    MM says my config is wrong.
    3 Posts 2 Posters 1.1k Views 2 Watching
      Doogain
      Hey there!
      When I try to add this
      fade: false
      to my config.js
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "2624886",
      				appid: "a59083d2a1c9da6e99d2395fb61d8979"
      So it becomes
                                      fade: false
      Then MM says that my config is wrong.
      WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:73
      fade: false
      SyntaxError: Unexpected identifier
          at new Script (vm.js:74:7)
          at createScript (vm.js:246:10)
          at Object.runInThisContext (vm.js:298:10)
          at Module._compile (internal/modules/cjs/loader.js:678:28)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
          at Module.load (internal/modules/cjs/loader.js:620:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
          at Function.Module._load (internal/modules/cjs/loader.js:551:3)
          at Module.require (internal/modules/cjs/loader.js:658:17)
          at require (internal/modules/cjs/helpers.js:20:18)
      Not sure on how to fix this, since I believe I’m writing it correctly. Anyone with a quick fix?
      I’m trying to remove the fade effect on the modules, aint working too great for me.
      • buzzkcB
        buzzkc
        Add a comma after the appid line.
        Darren
        My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
        Reply Quote 2
          Doogain
          Wow, that was awkward. Thanks man haha
