    MMM-pages & mmm-remote-control
    12 Posts 4 Posters 5.2k Views 4 Watching
      sdetweil @waki
      @waki see this post of mine… the api was changed but not documented
      https://forum.magicmirror.builders/topic/9941/mmm-remote-control-cannot-get-api/7
      • W Offline
        waki
        Thank you for the link, but the command is working, if I use the notification “PAGE_DECREMENT” without an aditional parameter. But I´m not sure how to pass the page as paramter, so the mmm-remote-control is executing “this.sendNotification(“PAGE_CHANGED”, 1)”.
          sdetweil @waki
          @waki
          from the mmm-pages doc
          https://github.com/edward-shen/MMM-pages
          also do note that to switch to page 1, you need to send 0 to the module
          • W Offline
            waki
            I understand this. The question is how to pass the page:
            Like one of these??
            • http://192.168.0.62:8080/api/notification/PAGE_CHANGED?page=1
            • http://192.168.0.62:8080/api/notification/PAGE_CHANGED?1
            • http://192.168.0.62:8080/api/notification/PAGE_CHANGED?payload=1
            or how ?
              sdetweil @waki
              @waki said in MMM-pages & mmm-remote-control:
              no
              to go directly to page 1
              http://192.168.0.62:8080/api/notification/PAGE_CHANGED?payload=0
              the direct page numbers are 0 based…
              1 Reply Last reply Reply Quote -1
              • W Offline
                waki
                I know the page numbers start with 0. But if I use the commands in the list, no matter what page index I pass, I only get a black page. So I think the formal way, of how I pass the paramter is wrong. And your command also doesnt work
                  sdetweil @waki
                  @waki open the developers window, ctrl-shift-i and select the tab labeled console, set the filter to control
                  and then send a message and see what the error is…
                  or look at the mmm-remote-control code
                  • W Offline
                    waki
                    I tried this, there is no error. The notification gets recieved by the mmm-pages modules, but it reports:
                    [Pages]: received a notification to change to page [object Object] of type object
                    From the API I get the answer:
                    {“success”:true,“notification”:“PAGE_CHANGED”,“payload”:{“payload”:“1”}}
                    But I only get a black page. And I looked inside the code, but my js knowledge is too bad to understand what is happening there.
                      sdetweil @waki
                      @waki try this
                      “payload”:{“page”:“0”}
                        m1scha
                        Hi, were you able to solve this? I am having the same issue
                          andy123 @waki
                          @waki @m1scha
                          the page that you would like to rotate to is given as a url parameter. Replace localhost:8080 with your own ip’s.
                          curl -X GET "http://localhost:8080/api/notification/PAGE_CHANGED/0" -H "accept: application/json"
                          You can test it out with the Swagger API:
                          http://localhost:8080/api/docs/#/Module Control/get_api_notification___notification_____p_
