Solved Update to v2.9.0 fail
@bdream said in Update to v2.9.0 fail:
custom.css is realy touched by me but should not be affected by updates I thougt.
prior to this release, custom.css was considered a core file, and was overlayed on updates.
this release puts in a fix for that… but I save/restore it anyhowstash is a place where you can hold modified files, but continue on with your work.
it requires some setup, but my script is supposed to go that for you -
pi@MagicMirror:~/MagicMirror $ bash -c -i "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply doing test run = false update log will be in /home/pi/MagicMirror/installers/upgrade.log saving custom.css upgrading from version 2.8.0 to 2.9.0 fetching latest revisions there were merge errors error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor Sie mergen. Abbruch Aktualisiere a31546b..500147e you should examine and resolve them using the command git log --oneline --decorate a31546b (grafted, HEAD -> master, tag: v2.8.0) Merge pull request #1717 from MichMich/develop restoring custom.css
upgrade.log
Upgrade started - Mi Okt 16 17:12:12 CEST 2019 user requested to apply changes doing test run = false saving custom.css not english or locale not set, set git alias alias egrep='egrep --color=auto' alias fgrep='fgrep --color=auto' alias git='LANGUAGE=en_US.UTF-8 git' alias grep='grep --color=auto' alias ls='ls --color=auto' remote name = origin upgrading from version 2.8.0 to 2.9.0 fetching latest revisions current branch = master Auf Branch master Ihr Branch ist 2715 Commits hinter 'origin/master', und kann vorgespult werden. (benutzen Sie "git pull", um Ihren lokalen Branch zu aktualisieren) Änderungen, die nicht zum Commit vorgemerkt sind: (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken) (benutzen Sie "git checkout -- <Datei>...", um die Änderungen im Arbeitsverzeichnis zu verwerfen) geändert: css/custom.css geändert: package-lock.json Unversionierte Dateien: (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken) %logfile core css/save_custom.css installers/dumpactivemodules.js installers/pm2_MagicMirror_new.json installers/stashed_files mm.sh nohup.out keine Änderungen zum Commit vorgemerkt (benutzen Sie "git add" und/oder "git commit -a") no files different from github version test merge result rc='' , if empty, no conflicts executing merge, apply specified merge result rc= 1 error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor Sie mergen. Abbruch Aktualisiere a31546b..500147e there were merge errors you should examine and resolve them using the command git log --oneline --decorate a31546b (grafted, HEAD -> master, tag: v2.8.0) Merge pull request #1717 from MichMich/develop restoring custom.css removing git alias Upgrade ended - Mi Okt 16 17:12:14 CEST 2019
pi@MagicMirror:~/MagicMirror $ cat ~/.bashrc # ~/.bashrc: executed by bash(1) for non-login shells. # see /usr/share/doc/bash/examples/startup-files (in the package bash-doc) # for examples # If not running interactively, don't do anything case $- in *i*) ;; *) return;; esac # don't put duplicate lines or lines starting with space in the history. # See bash(1) for more options HISTCONTROL=ignoreboth # append to the history file, don't overwrite it shopt -s histappend # for setting history length see HISTSIZE and HISTFILESIZE in bash(1) HISTSIZE=1000 HISTFILESIZE=2000 # check the window size after each command and, if necessary, # update the values of LINES and COLUMNS. shopt -s checkwinsize # If set, the pattern "**" used in a pathname expansion context will # match all files and zero or more directories and subdirectories. #shopt -s globstar # make less more friendly for non-text input files, see lesspipe(1) #[ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)" # set variable identifying the chroot you work in (used in the prompt below) if [ -z "${debian_chroot:-}" ] && [ -r /etc/debian_chroot ]; then debian_chroot=$(cat /etc/debian_chroot) fi # set a fancy prompt (non-color, unless we know we "want" color) case "$TERM" in xterm-color|*-256color) color_prompt=yes;; esac # uncomment for a colored prompt, if the terminal has the capability; turned # off by default to not distract the user: the focus in a terminal window # should be on the output of commands, not on the prompt force_color_prompt=yes if [ -n "$force_color_prompt" ]; then if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then # We have color support; assume it's compliant with Ecma-48 # (ISO/IEC-6429). (Lack of such support is extremely rare, and such # a case would tend to support setf rather than setaf.) color_prompt=yes else color_prompt= fi fi if [ "$color_prompt" = yes ]; then PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w \$\[\033[00m\] ' else PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ ' fi unset color_prompt force_color_prompt # If this is an xterm set the title to user@host:dir case "$TERM" in xterm*|rxvt*) PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1" ;; *) ;; esac # enable color support of ls and also add handy aliases if [ -x /usr/bin/dircolors ]; then test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)" alias ls='ls --color=auto' #alias dir='dir --color=auto' #alias vdir='vdir --color=auto' alias grep='grep --color=auto' alias fgrep='fgrep --color=auto' alias egrep='egrep --color=auto' fi # colored GCC warnings and errors #export GCC_COLORS='error=01;31:warning=01;35:note=01;36:caret=01;32:locus=01:quote=01' # some more ls aliases #alias ll='ls -l' #alias la='ls -A' #alias l='ls -CF' # Alias definitions. # You may want to put all your additions into a separate file like # ~/.bash_aliases, instead of adding them here directly. # See /usr/share/doc/bash-doc/examples in the bash-doc package. if [ -f ~/.bash_aliases ]; then . ~/.bash_aliases fi # enable programmable completion features (you don't need to enable # this, if it's already enabled in /etc/bash.bashrc and /etc/profile # sources /etc/bash.bashrc). if ! shopt -oq posix; then if [ -f /usr/share/bash-completion/bash_completion ]; then . /usr/share/bash-completion/bash_completion elif [ -f /etc/bash_completion ]; then . /etc/bash_completion fi fi
@bdream what a battle!
