    MMM-Facial-Recognition
    31 Posts 2 Posters 18.0k Views 2 Watching
      sdetweil @Buncie
      @Buncie u have to do it on the mirror screen
        Buncie
        [0_1571938086869_AF1QipMMEwZBijpc66gjmdGmou7LnGLnF-qIh0I9nhBU.html](Uploading 100%) It’s giving an error message about the example_module.
          sdetweil @Buncie
          @Buncie sorry, not quite sure I understand. Your image did not display.
          UseUsb??? We don’t have that in MagicMirror, unless it is a module
          Also, example module?
            Buncie
            The title, MMM-Facial-Recongnition, is the module I’m having issue with.
            https://github.com/paviro/MMM-Facial-Recognition![0_1571939212539_675ae4b6-638c-4e26-bad1-fcc2aeb98e1a-image.png](/assets/uploads/files/1571939212802-675ae4b6-638c-4e26-bad1-fcc2aeb98e1a-image.png)
            https://photos.google.com/share/AF1QipMuv9hNbRVSByJFSfhnhDa2a6Rf_fe7nGFPtInNnsAPE7uQ9CWc07MknObyU_nUqQ?key=WmU4d0VXQmhSLUZ3Z0t2aXVKbzRqeHhrRnlGNmhn
              sdetweil @Buncie
              @Buncie ah. The facial module executes a script when it detects a face… sounds like u have more config work to do
                Buncie
                Is there anyway to change that. All I want is to make it show the camera and when you step in front of it, a box will appear around your face and it will show your name. Here is the config file for the magic mirror so far.
                https://photos.google.com/share/AF1QipMBomD6bUWkKLSLd51oXRsYx766DFKdZYNFbn7gHo9iK2OBuMQ1yA2blZ25nfAXIQ?key=OUZ5MkhDVndtMzdPcmdWODBRVlFqX0pNTk5GLUFR
                  sdetweil @Buncie
                  @Buncie sorry, I don’t know anything about the module. Maybe another user or the author will come by and be able to help.
                    Buncie
                    Here is the example_module too.
                    https://photos.google.com/share/AF1QipNGBelqXy6FuDK2WKQjyrvIxPsl0zeMPi5hwGZorQXEywzcP2d-MuxoLl4vwS5XCA?key=VGR6VGsxWEV6M1owTEI0Rlh6QVVQWkl0TXlkRVFn
                      sdetweil @Buncie
                      @Buncie there is no example module. He was just suggesting that using classes u could make a module show or hide
                        Buncie
                        So I should delete the example and everything should be fixed?
                          sdetweil @Buncie
                          @Buncie again, I do not know. First time looking at it. On my phone so hard to read the code
                            Buncie
                            Even after the reboot, it still shows a black screen. I did crtl-shift-i and it’s showing no error messages. Have any ideas?
                              Buncie
                              I need to leave my classroom, I shall hope to resume this chat tomorrow.
                                Buncie
                                I’m back, I’m still getting the same error, did anyone figure it out what I did wrong?
                                  sdetweil @Buncie
                                  @Buncie can u show output of
                                  pm2 logs --lines=100
                                    Buncie
                                    How would I do that?
                                      sdetweil @Buncie
                                      @Buncie via ssh or on screen do the command in a command prompt
                                        Buncie
                                        https://photos.google.com/share/AF1QipPm5it4o56ZmhXqukbDCag27So1yV4DE65QoD-QLzXXuWVkAHkMnFgzTQj5pJruHw?key=REVKY2wtM0VVNXRLZHZ1cUE0Z3NFRVBwcXFfd3ZB![0_1572021578247_cc5f68ac-5b9f-4b16-ac72-063229019bdb-image.png](/assets/uploads/files/1572021578595-cc5f68ac-5b9f-4b16-ac72-063229019bdb-image.png)
                                        https://photos.google.com/share/AF1QipPm5it4o56ZmhXqukbDCag27So1yV4DE65QoD-QLzXXuWVkAHkMnFgzTQj5pJruHw?key=REVKY2wtM0VVNXRLZHZ1cUE0Z3NFRVBwcXFfd3ZB![0_1572021594291_0a64d8b7-5427-4bea-a6e8-82c121e379a9-image.png](/assets/uploads/files/1572021594519-0a64d8b7-5427-4bea-a6e8-82c121e379a9-image.png)
                                        https://photos.google.com/share/AF1QipPm5it4o56ZmhXqukbDCag27So1yV4DE65QoD-QLzXXuWVkAHkMnFgzTQj5pJruHw?key=REVKY2wtM0VVNXRLZHZ1cUE0Z3NFRVBwcXFfd3ZB![0_1572021616048_23915c52-6290-4fb6-a7b1-a61237d964fa-image.png](/assets/uploads/files/1572021616246-23915c52-6290-4fb6-a7b1-a61237d964fa-image.png)
                                        https://photos.google.com/share/AF1QipPm5it4o56ZmhXqukbDCag27So1yV4DE65QoD-QLzXXuWVkAHkMnFgzTQj5pJruHw?key=REVKY2wtM0VVNXRLZHZ1cUE0Z3NFRVBwcXFfd3ZBhttps://lh3.googleusercontent.com/vCzy2ZpJRncIL7OYPO94k3diYIZqaKa-Ak_6s_ZPQwwR3PD9t8FRXx7x44Q8AT8BkMxfNTrUnKDTKolVIEChxq29GqXntRs6ZeO_wWmnSEb90VLeq9-8nSOh8KPcmEUZoq3OALYEDEwcrDJi47wxmaJ0H-C2mcBgR3cLex-vwgVybFIPwxoqz1s4hGgGQvch7XE3-iVI-1daRcgP3wv5Y3M6Hz-VzPY4OxQAEdBy7sfjc4xEdi_C9_nvSEf1hMTE8u1d7rq8Q2H0gcsa_JQ-zz93yyPU6FS_7AxT9AJeBLG_5-kwdGEOUPRFspR_cUo5UBWjFvmiC_JnFJrnxeLvXZc67CVKR5Nw9UGyFEgsWkYlj1qjDzXyIsDyqTVZkXspgQvJouHDMpyyWXn7gmHeIxb191LKsVCN8l2UUR0Pny35NdxIOeIl-f-4_xPhF8fQOaXZEs0tvohqhSmBnbDuUxZCeSl7kns31mniSVB9UT_F7t4qjbY4z53DdIgPCA0WkhHfBniCt-heh9rKmRFzOKku_7lGuvFwYo10olYg8NUYaRj7dqe28txqPNekvAveIk7VoutrZQnaZ0gps683-8bPKMhIgil2CD-Th91WOeaDYNYCxBUZjY4q3MwrJAj1k2OfkrMc-kvqmU-SQ_7OP0qMnFQwOyyM9__MiNjyhq8AYXY7dN0KtBcIVN1Am0wnefgubUG1Chalbq9FH3oLIzqWmIfXKyaxR_psaa-v62N4uZzF=w1602-h2136-no
                                          Buncie
                                          The last image had an error so I fixed it.
                                            sdetweil @Buncie
                                            @Buncie so, MMM-NOAA3 has some config missing (for providers I would guess)
                                            looks like voicecontrol module config isn’t completed, or snowboy needs an electron-rebuild. (snowboy is a challenge many times)
                                            and Facial-rec is having a problem with its python code… maybe wrong python version…
