    MMM-pages & mmm-remote-control
    12 Posts 4 Posters 4.3k Views 4 Watching
      sdetweil @waki
      @waki
      from the mmm-pages doc
      https://github.com/edward-shen/MMM-pages
      also do note that to switch to page 1, you need to send 0 to the module
      • W Offline
        waki
        I understand this. The question is how to pass the page:
        Like one of these??
        • http://192.168.0.62:8080/api/notification/PAGE_CHANGED?page=1
        • http://192.168.0.62:8080/api/notification/PAGE_CHANGED?1
        • http://192.168.0.62:8080/api/notification/PAGE_CHANGED?payload=1
        or how ?
          sdetweil @waki
          @waki said in MMM-pages & mmm-remote-control:
          no
          to go directly to page 1
          http://192.168.0.62:8080/api/notification/PAGE_CHANGED?payload=0
          the direct page numbers are 0 based…
          1 Reply Last reply Reply Quote -1
          • W Offline
            waki
            I know the page numbers start with 0. But if I use the commands in the list, no matter what page index I pass, I only get a black page. So I think the formal way, of how I pass the paramter is wrong. And your command also doesnt work
              sdetweil @waki
              @waki open the developers window, ctrl-shift-i and select the tab labeled console, set the filter to control
              and then send a message and see what the error is…
              or look at the mmm-remote-control code
              • W Offline
                waki
                I tried this, there is no error. The notification gets recieved by the mmm-pages modules, but it reports:
                [Pages]: received a notification to change to page [object Object] of type object
                From the API I get the answer:
                {“success”:true,“notification”:“PAGE_CHANGED”,“payload”:{“payload”:“1”}}
                But I only get a black page. And I looked inside the code, but my js knowledge is too bad to understand what is happening there.
                  sdetweil @waki
                  @waki try this
                  “payload”:{“page”:“0”}
                    m1scha
                    Hi, were you able to solve this? I am having the same issue
                      andy123 @waki
                      @waki @m1scha
                      the page that you would like to rotate to is given as a url parameter. Replace localhost:8080 with your own ip’s.
                      curl -X GET "http://localhost:8080/api/notification/PAGE_CHANGED/0" -H "accept: application/json"
                      You can test it out with the Swagger API:
                      http://localhost:8080/api/docs/#/Module Control/get_api_notification___notification_____p_
