Maximizing Screen Use with MMM-CalendarExt2 and Custom.css
I am a complete noob with css, so please be kind. I am trying to move the calendar entries up to possibly show a fourth row. What I have so far is this:
My custom.css file looks like:
- Magic Mirror *
- Custom CSS *
* - By Michael Teeuw http://michaelteeuw.nl *
- MIT Licensed. *
* - Add any custom CSS below. *
- Changes to this files will be ignored by GIT. *
body {
margin: 40px;
height: calc(100% - 100px);
width: calc(100% - 30px);
}Any changes I make to height/width don’t seem to affect the calendar display. Can someone give me some guidance how I maximize the screen usage?
@CliffordW
use fullscreen_below or above. -
@Sean Thanks for your reply Sean. I’ve tried both fullscreen_below and fullscreen_above and both have an identical look. Any other suggestions how to remove the blank margin at the top?
If I change slotcount from 3 to 4, the first couple of lines from the top are chopped off.
```modules: [
{ module: 'MMM-CalendarExt2', config: { calendars : [ { name: "BNC Rentals", // url: "https://calendar.google.com/calendar/ical/en.canadian%23holiday%40group.v.calendar.google.com/public/basic.ics", url: "https://calendar.google.com/calendar/ical/rentalsthebnc%40gmail.com/private-xxxxxxxxxxxxx/basic.ics" }, ], views: [ { Name: "Rentals", title: "BNC Rentals", mode: "week", position: "fullscreen_below", calendars: ["BNC Rentals"], useEventTimeRelative: true, slotCount: 3, slotTitle: "", slotMaxHeight: "150px", slotSubTitle: "", slotTitleFormat: "MMM:DD", slotSubTitleFormat: "MMM:DD", subslotTitleFormat: "MMM:DD", maxItems: 200, hideOverflow: false, relativeFormat: { passed: "ended %ENDFROMNOW%", current: "ends %ENDFROMNOW%", future: "starts %STARTFROMNOW% (%DURATION%)" }, } ], scenes: [ { name: "DEFAULT", views: [], }, ], } } ]};
@CliffordW
weekandmonthviews are somewhat huge. You can adjust size by CSS or setslotMaxHeightto smaller values. -
@Sean I’ve been looking at custom.css, and I admit it’s very new to me. Which value should I try changing to reduce the upper margin?
@CliffordW
By default, infullscreenposition,monthandweekview will be positioned to the bottom of the screen.MMM-CalendarExt2.css
.fullscreen .CX2 { /* when the view is located on `fullscreen_below` or `fullscreen_above` */ position:fixed; bottom: 10px; margin: 20px; width:calc(100vw - 40px); }So you can redefine this section in your
css/custom.cssbut not recommended. -
@CliffordW
If what you want is just enlarge the height, setslotMaxHeightto bigger value. -
@Sean I’d like to be able show 4 rows instead of 3. There is a considerable amount of unused space at the top of the monitor, so I’d like to reduce (remove) this margin at the top.
I hope I’m making sense.
@Sean Thanks for the guidance. I missed it the first time. Considering this pi is a single function, I might just give this a shot.
