    Maximizing Screen Use with MMM-CalendarExt2 and Custom.css
    9 Posts 2 Posters 3.5k Views 2 Watching
      A Former User @CliffordW
      @CliffordW
      use fullscreen_below or above.
        CliffordW @Guest
        @Sean Thanks for your reply Sean. I’ve tried both fullscreen_below and fullscreen_above and both have an identical look. Any other suggestions how to remove the blank margin at the top?
        If I change slotcount from 3 to 4, the first couple of lines from the top are chopped off.
        		module: 'MMM-CalendarExt2',
        			calendars : [
        				name: "BNC Rentals",
        				// url: "https://calendar.google.com/calendar/ical/en.canadian%23holiday%40group.v.calendar.google.com/public/basic.ics",
        				url: "https://calendar.google.com/calendar/ical/rentalsthebnc%40gmail.com/private-xxxxxxxxxxxxx/basic.ics"
        			views: [
        				title: "BNC Rentals",
        				mode: "week",
        				position: "fullscreen_below",
        				calendars: ["BNC Rentals"],
        				useEventTimeRelative: true,
        				slotCount: 3,
        				slotTitle: "",
        				slotMaxHeight: "150px",
        				slotSubTitle: "",
        				slotTitleFormat: "MMM:DD",
        				slotSubTitleFormat: "MMM:DD",
        				subslotTitleFormat: "MMM:DD",
        				maxItems: 200,
        				hideOverflow: false,
        				relativeFormat: {
        					passed: "ended %ENDFROMNOW%",
        					current: "ends %ENDFROMNOW%",
        					future: "starts %STARTFROMNOW% (%DURATION%)"
        			scenes: [
        				views: [],
          @CliffordW
          week and month views are somewhat huge. You can adjust size by CSS or set slotMaxHeight to smaller values.
            CliffordW @Guest
            @Sean I’ve been looking at custom.css, and I admit it’s very new to me. Which value should I try changing to reduce the upper margin?
              @CliffordW
              By default, in fullscreen position, month and week view will be positioned to the bottom of the screen.
              MMM-CalendarExt2.css
              .fullscreen .CX2 { /* when the view is located on `fullscreen_below` or `fullscreen_above` */
                position:fixed;
                bottom: 10px;
                margin: 20px;
                width:calc(100vw - 40px);
              So you can redefine this section in your css/custom.css but not recommended.
                @CliffordW
                If what you want is just enlarge the height, set slotMaxHeight to bigger value.
                  CliffordW @Guest
                  @Sean I’d like to be able show 4 rows instead of 3. There is a considerable amount of unused space at the top of the monitor, so I’d like to reduce (remove) this margin at the top.
                  I hope I’m making sense.
                    CliffordW @Guest
                    @Sean Thanks for the guidance. I missed it the first time. Considering this pi is a single function, I might just give this a shot.
