    config error (edited config)
    5 Posts 2 Posters 1.5k Views 2 Watching
      daltonlupu
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	//address: "localhost", // Address to listen on, can be:
      	address : '0.0.0.0',
      	port: 8080,
      	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
      	ipWhitelist: [], // Set [] to allow all IP addresses
      	language: "en",
      	timeFormat: 12,
      	units: "imperial",
      			module: "clock",
      			position: "top_center"
      			header: "US Holidays",
      			position: "top_center",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
          module: 'MMM-Remote-Control'
           , position: 'bottom_left'
              customCommand: {},  // Optional, See "Using Custom Commands" below
              customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
              showModuleApiMenu: true, // Optional, Enable the Module Controls menu
              apiKey: "",         // Optional, See API/README.md for details
      			module: "currentweather",
      				locationID: '",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: ""
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: ""
      module: 'MMM-NowPlayingOnSpotify',
      					  position: 'top_center',
      					    clientID: '',
      					    clientSecret: '',
      					    accessToken: '',
      					    refreshToken:
      • buzzkcB Offline
        buzzkc
        You’re missing comma after position: ‘bottom_left’ on MMM-RemoteControl.
        Can run the following from your MagicMirror root folder to check your config:
        npm run config:check
        Darren
        My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
        D 2 Replies Last reply Reply Quote 2
          daltonlupu @buzzkc
          @buzzkc okay I’ll try that later and let you know what happens, thank you!
            daltonlupu @buzzkc
            @buzzkc it worked thanks man, a comma can change everything
            • buzzkcB Offline
              buzzkc
              No worries, glad I could help. :-)
              Darren
