    MMM-CalendarExt2 month view for Sept not showing all views
    5 Posts 2 Posters 2.0k Views 2 Watching
      aunrea
      I installed the MMM-CalendarExt2 back in August and it was working great. Now that it is September I am having a problem. Now it only shows events up to 3 days after the current day. It shows no events for the rest or the month or the next month. I can’t figure out why it is doing that.
        A Former User @aunrea
        @aunrea
        show me your config.
          aunrea @Guest
          module: ‘MMM-CalendarExt2’,
          updateInterval: 1000 * 60,
          url: “https://calendar.google.com/calendar/ical/.../basic.ics”,
          className: “candace-event”,
          className: “sam-event”,
          className: “liam-event”,
          className: “casey-event”,
          className: “family-event”,
          className: “birthday-event”,
          url: “https://calendar.google.com/calendar/ical/en.usa%23holiday%40group.v.calendar.google.com/public/basic.ics”,
              		views: [
          						mode: "month",
          						name: "Monthly Calendar",
          						position: "middle_center",
          						hideOverflow: false,
          						timeFormat: "h:mm A",
          						mode: "month",
          						fromNow: 1,
          						mode: "month",
          						name: "Next Next Month",
          						fromNow: 2,
          						mode: "month",
          						fromNow: -1,
              		scenes: [
          					views: ["Monthly Calendar"],
          					views: ["Next Month"],
          					views: ["Next Next Month"],
          					views: ["Last Month"],
            @aunrea
            Default items to display in a view is set to 100. Your calendars have more than 100 so some events have been cut off.
            The purpose of this default limitation is for whom has too many events in his calendar from old history.
            Usually, user can select the events by filter and sort feature.
            However in your case, you want total 4 views for 4 months, so it needs to get over 100 events.
            You can set maxItems to bigger number (e.g: 500)
            https://github.com/eouia/MMM-CalendarExt2/wiki/2c.-Configuration:View#common
              module: 'MMM-CalendarExt2',
                defaultSet: {
                  view: {
                    hideOverflow:false,
                    maxItems: 500,  // < ------ THIS VALUE
                views: [
                      mode: "month",
                scenes: [
            You can get this.
              aunrea @Guest
              @Sean Thank you that workd.
