    Default Calendar Daylight Savings Issue
    6 Posts 2 Posters 2.0k Views 2 Watching
    • Y
      yk
      I’m having issues with reoccurring events after daylight savings. The pi is showing the correct time overall (so it’s not a “pi config” issue it seems). The calendar, though, is showing the events as 1 hour back.
      I’m using vdircyncer to connect to iCal and create the ics file. Any help would be appreciated.
      BEGIN:VEVENT
      DTEND;TZID=America/Toronto:20191029T190000
      DTSTART;TZID=America/Toronto:20191029T183000
      UID:A8F15920-2D23-4622-9403-11C9BBCB79F8
      DTSTAMP:20191008T213304Z
      URL;VALUE=URI:
      SEQUENCE:0
      SUMMARY:Piano Lessons
      LAST-MODIFIED:20191105T131547Z
      CREATED:20190921T152400Z
      RRULE:FREQ=WEEKLY;UNTIL=20200701T035959Z;INTERVAL=1
      TRANSP:OPAQUE
      X-APPLE-TRAVEL-ADVISORY-BEHAVIOR:AUTOMATIC
      BEGIN:VALARM
      X-WR-ALARMUID:0D4450D8-59CA-4370-A0FB-85208564B2D6
      TRIGGER:-PT1H
      ATTACH;VALUE=URI:Chord
      ACTION:AUDIO
      X-APPLE-DEFAULT-ALARM:TRUE
      ACKNOWLEDGED:20191008T213304Z
      END:VALARM
      END:VEVENT
        sdetweil @yk
        @yk yes, the calendar parser has a set of bugs related to time zone and daylight savings time. No fix yet
        It’s not our code, but code we use, and have no control over
        • Y
          yk
          Understood. Is there a tracker somewhere which I can follow to check on progress? Who owns the component?
            sdetweil @yk
            @yk go to the GitHub issues for MagicMirror
            https://github.com/MichMich/MagicMirror/issues
            Remember, this is volunteer, open source. So there is no schedule. If you can and want to fix it for the project, you can. Just submit a GitHub pull request with your solution when ready.
            Mich manages one of the few projects I’ve been involved with that has a regular release each quarter. Whatever fixes are available, he consolidates and releases.
            • Y
              yk @sdetweil
              @sdetweil Thanks. Sorry, I misunderstood thinking that it’s a component outside of the MagicMirror repository, hence my question.
                sdetweil @yk
                @yk said in Default Calendar Daylight Savings Issue:
                it IS outside MM… its the ical nodejs module.
