Unsolved MM won't run, blank screen with cursor showing after updating
@sdetweil still an error, here is the new debug.log:
INFO: pocketsphinx.c(153): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params Current configuration: [NAME] [DEFLT] [VALUE] -agc none none -agcthresh 2.0 2.000000e+00 -allphone -allphone_ci yes yes -alpha 0.97 9.700000e-01 -ascale 20.0 2.000000e+01 -aw 1 1 -backtrace no no -beam 1e-48 1.000000e-48 -bestpath yes yes -bestpathlw 9.5 9.500000e+00 -ceplen 13 13 -cmn live batch -cmninit 40,3,-1 41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17 -compallsen no no -dict modules/MMM-voice/MMM-voice.dic -dictcase no no -dither no no -doublebw no no -ds 1 1 -fdict -feat 1s_c_d_dd 1s_c_d_dd -featparams -fillprob 1e-8 1.000000e-08 -frate 100 100 -fsg -fsgusealtpron yes yes -fsgusefiller yes yes -fwdflat yes yes -fwdflatbeam 1e-64 1.000000e-64 -fwdflatefwid 4 4 -fwdflatlw 8.5 8.500000e+00 -fwdflatsfwin 25 25 -fwdflatwbeam 7e-29 7.000000e-29 -fwdtree yes yes -hmm /usr/local/share/pocketsphinx/model/en-us/en-us -input_endian little little -jsgf -keyphrase -kws -kws_delay 10 10 -kws_plp 1e-1 1.000000e-01 -kws_threshold 1e-30 1.000000e-30 -latsize 5000 5000 -lda -ldadim 0 0 -lifter 0 22 -lm modules/MMM-voice/MMM-voice.lm -lmctl -lmname -logbase 1.0001 1.000100e+00 -logfn -logspec no no -lowerf 133.33334 1.300000e+02 -lpbeam 1e-40 1.000000e-40 -lponlybeam 7e-29 7.000000e-29 -lw 6.5 6.500000e+00 -maxhmmpf 30000 30000 -maxwpf -1 -1 -mdef -mean -mfclogdir -min_endfr 0 0 -mixw -mixwfloor 0.0000001 1.000000e-07 -mllr -mmap yes yes -ncep 13 13 -nfft 512 512 -nfilt 40 25 -nwpen 1.0 1.000000e+00 -pbeam 1e-48 1.000000e-48 -pip 1.0 1.000000e+00 -pl_beam 1e-10 1.000000e-10 -pl_pbeam 1e-10 1.000000e-10 -pl_pip 1.0 1.000000e+00 -pl_weight 3.0 3.000000e+00 -pl_window 5 5 -rawlogdir -remove_dc no no -remove_noise yes yes -remove_silence yes yes -round_filters yes yes -samprate 16000 1.600000e+04 -seed -1 -1 -sendump -senlogdir -senmgau -silprob 0.005 5.000000e-03 -smoothspec no no -svspec 0-12/13-25/26-38 -tmat -tmatfloor 0.0001 1.000000e-04 -topn 4 4 -topn_beam 0 0 -toprule -transform legacy dct -unit_area yes yes -upperf 6855.4976 6.800000e+03 -uw 1.0 1.000000e+00 -vad_postspeech 50 50 -vad_prespeech 20 20 -vad_startspeech 10 10 -vad_threshold 3.0 3.000000e+00 -var -varfloor 0.0001 1.000000e-04 -varnorm no no -verbose no no -warp_params -warp_type inverse_linear inverse_linear -wbeam 7e-29 7.000000e-29 -wip 0.65 6.500000e-01 -wlen 0.025625 2.562500e-02 INFO: feat.c(715): Initializing feature stream to type: '1s_c_d_dd', ceplen=13, CMN='batch', VARNORM='no', AGC='none' INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38 INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices INFO: acmod.c(113): Attempting to use PTM computation module INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means INFO: ms_gauden.c(242): 42 codebook, 3 feature, size: INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances INFO: ms_gauden.c(242): 42 codebook, 3 feature, size: INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(304): 222 variance values floored INFO: ptm_mgau.c(475): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump INFO: ptm_mgau.c(499): BEGIN FILE FORMAT DESCRIPTION INFO: ptm_mgau.c(562): Rows: 128, Columns: 5126 INFO: ptm_mgau.c(594): Using memory-mapped I/O for senones INFO: ptm_mgau.c(837): Maximum top-N: 4 INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0 INFO: dict.c(320): Allocating 