    Autoplay different module not working
    11 Posts 2 Posters 3.3k Views 2 Watching
      chassain 0
      I m using different modules with mmm-pages…when i use Mmm-embedyoutube and mmm-iframereload only one video (one module) can be launching (not the same page)…is there a solution to have a delay to start a module or is there a delay to start video when i lauch mm? Sorry for english and have a good day
        chassain 0
        I have now (after new version mm) : audio render error !!!
        An idea !?
          chassain 0
          Hello again,
          i can 't display two videos (with same module or two different modules like MMM-iFrameReload and MMM-SmartWebDisplay …i have always the error about audio render for one video from youtube…
            sdetweil @chassain 0
            @chassain-0 the modules probably don’t support sharing the audio device.
              chassain 0
              thank for your answer
              probably…but it was ok before…and it mention an error about audio but i have no video…
                @chassain-0 said in Autoplay different module not working:
                before when?
                  chassain 0
                  a another life…lol…no, a update and upgrade…not a rpi update…
                  I don’t know if someone have differents modules for video . I’m using MMM-pages to scroll many modules and so 2 videos (not on the same page)
                    @chassain-0 pages just hides and shows modules, doesn’t mean a module is not active in the background…
                    i don’t know how these modules work… but usually they have some startup that acquires resources. once acquired, they don’t let go
                      chassain 0
                      you’re right !
                      i’m going continue my research…thank a lot sdetweil
                        chassain 0
                        last news : sometimes it works after a “pm2 restart mm”
                        have a good day
                          chassain 0
                          pm2 logs
                          Failed to create permanent mapping for memfd region with ID = 207878710
                          0|mm | Failed to regester memfd mempool. Reason: could not attach memfd SHM ID to pipe
                          0|mm | mmap() failed: Cannot allocate memory
                          0|mm | Failed to create permanent mapping for memfd region with ID = 1648210477
                          0|mm | Failed to create permanent mapping for memfd region with ID = 1088771516
                          0|mm | Ignoring received block reference with non-registered memfd ID = 1088771516
                          0|mm | Failed to create permanent mapping for memfd region with ID = 3067665855
                          0|mm | Failed to create permanent mapping for memfd region with ID = 3337011850
                          0|mm | Ignoring received block reference with non-registered memfd ID = 3337011850
