Autoplay different module not working
thank for your answer
probably…but it was ok before…and it mention an error about audio but i have no video… -
a another life…lol…no, a update and upgrade…not a rpi update…
I don’t know if someone have differents modules for video . I’m using MMM-pages to scroll many modules and so 2 videos (not on the same page) -
@chassain-0 pages just hides and shows modules, doesn’t mean a module is not active in the background…
i don’t know how these modules work… but usually they have some startup that acquires resources. once acquired, they don’t let go
you’re right !
i’m going continue my research…thank a lot sdetweil -
last news : sometimes it works after a “pm2 restart mm”
have a good day
pm2 logs
Failed to create permanent mapping for memfd region with ID = 207878710
0|mm | Failed to regester memfd mempool. Reason: could not attach memfd SHM ID to pipe
0|mm | mmap() failed: Cannot allocate memory
0|mm | Failed to create permanent mapping for memfd region with ID = 1648210477
0|mm | Failed to create permanent mapping for memfd region with ID = 1088771516
0|mm | Ignoring received block reference with non-registered memfd ID = 1088771516
0|mm | Failed to create permanent mapping for memfd region with ID = 3067665855
0|mm | Failed to create permanent mapping for memfd region with ID = 3337011850
0|mm | Ignoring received block reference with non-registered memfd ID = 3337011850