4130 * 20 bytes (80 KiB) for word entries INFO: dict.c(333): Reading main dictionary: modules/MMM-voice/MMM-voice.dic INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones INFO: dict.c(336): 29 words read INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones INFO: dict.c(361): 5 words read INFO: dict2pid.c(396): Building PID tables for dictionary INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones INFO: dict2pid.c(132): Allocated 21336 bytes (20 KiB) for word-final triphones INFO: dict2pid.c(196): Allocated 21336 bytes (20 KiB) for single-phone word triphones INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format INFO: ngram_model_trie.c(365): Header doesn't match INFO: ngram_model_trie.c(177): Trying to read LM in arpa format INFO: ngram_model_trie.c(193): LM of order 3 INFO: ngram_model_trie.c(195): #1-grams: 25 INFO: ngram_model_trie.c(195): #2-grams: 46 INFO: ngram_model_trie.c(195): #3-grams: 23 INFO: lm_trie.c(474): Training quantizer INFO: lm_trie.c(482): Building LM trie INFO: ngram_search_fwdtree.c(74): Initializing search tree INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones INFO: ngram_search_fwdtree.c(186): Creating search channels INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157 INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25 INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Sep 29 2019, AT: 15:24:41 Error opening audio device plughw:1 for capture: Invalid argument FATAL: "continuous.c", line 245: Failed to open audio device INFO: pocketsphinx.c(153): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params Current configuration: [NAME] [DEFLT] [VALUE] -agc none none -agcthresh 2.0 2.000000e+00 -allphone -allphone_ci yes yes -alpha 0.97 9.700000e-01 -ascale 20.0 2.000000e+01 -aw 1 1 -backtrace no no -beam 1e-48 1.000000e-48 -bestpath yes yes -bestpathlw 9.5 9.500000e+00 -ceplen 13 13 -cmn live batch -cmninit 40,3,-1 41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17 -compallsen no no -dict modules/MMM-voice/MMM-voice.dic -dictcase no no -dither no no -doublebw no no -ds 1 1 -fdict -feat 1s_c_d_dd 1s_c_d_dd -featparams -fillprob 1e-8 1.000000e-08 -frate 100 100 -fsg -fsgusealtpron yes yes -fsgusefiller yes yes -fwdflat yes yes -fwdflatbeam 1e-64 1.000000e-64 -fwdflatefwid 4 4 -fwdflatlw 8.5 8.500000e+00 -fwdflatsfwin 25 25 -fwdflatwbeam 7e-29 7.000000e-29 -fwdtree yes yes -hmm /usr/local/share/pocketsphinx/model/en-us/en-us -input_endian little little -jsgf -keyphrase -kws -kws_delay 10 10 -kws_plp 1e-1 1.000000e-01 -kws_threshold 1e-30 1.000000e-30 -latsize 5000 5000 -lda -ldadim 0 0 -lifter 0 22 -lm modules/MMM-voice/MMM-voice.lm -lmctl -lmname -logbase 1.0001 1.000100e+00 -logfn -logspec no no -lowerf 133.33334 1.300000e+02 -lpbeam 1e-40 1.000000e-40 -lponlybeam 7e-29 7.000000e-29 -lw 6.5 6.500000e+00 -maxhmmpf 30000 30000 -maxwpf -1 -1 -mdef -mean -mfclogdir -min_endfr 0 0 -mixw -mixwfloor 0.0000001 1.000000e-07 -mllr -mmap yes yes -ncep 13 13 -nfft 512 512 -nfilt 40 25 -nwpen 1.0 1.000000e+00 -pbeam 1e-48 1.000000e-48 -pip 1.0 1.000000e+00 -pl_beam 1e-10 1.000000e-10 -pl_pbeam 1e-10 1.000000e-10 -pl_pip 1.0 1.000000e+00 -pl_weight 3.0 3.000000e+00 -pl_window 5 5 -rawlogdir -remove_dc no no -remove_noise yes yes -remove_silence yes yes -round_filters yes yes -samprate 16000 1.600000e+04 -seed -1 -1 -sendump -senlogdir -senmgau -silprob 0.005 5.000000e-03 -smoothspec no no -svspec 0-12/13-25/26-38 -tmat -tmatfloor 