in the short term, erase package-lock.json
also show me output of
echo $LC_ALL
@sdetweil said in Update to v2.9.0 fail:
done!
seems update is working now :grinning_face:pi@MagicMirror:~/MagicMirror $ bash -c -i "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply doing test run = false update log will be in /home/pi/MagicMirror/installers/upgrade.log saving custom.css upgrading from version 2.8.0 to 2.9.0 fetching latest revisions updating MagicMirror runtime, please wait > electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron > node install.js Downloading tmp-5207-1-SHASUMS256.txt-3.0.13 [============================================>] 100.0% of 4.79 kB (4.79 kB/s) > magicmirror@2.9.0 install /home/pi/MagicMirror > cd vendor && npm install npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) audited 220 packages in 12.241s found 5 vulnerabilities (4 low, 1 high) run `npm audit fix` to fix them, or `npm audit` for details > magicmirror@2.9.0 postinstall /home/pi/MagicMirror > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts We'll remove from the repository the css/custom.css This script apply git update-index --skip-worktree css/custom.css rm 'css/custom.css' MagicMirror installation successful! > magicmirror@2.9.0 install-fonts /home/pi/MagicMirror > cd fonts && npm install audited 1 package in 1.629s found 0 vulnerabilities npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself. added 173 packages from 113 contributors, removed 132 packages, updated 181 packages, moved 1 package and audited 3475 packages in 1071.546s found 28 vulnerabilities (1 low, 1 moderate, 26 high) run `npm audit fix` to fix them, or `npm audit` for details processing dependency changes for active modules with package.json files processing for module MMM-Carousel please wait ---------------------------------- audited 859 packages in 17.666s found 2 high severity vulnerabilities run `npm audit fix` to fix them, or `npm audit` for details processing complete for module MMM-Carousel processing for module MMM-PublicTransportHafas please wait ---------------------------------- audited 41 packages in 2.153s found 0 vulnerabilities processing complete for module MMM-PublicTransportHafas processing for module MMM-PublicTransportHafas please wait ---------------------------------- audited 41 packages in 3.251s found 0 vulnerabilities processing complete for module MMM-PublicTransportHafas processing for module MMM-PublicTransportHafas please wait ---------------------------------- audited 41 packages in 3.956s found 0 vulnerabilities processing complete for module MMM-PublicTransportHafas restoring custom.css
pm2 start mm
…and it looks GOOD! :rolling_on_the_floor_laughing:
It’s great after such a … work? … getting it solved.Thank you sooo much. On my own I would install from scatch :frowning_face: and this is nothing I can bring to my family.
and here you asked
pi@MagicMirror:~/MagicMirror $ echo $LC_ALL de_DE.UTF-8
would say this is one of the first thing I do installing Raspian :grimacing_face:
de_DE.UTF-8bingo… things you learn!..
LC_ALL overrides LANG or LANGUAGE=
I just have to fix my alias…
would u be willing to test the fix… no changes to your local running system
package-lock.json should exist
ls package-lock.json
then
bash -c "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
when u see the message about saving files, just hit ctrl-c to exit
I was to slow for hitting ctrl-c :nerd_face:
As this is a huge of lines my buffer is to small.
Is there a log or is there no interest to u of the outcome? -
@bdream yes the install.log
but it should have waited for you to reply about writing over package-lock.json
hm… if package.lock.json does NOT exist
then create it
touch package-lock.json
nono, it did exist
pi@MagicMirror:~/MagicMirror $ ls pack* package.json package-lock.json
but the script run fast
what path I can find the install.log?
@bdream sorry, not install… upgrade.log
update log will be in /home/pi/MagicMirror/installers/upgrade.logon the package-lock.json… it is the same as the update… thus why it didn’t stop
could edit it an add a space someplace
@sdetweil upgrade.log is here from …force… no it isn’t.
I can’t copy the 2738 lines in here.
How can I bring it to you?And what does this mean?
on the package-lock.json… it is the same as the update… thus why it didn’t stop could edit it an add a space someplace
