Solved Error : cannot find module "rrule"
@JohnB7777 said in Error : cannot find module "rrule":
I removed the module
removed what module?
do this
cd ~MagicMirror npm install rrule@2.6.2
@sdetweil I removed the calendar module, the one you help me to reinstall :)
And this command didn’t work, but I have the same errors when I do “npm install” on the MagicMirror folder :
pi@raspberrypi:~/MagicMirror $ npm install rrule@2.6.2 npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/aproba npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/are-we-there-yet/node_modules/isarray npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/are-we-there-yet/node_modules/process-nextick-args npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/are-we-there-yet/node_modules/string_decoder npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/are-we-there-yet/node_modules/readable-stream npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/chownr npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cli-spinners npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/ansi-regex npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/ansi-styles npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/is-fullwidth-code-point npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/strip-ansi npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/clone npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/console-control-strings npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/defaults npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/delegates npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/are-we-there-yet npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/detect-libc npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules/colors npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules/jsonfile npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules/fs-extra npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules/ms npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules/debug npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/emoji-regex npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/string-width npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/wrap-ansi npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/has-unicode npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mem/node_modules/mimic-fn npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/minipass/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/node-abi npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/node-gyp/node_modules/semver npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/ansi-regex npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/ansi-styles npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/has-flag npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/strip-ansi npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/supports-color npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/chalk npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/log-symbols npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/os-homedir npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/os-locale/node_modules/invert-kv npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/os-locale/node_modules/lcid npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/osenv npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/p-defer npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/map-age-cleaner npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/p-finally npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/p-is-promise npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mem npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/p-try npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/npm-run-path npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/pump npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/get-stream npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/spawn-rx npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/strip-eof npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/tar/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/wcwidth npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/execa npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/os-locale npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/which-module npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/wide-align npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/gauge npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/npmlog npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yallist npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/minipass npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/fs-minipass npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/minizlib npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/tar npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/node-gyp npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs-parser/node_modules/camelcase npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs-parser npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/ansi-regex npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/get-caller-file npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/is-fullwidth-code-point npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/p-limit npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/p-locate npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/path-exists npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/locate-path npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/find-up npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/require-main-filename npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/strip-ansi npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/string-width npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/y18n npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/are-we-there-yet/node_modules npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mem/node_modules npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/minipass/node_modules npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/node-gyp/node_modules npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/os-locale/node_modules npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/tar/node_modules npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs-parser/node_modules npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules npm WARN grunt-yamllint@0.3.0 requires a peer of grunt@>=1.0.1 but none is installed. You must install peer dependencies yourself. npm ERR! path /home/pi/MagicMirror/node_modules/aproba npm ERR! code EACCES npm ERR! errno -13 npm ERR! syscall access npm ERR! Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/aproba' npm ERR! { [Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/aproba'] npm ERR! stack: npm ERR! 'Error: EACCES: permission denied, access \'/home/pi/MagicMirror/node_modules/aproba\'', npm ERR! errno: -13, npm ERR! code: 'EACCES', npm ERR! syscall: 'access', npm ERR! path: '/home/pi/MagicMirror/node_modules/aproba' } npm ERR! npm ERR! The operation was rejected by your operating system. npm ERR! It is likely you do not have the permissions to access this file as the current user npm ERR! npm ERR! If you believe this might be a permissions issue, please double-check the npm ERR! permissions of the file and its containing directories, or try running npm ERR! the command again as root/Administrator (though this is not recommended). npm ERR! A complete log of this run can be found in: npm ``` ERR! /home/pi/.npm/_logs/2019-10-08T13_03_57_910Z-debug.log
@JohnB7777 yeh, you used sudo somehwere… NEVER use sudo (except when told, for specific things)
do this
cd ~ sudo chown -R pi MagicMirror
then redo the command above.
why would you delete a module?
@sdetweil I deleted this module because I though it was the cause of the error.
I tried what you said and it worked but when I start the mirror, there is another error :
> magicmirror@2.9.0 start /home/pi/MagicMirror > sh run-start.sh Starting MagicMirror: v2.9.0 Loading config ... Loading module helpers ... No helper found for module: alert. No helper found for module: clock. Initializing new module helper ... Module helper loaded: calendar No helper found for module: currentweather. No helper found for module: weatherforecast. No helper found for module: MMM-AirQuality. WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'async' Loading module helpers ... No helper found for module: alert. No helper found for module: clock. Initializing new module helper ... Module helper loaded: calendar No helper found for module: currentweather. No helper found for module: weatherforecast. No helper found for module: MMM-AirQuality. App threw an error during load Error: Cannot find module 'async' at Module._resolveFilename (internal/modules/cjs/loader.js:602:15) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12) at Function.Module._load (internal/modules/cjs/loader.js:528:25) at Module.require (internal/modules/cjs/loader.js:658:17) at require (internal/modules/cjs/helpers.js:20:18) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Tools/node_helper.js:9:13) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Tools/node_helper.js:239:3) at Module._compile (internal/modules/cjs/loader.js:711:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10) at Module.load (internal/modules/cjs/loader.js:620:32) Whoops! There was an uncaught exception... { Error: Cannot find module 'async' at Module._resolveFilename (internal/modules/cjs/loader.js:602:15) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12) at Function.Module._load (internal/modules/cjs/loader.js:528:25) at Module.require (internal/modules/cjs/loader.js:658:17) at require (internal/modules/cjs/helpers.js:20:18) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Tools/node_helper.js:9:13) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Tools/node_helper.js:239:3) at Module._compile (internal/modules/cjs/loader.js:711:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10) at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' } MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues Launching application. ^Z [2]+ Stoppé npm start
MMM-Tools
do this
cd MagicMirror npm install async
then restart mirror
@sdetweil Ok, it works but I have another error that doesn’t prevent the start of the mirror.
Whoops! There was an uncaught exception... { Error: listen EADDRINUSE 127.0.0.1:8080 at Server.setupListenHandle [as _listen2] (net.js:1330:14) at listenInCluster (net.js:1378:12) at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7) at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10) errno: 'EADDRINUSE', code: 'EADDRINUSE', syscall: 'listen', address: '127.0.0.1', port: 8080 } MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues Launching application.
@sdetweil Yes, I use pm2 to start and stop the mirror but I use npm start to see the errors.
@sdetweil Oh, yes, I understand what you wanted to say.
That was the cause of the error.Now, the problem is solved, and thank you very much for your (very quick) help ! :D
