Error : cannot find module "rrule"
13 Posts 3 Posters 2.8k Views 3 Watching
    JohnB7777
    I have a big problem with the calendar default module.
    Since the last magic mirror update, the module blocks the launch of the mirror.
    > magicmirror@2.9.0 start /home/pi/MagicMirror
    > sh run-start.sh
    Starting MagicMirror: v2.9.0
    Loading config ...
    Loading module helpers ...
    WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'rrule'
    App threw an error during load
        at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
        at Function.Module._load (internal/modules/cjs/loader.js:528:25)
        at Module.require (internal/modules/cjs/loader.js:658:17)
        at require (internal/modules/cjs/helpers.js:20:18)
        at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:27:13)
        at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:68:3)
        at Module._compile (internal/modules/cjs/loader.js:711:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
        at Module.load (internal/modules/cjs/loader.js:620:32)
    { Error: Cannot find module 'rrule'
        at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
    Launching application.
    I don’t understand what is wrong.
    I removed the module and I reinstall it but the problem still there.
    Thanks for your help ! :)
    S 1 Reply Last reply Oct 8, 2019, 12:57 PM Reply Quote 0
      sdetweil @JohnB7777
      @JohnB7777 said in Error : cannot find module "rrule":
      removed what module?
      do this
      cd ~MagicMirror
      npm install rrule@2.6.2
      J 1 Reply Last reply Oct 8, 2019, 1:07 PM Reply Quote 0
        JohnB7777 @sdetweil
        @sdetweil I removed the calendar module, the one you help me to reinstall :)
        And this command didn’t work, but I have the same errors when I do “npm install” on the MagicMirror folder :
        pi@raspberrypi:~/MagicMirror $ npm install rrule@2.6.2
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/aproba
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/are-we-there-yet/node_modules/isarray
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/are-we-there-yet/node_modules/process-nextick-args
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/are-we-there-yet/node_modules/string_decoder
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/are-we-there-yet/node_modules/readable-stream
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/chownr
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cli-spinners
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/ansi-regex
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/ansi-styles
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/is-fullwidth-code-point
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/strip-ansi
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/clone
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/console-control-strings
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/defaults
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/delegates
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/detect-libc
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules/colors
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules/jsonfile
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules/fs-extra
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules/ms
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules/debug
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/emoji-regex
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/string-width
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/wrap-ansi
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/has-unicode
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mem/node_modules/mimic-fn
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/minipass/node_modules/safe-buffer
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/node-abi
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/node-gyp/node_modules/semver
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/ansi-regex
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/ansi-styles
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/has-flag
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/strip-ansi
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/supports-color
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/chalk
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/log-symbols
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/os-homedir
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/os-locale/node_modules/invert-kv
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/os-locale/node_modules/lcid
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/osenv
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/p-defer
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/map-age-cleaner
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/p-finally
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/p-is-promise
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/p-try
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/npm-run-path
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/pump
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/get-stream
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/spawn-rx
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/strip-eof
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/tar/node_modules/safe-buffer
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/wcwidth
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/execa
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/which-module
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/wide-align
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/gauge
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/npmlog
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yallist
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/fs-minipass
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/minizlib
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs-parser/node_modules/camelcase
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/ansi-regex
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/get-caller-file
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/is-fullwidth-code-point
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/p-limit
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/p-locate
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/path-exists
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/locate-path
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/find-up
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/require-main-filename
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/strip-ansi
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/string-width
        npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/y18n
        npm WARN grunt-yamllint@0.3.0 requires a peer of grunt@>=1.0.1 but none is installed. You must install peer dependencies yourself.
        npm ERR! path /home/pi/MagicMirror/node_modules/aproba
        npm ERR! code EACCES
        npm ERR! errno -13
        npm ERR! syscall access
        npm ERR! Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/aproba'
        npm ERR!  { [Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/aproba']
        npm ERR!   stack:
        npm ERR!    'Error: EACCES: permission denied, access \'/home/pi/MagicMirror/node_modules/aproba\'',
        npm ERR!   errno: -13,
        npm ERR!   code: 'EACCES',
        npm ERR!   syscall: 'access',
        npm ERR!   path: '/home/pi/MagicMirror/node_modules/aproba' }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator (though this is not recommended).
        npm
        ``` ERR!     /home/pi/.npm/_logs/2019-10-08T13_03_57_910Z-debug.log
        S 1 Reply Last reply Oct 8, 2019, 1:09 PM Reply Quote 0
          sdetweil @JohnB7777
          @JohnB7777 yeh, you used sudo somehwere… NEVER use sudo (except when told, for specific things)
          do this
          cd ~
          sudo chown -R pi MagicMirror
          then redo the command above.
          why would you delete a module?
          J 1 Reply Last reply Oct 8, 2019, 1:32 PM Reply Quote 0
            JohnB7777 @sdetweil
            @sdetweil I deleted this module because I though it was the cause of the error.
            I tried what you said and it worked but when I start the mirror, there is another error :
            > sh run-start.sh
            Loading config ...
            No helper found for module: MMM-AirQuality.
            WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'async'
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Tools/node_helper.js:9:13)
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Tools/node_helper.js:239:3)
            { Error: Cannot find module 'async'
            ^Z
            [2]+  Stoppé                 npm start
            S 1 Reply Last reply Oct 8, 2019, 1:37 PM Reply Quote 0
              sdetweil @JohnB7777
              MMM-Tools
              do this
              cd MagicMirror
              npm install async
              then restart mirror
              J 1 Reply Last reply Oct 8, 2019, 1:54 PM Reply Quote 0
                JohnB7777 @sdetweil
                @sdetweil Ok, it works but I have another error that doesn’t prevent the start of the mirror.
                { Error: listen EADDRINUSE 127.0.0.1:8080
                    at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                    at listenInCluster (net.js:1378:12)
                    at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
                    at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
                  errno: 'EADDRINUSE',
                  code: 'EADDRINUSE',
                  syscall: 'listen',
                  address: '127.0.0.1',
                  port: 8080 }
                S 1 Reply Last reply Oct 8, 2019, 1:56 PM Reply Quote 0
                  sdetweil @JohnB7777
                  @JohnB7777
                  already have MagicMirror running
                  pm2 stop 0
                  pm2 start 0
                  J 1 Reply Last reply Oct 8, 2019, 2:03 PM Reply Quote 0
                    JohnB7777 @sdetweil
                    @sdetweil Yes, I use pm2 to start and stop the mirror but I use npm start to see the errors.
                    S 1 Reply Last reply Oct 8, 2019, 2:04 PM Reply Quote 0
                      sdetweil @JohnB7777
                      @JohnB7777
                      you have two instances running…
                      npm start is what pm2 does for you under the covers
                      J L 2 Replies Last reply Oct 8, 2019, 2:05 PM Reply Quote 0