0.0001 1.000000e-04 -topn 4 4 -topn_beam 0 0 -toprule -transform legacy dct -unit_area yes yes -upperf 6855.4976 6.800000e+03 -uw 1.0 1.000000e+00 -vad_postspeech 50 50 -vad_prespeech 20 20 -vad_startspeech 10 10 -vad_threshold 3.0 3.000000e+00 -var -varfloor 0.0001 1.000000e-04 -varnorm no no -verbose no no -warp_params -warp_type inverse_linear inverse_linear -wbeam 7e-29 7.000000e-29 -wip 0.65 6.500000e-01 -wlen 0.025625 2.562500e-02 INFO: feat.c(715): Initializing feature stream to type: '1s_c_d_dd', ceplen=13, CMN='batch', VARNORM='no', AGC='none' INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38 INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices INFO: acmod.c(113): Attempting to use PTM computation module INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means INFO: ms_gauden.c(242): 42 codebook, 3 feature, size: INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances INFO: ms_gauden.c(242): 42 codebook, 3 feature, size: INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(304): 222 variance values floored INFO: ptm_mgau.c(475): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump INFO: ptm_mgau.c(499): BEGIN FILE FORMAT DESCRIPTION INFO: ptm_mgau.c(562): Rows: 128, Columns: 5126 INFO: ptm_mgau.c(594): Using memory-mapped I/O for senones INFO: ptm_mgau.c(837): Maximum top-N: 4 INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0 INFO: dict.c(320): Allocating 4130 * 20 bytes (80 KiB) for word entries INFO: dict.c(333): Reading main dictionary: modules/MMM-voice/MMM-voice.dic INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones INFO: dict.c(336): 29 words read INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones INFO: dict.c(361): 5 words read INFO: dict2pid.c(396): Building PID tables for dictionary INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones INFO: dict2pid.c(132): Allocated 21336 bytes (20 KiB) for word-final triphones INFO: dict2pid.c(196): Allocated 21336 bytes (20 KiB) for single-phone word triphones INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format INFO: ngram_model_trie.c(365): Header doesn't match INFO: ngram_model_trie.c(177): Trying to read LM in arpa format INFO: ngram_model_trie.c(193): LM of order 3 INFO: ngram_model_trie.c(195): #1-grams: 25 INFO: ngram_model_trie.c(195): #2-grams: 46 INFO: ngram_model_trie.c(195): #3-grams: 23 INFO: lm_trie.c(474): Training quantizer INFO: lm_trie.c(482): Building LM trie INFO: ngram_search_fwdtree.c(74): Initializing search tree INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones INFO: ngram_search_fwdtree.c(186): Creating search channels INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157 INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25 INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Sep 29 2019, AT: 15:24:41 Error opening audio device plughw:1,0 for capture: Invalid argument FATAL: "continuous.c", line 245: Failed to open audio device INFO: pocketsphinx.c(153): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params Current configuration: [NAME] [DEFLT] [VALUE] -agc none none -agcthresh 2.0 2.000000e+00 -allphone -allphone_ci yes yes -alpha 0.97 9.700000e-01 -ascale 20.0 2.000000e+01 -aw 1 1 -backtrace no no -beam 1e-48 1.000000e-48 -bestpath yes yes -bestpathlw 9.5 9.500000e+00 -ceplen 13 13 -cmn live batch -cmninit 40,3,-1 41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17 -compallsen no no -dict modules/MMM-voice/MMM-voice.dic -dictcase