    Problems with calender and Nextcloud
    44 Posts 6 Posters 24.2k Views 6 Watching
    • K Offline
      kruf
      I got a Problem with the calender module, since it shows no dates.
      The standart calender works just fine, but when I try to connect my Nextcloud calender nothing shows. With my iPhone the link works, so I am sure it works.
      Had somebody the same expirience and knows some tips.
      Thank You
      kruf
        bdream
        @kruf said in Problems with calender and Nextcloud:
        If I’m right you talk about standard calendar module and getting connected to your nextcloud.
        I have done my config as you can see and it works fine
        	header: "  WHAT CALENDAR YOU WILL SHOW", // see help for more information
        	position: "bottom_left",
        		colored: true,
        		displaySymbol: true,
        		wrapEvents: true,
        		fetchInterval: 120000,
        		fade: false,
         		fullDateEventDateFormat: "ddd DD. MMM",
        		maximumNumberOfDays: 30,
        		maximumEntries: 15,
        		maxTitleLength: 50,
        		displayRepeatingCountTitle: true,
        		fade: false,
        		timeFormat: "absolute",
        		dateFormat: "ddd DD. MMM - HH:mm",
        		dateEndFormat: "ddd DD. MMM - HH:mm",
        		showEnd: true,
        		joiningWord: "AT", // see help for more information
        		maxTitleLength: 500,
        		useRelativeDates: false,
        		getRelative: 6,
        		dayOfWeekFormat: "dddd",
        		urgency: 1,
        				symbol: "birthday-cake",
        				color: "#a9a9a9",
        				url: "https://NAME:PASSWORD@DOMAIN.TLD/Nextcloud/remote.php/dav/calendars/CALENDARNAME/contact_birthdays?export"
        				symbol: "plane ",
        				color: "#ffd700", // gold
        				url: "https://www.schulferien.org/media/ical/deutschland/ferien_hessen_2019.ics?k=A1phwzkCPxzt2pDVDT3ZeJvHfv9hq0Wo39uxgoplWmpDqdjNn4diAxd9kVfib72HpVThoNV9WGIF3Pjs5BrYIpOZ2F97U0Mbdbo_c3mxjo0"
        If I’m wrong, please provide some information enable helpers to help.
        cheers, bdream
        • K Offline
          kruf @bdream
          @bdream
          thank you very much for your answer, I tried to use the link setup with the user and password in the name, but it does not work for me. I also tried to use a public link.
          I do not know why my dates do not appear.
          Greetings
            bdream
            than start the config as first with only an official calendar as shown in the README.md on GitHub ad default value:
            	colored: false,
            	coloredSymbolOnly: false,
            			url: 'http://www.calendarlabs.com/templates/ical/US-Holidays.ics',
            			symbol: 'calendar',
            			auth: {
            			    user: 'username',
            			    pass: 'superstrongpassword',
            			    method: 'basic'
            If this don’t work your problem is on other place and as I said in my first post: “If I’m wrong, please provide some information enable helpers to help.”
            cheers, bdream
              sdetweil @kruf
              @kruf so two things to test
              1. with the calendar URL, open a browser on the pi, and put in the URL… it should download the ICS file
                if not, u need to solve this part. Mirror does not run as any particular user, so it needs access without
                credentials (unless they are part of the actual url)
              2. I helped another user who did some download process, and then use the ics file locally, and had a similar problem. it turned out the ics reader is expecting windows line ends (cr+lf, \r\n), but the file had only unix line ends (lf, \n). so he had to do a unix2dos conversion as part of the download process
              • K Offline
                kruf @bdream
                @bdream
                I tried your holiday calender in hessen, and it works. The standart calender also works just fine.
                • K Offline
                  kruf @kruf
                  @kruf There is no download, it says "its a webdav interface and you need a client for it.
                  Do you know how to do the conversion?
                    sdetweil @kruf
                    @kruf see
                    https://help.nextcloud.com/t/sharing-nextcloud-calendar-with-google-calendar/12935
                      bdream
                      @kruf
                      I use Nextcloud and have URL like this working.
                      url: "https://NAME:PASSWORT@DOMAIN.TLD/Nextcloud/remote.php/dav/calendars/CALENDARNAME/pers%c3%b6nlich?export"
                      May this help you
                      cheers, bdream
                      K 1 Reply Last reply Reply Quote 1
                      • K Offline
                        kruf @bdream
                        @bdream has CALENDERNAME to be changed? Or is the phrase after that important?
                        • 1 / 5
