    Calendar Module Error "Exceeded maxRedirects. Probably stuck in a redirect loop"
    1 Posts 1 Posters 1.1k Views 1 Watching
      anyhowat
      Hi!
      I’m trying to fetch this calender in the default calendar module:
      http://weboffice.orf.at/owa/calendar/4820fc8ddfc0468cbe426b3e08c330b8@orf.at/b5842d9f817246008d95c9f8360a1dbe10919048264267524527/calendar.ics
      This gives me the following error:
      (node:22123) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 pipe listeners added. Use emitter.setMaxListeners() to increase limit
      Calendar Error. Could not fetch calendar:  http://weboffice.orf.at/owa/calendar/4820fc8ddfc0468cbe426b3e08c330b8@orf.at/b5842d9f817246008d95c9f8360a1dbe10919048264267524527/calendar.ics Error: Exceeded maxRedirects. Probably stuck in a redirect loop https://weboffice.orf.at/my.policy
          at Redirect.onResponse (/home/pi/MagicMirror/modules/node_modules/request/lib/redirect.js:98:27)
          at Request.onRequestResponse (/home/pi/MagicMirror/modules/node_modules/request/request.js:993:22)
          at ClientRequest.emit (events.js:182:13)
          at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:546:21)
          at HTTPParser.parserOnHeadersComplete (_http_common.js:109:17)
          at TLSSocket.socketOnData (_http_client.js:432:20)
          at TLSSocket.emit (events.js:182:13)
          at addChunk (_stream_readable.js:279:12)
          at readableAddChunk (_stream_readable.js:264:11)
          at TLSSocket.Readable.push (_stream_readable.js:219:10)
      I googled a possible solution, which is to add
      require('events').EventEmitter.defaultMaxListeners = 15;
      somewhere. But I don’t know where. Changing the Node Module Files is probably not best practise…
      Thanks for help!
