 'eStatus',
                        						label: 'Weather',
                        						type: 'label',
                        						  fields: ['OAT','OAH'],
                        						//key: 'OAT', //I would like to have configurable keyword for each name of object that I want display.
                        						//jsonpointer: '/OAT',
                        						display: { left: 55, top: 337, prefix: "", suffix: " °C", decimals: 1 },
                            disabled: false,
                              record: {
                                recordProgram : "arecord",
                                device        : "default",
                              notifications: {
                                ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                                ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                            disabled: false,
                              record: {
                                device        : "default",
                              snowboy: [
                                hotwords: "smart mirror", //this will be sent to other module for distinguishing which hotword is detected.
                                file: "resources/models/smart_mirror.umdl",
                                sensitivity: '0.5',
                              autostart:true,
                              autorestart: false,
                              onDetected: {
                                notification: function (payload) {
                                  return "ASSISTANT_ACTIVATE"
                                payload: function (payload){
                                  return {
                                    profile: payload.hotword
                        		disabled: true,
                        		position:'middle'
                        					disabled: true,
                        		      position: "bottom_right",
                        			                        lat: 41.8816281,
                        															lng: -87.6608605,
                        			                height: "300px",
                        			                width: "300px",
                        					mapTypeId: "roadmap",
                        			                styledMapType: "transparent",
                        			                disableDefaultUI: "true",
                        					updateInterval: "60000",
                        			                backgroundColor: "hsla(0, 0%, 0%, 0)",
                        			                markers: [
                        			                        lat: 41.8816281,
                        															lng: -87.6608605,
                        			                        fillColor: "#9966ff"
                        			  disabled: true,
                        				position: "middle",
                        		disabled: true,
                        		position: 'bottom_left', // this can be any of the regions
                        			country: 'Germany', // as determined above
                        			area: 'North_Rhine-Westphalia', // as determined above
                        			city: 'Duisburg', // as determined above
                        			updateInterval: 60 * 60 * 1000, // update every hour
                        			hideBorder: true, // whether or not a border with city name should be shown
                        			negativeImage: true, // whether or not the default white image should be inverted
                        			mmDirectory: "/home/odroid/MagicMirror/" // required for caching; adjust if it differs
                          sdetweil @evroom
                          @evroom modified results at least lose the comments
                          module: "alert",
                          disabled: false,
                          module: "clock",
                          disabled: false,
                          disabled: false,
                          module: "newsfeed",
                          disabled: false,
                          disabled: false,
                          disabled: false,
                          disabled: true,
                          disabled: false,
                          disabled: false,
                          disabled: true,
                          disabled: true,
                          disabled: true,
                          disabled: true,
                          • evroomE Offline
                            evroom @kvicksson
                            @kvicksson
                            If these are the only ‘errors’ you see in the pm2 log, then it looks you are quite okay.
                            As said, I personally would like to ged rid of npm audit errors, but if other board-members think it imposes a hazard to a good running system, then I would leave it. I remember that sometimes some dependencies just did not want to go away and I left it that way.
                            The only thing to consider, is that you are still running on Debian jessie, where the majority probably runs using stretch and fast adopters on buster.
                            I would leave this until you setup a new system.
                            So, when it runs as you expect it to run, then you can close this topic and enjoy your mirror. Otherwise we will hear from you.
                            • evroomE Offline
                              evroom @sdetweil
                              Okay, then it makes sense.
                              I have module: always first and then disabled:.
                              So you see that you never can assume something :-)
                              Using your script now :thumbs_up:
                                sdetweil @kvicksson
                                @kvicksson can u mark your issue resolved?
                                • 3 / 3
