    Cannot Get Magic Mirror To Start On Second Screen
    11 Posts 2 Posters 4.7k Views 3 Watching
      sdetweil @djdadevil
      @djdadevil i think extended desktop disables independent display…
      i don’t think u can make MM show up on the right side of a large extended display. without changing the css for screen size
        djdadevil
        That is what the electron option in the config file should do:
        electronOptions: {fullsscreen:false, width:800, x:600}
        But this gave an error when starting the MagicMirror app.
        And i know CSS, there isn’t anything in main.css wich states what the resolution schould be, only that everything must stretch to 100%. Than modules can overlap eachother, but that is what I can edit in the config file and modules own css files.
          sdetweil @djdadevil
          @djdadevil said in Cannot Get Magic Mirror To Start On Second Screen:
          	electronOptions: {fullscreen:false, width:800, x:600},
          two things…
          1- need comma at the end
          2 - u had TWO ‘s’, fullsscreen:false
          changed as above and it sets position correctly
            djdadevil
            Wauw Thanks! Now it work’s! I’ve got the comma, but the two fullscreens i dit not. You really made my day today! Now it’s a window wich I can place on the second screen. Really thank you very much, and don’t know if you are Dutch to (Like Michael Teeuws the creator of this is), but great help man! You solved my problem! Your’s sincerrely!
              sdetweil @djdadevil
              @djdadevil great!.. thanks for the feedback… Not Dutch, US…
              can u mark your issue resolved? click the 3 dots to the right
                djdadevil
                oops, marked the wrong post, but I made it solved, the solution is from “sdetweil” 2 posts above the solved marked message. Thank you very much!