no no -dither no no -doublebw no no -ds 1 1 -fdict -feat 1s_c_d_dd 1s_c_d_dd -featparams -fillprob 1e-8 1.000000e-08 -frate 100 100 -fsg -fsgusealtpron yes yes -fsgusefiller yes yes -fwdflat yes yes -fwdflatbeam 1e-64 1.000000e-64 -fwdflatefwid 4 4 -fwdflatlw 8.5 8.500000e+00 -fwdflatsfwin 25 25 -fwdflatwbeam 7e-29 7.000000e-29 -fwdtree yes yes -hmm /usr/local/share/pocketsphinx/model/en-us/en-us -input_endian little little -jsgf -keyphrase -kws -kws_delay 10 10 -kws_plp 1e-1 1.000000e-01 -kws_threshold 1e-30 1.000000e-30 -latsize 5000 5000 -lda -ldadim 0 0 -lifter 0 22 -lm modules/MMM-voice/MMM-voice.lm -lmctl -lmname -logbase 1.0001 1.000100e+00 -logfn -logspec no no -lowerf 133.33334 1.300000e+02 -lpbeam 1e-40 1.000000e-40 -lponlybeam 7e-29 7.000000e-29 -lw 6.5 6.500000e+00 -maxhmmpf 30000 30000 -maxwpf -1 -1 -mdef -mean -mfclogdir -min_endfr 0 0 -mixw -mixwfloor 0.0000001 1.000000e-07 -mllr -mmap yes yes -ncep 13 13 -nfft 512 512 -nfilt 40 25 -nwpen 1.0 1.000000e+00 -pbeam 1e-48 1.000000e-48 -pip 1.0 1.000000e+00 -pl_beam 1e-10 1.000000e-10 -pl_pbeam 1e-10 1.000000e-10 -pl_pip 1.0 1.000000e+00 -pl_weight 3.0 3.000000e+00 -pl_window 5 5 -rawlogdir -remove_dc no no -remove_noise yes yes -remove_silence yes yes -round_filters yes yes -samprate 16000 1.600000e+04 -seed -1 -1 -sendump -senlogdir -senmgau -silprob 0.005 5.000000e-03 -smoothspec no no -svspec 0-12/13-25/26-38 -tmat -tmatfloor 0.0001 1.000000e-04 -topn 4 4 -topn_beam 0 0 -toprule -transform legacy dct -unit_area yes yes -upperf 6855.4976 6.800000e+03 -uw 1.0 1.000000e+00 -vad_postspeech 50 50 -vad_prespeech 20 20 -vad_startspeech 10 10 -vad_threshold 3.0 3.000000e+00 -var -varfloor 0.0001 1.000000e-04 -varnorm no no -verbose no no -warp_params -warp_type inverse_linear inverse_linear -wbeam 7e-29 7.000000e-29 -wip 0.65 6.500000e-01 -wlen 0.025625 2.562500e-02 INFO: feat.c(715): Initializing feature stream to type: '1s_c_d_dd', ceplen=13, CMN='batch', VARNORM='no', AGC='none' INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38 INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices INFO: acmod.c(113): Attempting to use PTM computation module INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means INFO: ms_gauden.c(242): 42 codebook, 3 feature, size: INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances INFO: ms_gauden.c(242): 42 codebook, 3 feature, size: INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(304): 222 variance values floored INFO: ptm_mgau.c(475): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump INFO: ptm_mgau.c(499): BEGIN FILE FORMAT DESCRIPTION INFO: ptm_mgau.c(562): Rows: 128, Columns: 5126 INFO: ptm_mgau.c(594): Using memory-mapped I/O for senones INFO: ptm_mgau.c(837): Maximum top-N: 4 INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0 INFO: dict.c(320): Allocating 4130 * 20 bytes (80 KiB) for word entries INFO: dict.c(333): Reading main dictionary: modules/MMM-voice/MMM-voice.dic INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones INFO: dict.c(336): 29 words read INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones INFO: dict.c(361): 5 words read INFO: dict2pid.c(396): Building PID tables for dictionary INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones INFO: dict2pid.c(132): Allocated 21336 bytes (20 KiB) for word-final triphones INFO: dict2pid.c(196): Allocated 21336 bytes (20 KiB) for single-phone word triphones INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format