    MMM-AssistantMk2
    421 Posts 61 Posters 761.7k Views 57 Watching
      A Former User @Zoltan
      @Zoltan
      Have you already some external program or script to turn on/off LED strips?
      Z 1 Reply Last reply Reply Quote 0
      • Z Offline
        Zoltan @Guest
        @Sean
        Hi Sean
        I only have ideas that i have seen on other sites where Google home has been installed on a Raspberry. There is a file In the link below at Step 7 that one might used as an idea on how to manage it. Not sure if i am allowed to post links to other sites other than Github and this forum?
        https://medium.com/@kevalpatel2106/turn-your-raspberry-pi-into-homemade-google-home-9e29ad220075
        And then there is also in the middle of the following page a way of doing it with a heading
        “Bonus: Voice Activated GPIO”
        https://www.makeuseof.com/tag/diy-google-home-assistant-raspberry-pi/
        My slate is clean other than this :-(
        ? 1 Reply Last reply Reply Quote -1
          @Zoltan
          To say clear, the job of MMM-AssistantMk2 is understanding your vocal phrase. Turning on/off GPIO thing is others job. If you have or find program/script/command or module which can turn on/off GPIO, MMM-ASSITANTMK2 can translate your vocal phrase to execution trigger for them. So you’d better find one at first.
          • Z Offline
            Zoltan
            @Sean
            I get you with this one. I was just thinking that the moment the google icon on the screen change to any thing else than the google icon (Process or listening or speaking) then one of the GPIO pins can be made high. This will then be the same effect as on the google home with the LEDs on the top
            After the above has been accomplished. Then i would like to explore a recipe that can switch the LED lights on, on a command eg “Light On”, and then later switch them off again when i say “Light off”. This i would use when the mirror is in an dark area and would like to have more light while i groom lol
              mithatcak
              @Sean first of all, thank you for this amazing module! quick question, I’m using ps3 eye which has 4 channel mics but I don’t see any option for channel in the config. It is only present in your MMM-Hotword module. Am I missing something? Thanks!
                A Former User @mithatcak
                @mithatcak
                The node module node-record-lpcm16 - which is used for getting record from mic in MMM-AssistantMk2 - has that feature already (from version 1.0.1 / since Jul. 2019), So if you installed AMK2 nowadays, you can use channel fields also in this module.
                  mithatcak @Guest
                  @Sean thanks! I noticed a typo in MMM-Hotword config documentation it should be channel instead of channels. When I use channels both Hotword and AMK2 won’t record.
                  • O Offline
                    otto
                    @Sean maybe u know what how i can fix the:
                    https://github.com/makepluscode/rpi-tutorial-advanced/issues/12
                    i im following this guide:https://www.youtube.com/watch?v=jrOOBGkOOZQ&feature=youtu.be
                      aunrea
                      I am having an issue with getting this module to work. I get a blank black screen when my magic mirror starts up after I installed this module. I have looked over the config and everything looks fine (no missing commas or brackets). I am not sure what else I can do.
                        sdetweil @aunrea
                        @aunrea start the developers window, with ctrl-shift-i on the keyboard, select the tab marked console at the top of that window, and scroll up to find any errors, usually red text
                          aunrea @sdetweil
                          @sdetweil The only error I got was
                          Moment Timezone has no data for America/New York. See http://momentjs.com/timezone/docs/#/data-loading/.
                          logError @ moment-timezone-with-data.js:472
                            aunrea @aunrea
                            I just realized I forgot to reactivate the module. I quoted it out. Now it runs fine. I don’t know what was the issue before.
                              raedonlpa
                              • O Offline
                                otto
                                i just what to check so if this is right or wrong before i try it:S
                                https://pastebin.com/m4d4nhJH
                                on line 20 i get this: ‘arrow function syntax (=>)’ is only available in ES6 (use ‘esversion: 6’).
                                on line 21 i get this: Missing semicolon.
                                is this anyting i need to change?
                                O S 2 Replies Last reply Reply Quote 0
                                • O Offline
                                  otto @otto
                                  @otto said in MMM-AssistantMk2:
                                  i got this when i was trying to start it:
                                  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                                  Expected directory: electron-v3.1-linux-arm-glibc
                                  Found: [node-v64-linux-arm-glibc]
                                  This problem can often be fixed by running “npm rebuild” on the current system
                                  Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.1-linux-arm-glibc/grpc_node.node’
                                  S ? 2 Replies Last reply Reply Quote 0
                                    sdetweil @otto
                                    @otto your node version is downlevel…
                                    please do
                                    node -v
                                    and
                                    npm -v
                                      sdetweil @otto
                                      @otto after u fix the node problem above, then redo the npm install in the module folder…
                                      if there are still issues, then see the module installation instructions for the steps to resolve this problem
                                      • O Offline
                                        otto @sdetweil
                                        @sdetweil said in MMM-AssistantMk2:
                                        node -v
                                        node:v10.16.3
                                        npm -V 6.11.2
                                          A Former User @otto
                                          This message means you’ve missed/failed electron-rebuild step. read the docs and do that step again carefully.
                                          • O Offline
                                            otto @Guest
                                            @Sean do i need to reinstall it all, or can i just jump to electron-rebuild ?
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 17 / 22
