    Email-Mirror
    8 Posts 2 Posters 2.1k Views 2 Watching
      andyyy
      I reverted to a backup of my MM.
      I figured the out the following. The email module works as expected until I install the MMM-GoogleMapsTraffic. In case both the email and the GoogleMaps module are configured in the config.js the email module seems to stop working or hang at “loading”.
        sdetweil @andyyy
        @andyyy open the developers console (using keyboard its ctrl-shift-i) (or npm start dev)…
        select the tab labeled console in that window, and then scroll up to find any errors (usually red text)
        the ‘loading’ is hard coded text the module displays until the api returns data and the info is updated…
        so the api didn’t work
        which should show in the console view
          andyyy
          Does this help? It was printed out in red:
          Uncaught TypeError: console.log is not a function
          at Class.socketNotificationReceived (:8080/modules/email//email.js:34)
          at module.js:246
          at r. (socketclient.js:25)
          at r.emit (index.js:83)
          at r.onevent (index.js:83)
          at r.MMSocket.self.socket.onevent (socketclient.js:19)
          at r.onpacket (index.js:83)
          at r. (index.js:83)
          at r.ondecoded (index.js:83)
            sdetweil @andyyy
            @andyyy said in Email-Mirror:
            /email.js:34
            yes,
            edit the email.js file in modules/email
            and change line 34 from console.log(…), to Log.log(…)
            then restart MagicMirror
              andyyy
              Seems to work. What was/is the issue?
                sdetweil @andyyy
                @andyyy developer coded it wrong.
