    MMM-pages & mmm-remote-control
    12 Posts 4 Posters 5.3k Views 4 Watching
    • W
      waki
      Hey guys,
      I want to use the restful-api of the mmm-remote control package to switch to a specific page. To achive this, I tried to send a notification with the command “http://192.168.0.62:8080/api/notification/PAGE_CHANGED?payload=1” but it is not working. Can you help me?
      Thanks a lot!
      S A 2 Replies Last reply
        sdetweil @waki
        @waki see this post of mine… the api was changed but not documented
        https://forum.magicmirror.builders/topic/9941/mmm-remote-control-cannot-get-api/7
        • W
          waki
          Thank you for the link, but the command is working, if I use the notification “PAGE_DECREMENT” without an aditional parameter. But I´m not sure how to pass the page as paramter, so the mmm-remote-control is executing “this.sendNotification(“PAGE_CHANGED”, 1)”.
            sdetweil @waki
            @waki
            from the mmm-pages doc
            https://github.com/edward-shen/MMM-pages
            also do note that to switch to page 1, you need to send 0 to the module
            • W
              waki
              I understand this. The question is how to pass the page:
              Like one of these??
              • http://192.168.0.62:8080/api/notification/PAGE_CHANGED?page=1
              • http://192.168.0.62:8080/api/notification/PAGE_CHANGED?1
              • http://192.168.0.62:8080/api/notification/PAGE_CHANGED?payload=1
              or how ?
                sdetweil @waki
                @waki said in MMM-pages & mmm-remote-control:
                no
                to go directly to page 1
                http://192.168.0.62:8080/api/notification/PAGE_CHANGED?payload=0
                the direct page numbers are 0 based…
                Reply Quote -1
                • W
                  waki
                  I know the page numbers start with 0. But if I use the commands in the list, no matter what page index I pass, I only get a black page. So I think the formal way, of how I pass the paramter is wrong. And your command also doesnt work
                    sdetweil @waki
                    @waki open the developers window, ctrl-shift-i and select the tab labeled console, set the filter to control
                    and then send a message and see what the error is…
                    or look at the mmm-remote-control code
                    • W
                      waki
                      I tried this, there is no error. The notification gets recieved by the mmm-pages modules, but it reports:
                      [Pages]: received a notification to change to page [object Object] of type object
                      From the API I get the answer:
                      {“success”:true,“notification”:“PAGE_CHANGED”,“payload”:{“payload”:“1”}}
                      But I only get a black page. And I looked inside the code, but my js knowledge is too bad to understand what is happening there.
                        sdetweil @waki
                        @waki try this
                        “payload”:{“page”:“0”}
                        Reply Quote -1
                          m1scha
                          Hi, were you able to solve this? I am having the same issue
                          • A
                            andy123 @waki
                            @waki @m1scha
                            the page that you would like to rotate to is given as a url parameter. Replace localhost:8080 with your own ip’s.
                            curl -X GET "http://localhost:8080/api/notification/PAGE_CHANGED/0" -H "accept: application/json"
                            You can test it out with the Swagger API:
                            http://localhost:8080/api/docs/#/Module Control/get_api_notification___notification_____p_
