optimize modules during days
i have a raspberry pi4 since 2 days on replace raspberry pi3…i have a lot of modules with MMM-pages…videos, meteo,images,default modules,spotify…
How can i optimize display without bug (slow display)? what’s the perfect size of memory split? (128 now) i’m using crontab -e to reduce default (pm2 stop and restart in half day)…thanks -
module: "MMM-pages", disabled: false, config: { modules: [[ "MMM-EmbedYoutube" , "MMM-EyeCandy" , "newsfeed" ], [ "helloworld" , "MMM-ImagesPhotos" , "MMM-ImagesPhotos2" , "newsfeed" , "helloworld2" ], [ "MMM-iFrameReload" , "MMM-EyeCandy" , "newsfeed" ], [ "helloworld" , "MMM-ImagesPhotos" , "newsfeed" ], [ 'MMM-Lunartic' , "MMM-DarkSkyForecast" , "MMM-EARTH" , 'MMM-rfacts' , "MMM-NowPlayingOnSpotify" , "newsfeed" ], [ "helloworld" , "MMM-ImagesPhotos" , "newsfeed" ], [ "MMM-EmbedYoutube" , "MMM-EyeCandy" , "newsfeed" ], [ "helloworld" , "MMM-ImagesPhotos" , "newsfeed" ], [ "MMM-iFrameReload" , "MMM-EyeCandy" , "newsfeed" ], [ "helloworld" , "MMM-ImagesPhotos" , "newsfeed" ], [ "clock" , "calendar", "calendar_monthly" , "MMM-cryptocurrency" , "MMM-EyeCandy" , "newsfeed" ], [ "helloworld" , "MMM-ImagesPhotos" , "newsfeed" ], [ "MMM-EmbedYoutube" , "MMM-EyeCandy" , "newsfeed" ], [ "helloworld" , "MMM-ImagesPhotos" , "newsfeed" ], [ "MMM-iFrameReload" , "MMM-EyeCandy" , "newsfeed" ], [ "helloworld" , "MMM-ImagesPhotos" , "newsfeed" ], [ 'MMM-SoccerLiveScore' , "MMM-Cocktails" , 'MMM-MovieListings' , "newsfeed" , 'MMM-SystemStats' ], [ "helloworld" , "MMM-ImagesPhotos" , "newsfeed" ]], rotationTime: 15000, } -
@chassain-0 sorry, I do not understand what you are asking…
also, can you use the markdown syntax, put a code block around your config post (mark the text and press the code icon in the editor
Sorry my english is bad…and school was so far 😁…for resume, you can see the differents modules used in my config.js…i have a magicmirror without mirror…the memory gpu is 128 M (with sudo raspi-config) but i have some slowly in a day…then, i use on a terminal “crontab -e” to restart mm at different moment…and it s ok !..but may be there is more parameters about raspberry pi 4 to work fine…
Cpu…not gpu
@chassain-0 hmm… 128meg memory? i don’t think so… pi 4 has 1 2 or 4 gig
lets check for swap space enabled
free -mmight show something like
total used free shared buff/cache available Mem: 1994 631 50 523 1313 785 Swap: 2047 224 1823if no swap space, do , see here
https://wpitchoune.net/tricks/raspberry_pi3_increase_swap_size.html -
Sorry but i speak about option 7 “advanced options” / A3 " memory split" / how much memory should the gpu have : 128 choose /…is it correct to have no slowly with vidéos & photos modules ? I have raspberry pi 4 with 4G memory
i don’t know when the GPU is used, but not very much if at all by MagicMirror
maybe video encoding/decoding… -
@sdetweil thanks
@chassain-0
Why do you use so many duplicated pages? I can’t understand what you want. -
Hello sean
It’s just a magicmirror wit no mirror… i duplicate pages because i don’t know change the timer for only one page. this config is just to play and see the result along a day…i had some slowly displays after 10 hours. I play with crontab to refresh modules and it’s correct now…i play too with trigger cmd (and alexa echo) to start mm or stop mm…it’s really funny !!! and i just wanted to know the best configuration for my raspi 4 to work fine