INFO: ngram_model_trie.c(365): Header doesn't match INFO: ngram_model_trie.c(177): Trying to read LM in arpa format INFO: ngram_model_trie.c(193): LM of order 3 INFO: ngram_model_trie.c(195): #1-grams: 25 INFO: ngram_model_trie.c(195): #2-grams: 46 INFO: ngram_model_trie.c(195): #3-grams: 23 INFO: lm_trie.c(474): Training quantizer INFO: lm_trie.c(482): Building LM trie INFO: ngram_search_fwdtree.c(74): Initializing search tree INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones INFO: ngram_search_fwdtree.c(186): Creating search channels INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157 INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25 INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Sep 29 2019, AT: 15:24:41 Error opening audio device plughw:1,0 for capture: Invalid argument FATAL: "continuous.c", line 245: Failed to open audio device INFO: pocketsphinx.c(153): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params Current configuration: [NAME] [DEFLT] [VALUE] -agc none none -agcthresh 2.0 2.000000e+00 -allphone -allphone_ci yes yes -alpha 0.97 9.700000e-01 -ascale 20.0 2.000000e+01 -aw 1 1 -backtrace no no -beam 1e-48 1.000000e-48 -bestpath yes yes -bestpathlw 9.5 9.500000e+00 -ceplen 13 13 -cmn live batch -cmninit 40,3,-1 41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17 -compallsen no no -dict modules/MMM-voice/MMM-voice.dic -dictcase no no -dither no no -doublebw no no -ds 1 1 -fdict -feat 1s_c_d_dd 1s_c_d_dd -featparams -fillprob 1e-8 1.000000e-08 -frate 100 100 -fsg -fsgusealtpron yes yes -fsgusefiller yes yes -fwdflat yes yes -fwdflatbeam 1e-64 1.000000e-64 -fwdflatefwid 4 4 -fwdflatlw 8.5 8.500000e+00 -fwdflatsfwin 25 25 -fwdflatwbeam 7e-29 7.000000e-29 -fwdtree yes yes -hmm /usr/local/share/pocketsphinx/model/en-us/en-us -input_endian little little -jsgf -keyphrase -kws -kws_delay 10 10 -kws_plp 1e-1 1.000000e-01 -kws_threshold 1e-30 1.000000e-30 -latsize 5000 5000 -lda -ldadim 0 0 -lifter 0 22 -lm modules/MMM-voice/MMM-voice.lm -lmctl -lmname -logbase 1.0001 1.000100e+00 -logfn -logspec no no -lowerf 133.33334 1.300000e+02 -lpbeam 1e-40 1.000000e-40 -lponlybeam 7e-29 7.000000e-29 -lw 6.5 6.500000e+00 -maxhmmpf 30000 30000 -maxwpf -1 -1 -mdef -mean -mfclogdir -min_endfr 0 0 -mixw -mixwfloor 0.0000001 1.000000e-07 -mllr -mmap yes yes -ncep 13 13 -nfft 512 512 -nfilt 40 25 -nwpen 1.0 1.000000e+00 -pbeam 1e-48 1.000000e-48 -pip 1.0 1.000000e+00 -pl_beam 1e-10 1.000000e-10 -pl_pbeam 1e-10 1.000000e-10 -pl_pip 1.0 1.000000e+00 -pl_weight 3.0 3.000000e+00 -pl_window 5 5 -rawlogdir -remove_dc no no -remove_noise yes yes -remove_silence yes yes -round_filters yes yes -samprate 16000 1.600000e+04 -seed -1 -1 -sendump -senlogdir -senmgau -silprob 0.005 5.000000e-03 -smoothspec no no -svspec 0-12/13-25/26-38 -tmat -tmatfloor 0.0001 1.000000e-04 -topn 4 4 -topn_beam 0 0 -toprule -transform legacy dct -unit_area yes yes -upperf 6855.4976 6.800000e+03 -uw 1.0 1.000000e+00 -vad_postspeech 50 50 -vad_prespeech 20 20 -vad_startspeech 10 10 -vad_threshold 3.0 3.000000e+00 -var -varfloor 0.0001 1.000000e-04 -varnorm no no -verbose no no -warp_params -warp_type inverse_linear inverse_linear -wbeam 7e-29 7.000000e-29 -wip 0.65 6.500000e-01 -wlen 0.025625 2.562500e-02 INFO: feat.c(715): Initializing feature stream to type: '1s_c_d_dd', ceplen=13, CMN='batch', VARNORM='no', AGC='none' INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38 INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices INFO: acmod.c(113): Attempting to use PTM computation module INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means INFO: ms_gauden.c(242): 42 codebook, 3 feature, size: INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances INFO: ms_gauden.c(242): 42 codebook, 3 feature, size: INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(244): 128x13 INFO: ms_gauden.c(304): 222 variance values floored INFO: ptm_mgau.c(475): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump INFO: ptm_mgau.c(499): BEGIN FILE FORMAT DESCRIPTION INFO: ptm_mgau.c(562): Rows: 128, Columns: 5126 INFO: ptm_mgau.c(594): Using memory-mapped I/O for senones INFO: ptm_mgau.c(837): Maximum top-N: 4 INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0 INFO: dict.c(320): Allocating 4130 * 20 bytes (80 KiB) for word entries INFO: dict.c(333): Reading main dictionary: modules/MMM-voice/MMM-voice.dic INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones INFO: dict.c(336): 29 words read INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones INFO: dict.c(361): 5 words read INFO: dict2pid.c(396): Building PID tables for dictionary INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones INFO: dict2pid.c(132): Allocated 21336 bytes (20 KiB) for word-final triphones INFO: dict2pid.c(196): Allocated 21336 bytes (20 KiB) for single-phone word triphones INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format INFO: ngram_model_trie.c(365): Header doesn't match INFO: ngram_model_trie.c(177): Trying to read LM in arpa format INFO: ngram_model_trie.c(193): LM of order 3 INFO: ngram_model_trie.c(195): #1-grams: 25 INFO: ngram_model_trie.c(195): #2-grams: 46 INFO: ngram_model_trie.c(195): #3-grams: 23 INFO: lm_trie.c(474): Training quantizer INFO: lm_trie.c(482): Building LM trie INFO: ngram_search_fwdtree.c(74): Initializing search tree INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones INFO: ngram_search_fwdtree.c(186): Creating search channels INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157 INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25 INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Sep 29 2019, AT: 15:24:41 Error opening audio device hw:1,0 for capture: Invalid argument FATAL: "continuous.c", line 245: Failed to open audio device
@jmartin1009 yeh. Fix not published.
Can u try the arecord -D hw:1,0 test.wav
@sdetweil i tried that but with duration 10, then did aplay test.wav and it said no file or directory, so it may be my mic or something, but it shows up in arecord -l.
@jmartin1009 make sure the filename was right.
ls
pi@raspberrypi:~ $ arecord -D hw:1,0 --duration=10 test.wav Recording WAVE 'test.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono arecord: set_params:1299: Sample format non available Available formats: - S16_LE pi@raspberrypi:~ $ aplay test.wav test.wav: No such file or directory pi@raspberrypi:~ $
@jmartin1009 ok. Can’t help.mic not working.
But plughw vs hw
Go to MagicMirror/modules/mmm-voice/node_modules/pocketsphinx_continuous
Edit index J’s and change ‘plughw’ to ‘hw’
Only one place.
@sdetweil done, will try now.
@sdetweil same error, should a corsair headset mic work to check it? I’m currently using a blue yeti but the connection is a bit iffy, but it appears to be working. Just don’t know what the issue is here.
@jmartin1009 but it should say hw:1,0 can’t be opened
@sdetweil what? I’m not sure what you’re referring to
