    MMM-DumpsterDay
    83 Posts 11 Posters 71.8k Views 12 Watching
      BD0G
      Well I am kinda forced to collaborate if I want to use this awesome module . Right? :) LOL
      My config.js does not work so I want to get it going so we can all use this module!
      D 2 Replies Last reply
        DeanoNoire @BD0G
        @BD0G i will give it a try with your config and check what’s wrong and let you know.
          DeanoNoire @BD0G
          @BD0G Hey there, I changed the file names of the modules and the paths, so it can be used the way you described - via clone.
          Can pull the current version and give it a try? Also change the date accordingly :) I believe we’re getting there! :D
          Have a good one.
          B 1 Reply Last reply
            BD0G @DeanoNoire
            @DeanoNoire
            I deleted the sub-directory that was created under MagicMirror/modules named mmm-dumpsterday . All lowercase.
            I then used the command git clone https://github.com/DeanoNoire/MMM-DumpsterDay.git.
            This created the correct the directory named MMM-DumpsterDay . Capital letters in proper places.
            Then I modified my config.js under the MagicMirror/config directory to reflect today as being trash day . Turned off Recycle by using the false specifier. Turned on Landscape by using the specifier true. Set the Landscape date to todays date as well.
            Restarted the MagicMirror and I do see a pulsing white trash can ,BUT no can for Landscape. ???
            The trash can is displayed within the bottom_bar area of the screen and the trash can is quiet large onscreen. I am assuming that I can modify the MagicMirror/modules/MMM-DumpsterDay/MMM-DumpsterDay.css file to change the size to better fit the screen?
            Here is my current config.js file to troubleshoot the absence of the Landscape can. on screen
            	module:"MMM-DumpsterDay",
            	position:"bottom_bar",
            		refreshInterval: 18000000, // Default: 18000000 = 5 hours
            		pulse: true, 			   // Default: true - Makes the module pulsating
            		enableBasic: true, 				// Enable basic trashcan
            		basicStartDate: "11.11.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
            		basicDateDiff_1: 7,			// Trashday reoccurance - Default: 14 (every 14 days)
            		basicNotifyDayBefore: true,		//Default: true - If you want the notification to appear also the day before the dumpster day
            		enablePlastic: false,			// Same values as basic but for Plastic
            		plasticStartDate: "16.01.2019",
            		plasticDateDiff_1: 28,
            		plasticNotifyDayBefore: true,
            		enableLandscape: true,			// Same values as basic but for Landscape
            		landscapeStartDate: "11.11.2019",
            		landscapeDateDiff_1: 14,
            		landscapeNotifyDayBefore: true,
            			module: "alert",
              BD0G
              Also, I dont know how much additional code would be needed to display the words
              Tomorrow is Trash Day
              for the day preceding what one sets for Trash Day and then the words Today is Trash Day
              for the day in which is actually trash day. This would be in small text (alterable within the .css file) below the trash can icons. That way one would know at a glance.
                mrdenmark
                @DeanoNoire
                i have this module working and it looks good,thanks
                i would like to use the basic,recycle_blue and recycle_yellow bins,how do i modify the config to work with those?
                  BD0G @mrdenmark
                  @mrdenmark
                  Try this setup in your MagicMirror/config/config.js
                  		enablePlastic: true,			// Same values as basic but for Plastic
                  		plasticStartDate: "11.11.2019",
                  		landscapeDateDiff_1: 7,
                  Then just modify the MagicMirror/modules/MMM-DumpsterDay/MMM-DumpsterDay.css file to have the Landscape setting display a blue can.
                  .landscapeDiv{
                  	height:70px;
                  	width:20%;
                  	background-image: url(imgs/recycle_blue.png);
                  	background-repeat: no-repeat;
                  	background-position: center center;
                  	background-size: contain;
                  	overflow: auto;
                  	display:inline-block;
                  If you want the Blue can next to the White can instead of the Yellow Can then just modify the MagicMirror/modules/MMM-DumpsterDay/MMM-DumpsterDay.css file like this
                  .plasticDiv{
                  	height:70px;
                  	width:20%;
                  	overflow: auto;
                  .landscapeDiv{
                  	height:70px;
                  	width:20%;
                  	background-image: url(imgs/recycle_yellow.png);
                  	overflow: auto;
                  M 1 Reply Last reply
                    mrdenmark @BD0G
                    @BD0G
                    thanks for that,one last thing,is it possible change the colour of the basic bin?in my case i’d like red.
                      BD0G
                      Give me a few minutes and I will try and fill the one that is white with a red color.
                        BD0G
                        Save the file I uploaded (right click -Save Image As) to this directory MagicMirror/modules/MMM-DumpsterDay/imgs
                        Then change your MagicMirror/modules/MMM-DumpsterDay/MMM-DumpsterDay.css file so that it has this entry
                        .basicDiv{
                        	height:70px;
                        	width:20%;
                        	background-image: url(imgs/basic_red.png);
                        	overflow: auto;
                          BD0G
                          I have learned alot during the process to get this module working.
                          1. Getting only 2 of the cans to show up.
                          One must set all of the cans to true and adjust the dates within the MagicMirror/config/config.js file the very first time and save the file.
                          So these lines must be set to true
                          enableBasic: true,
                          Then launch MagicMirror. Then shut down MagicMirror and change the can or cans that one does not want to be shown on screen by changing the setting to false.
                          For instance,
                          enableBasic: true,
                          Save the file and restart MagicMirror. This will display the cans selected.
                          Strange behavior , but thats what I found.
                          I also needed to change the date on each of the cans within the same MagicMirror/config/config.js file
                          basicStartDate: “11.13.2019”,
                          plasticStartDate: “11.13.2019”,
                          landscapeStartDate: “11.13.2019”,
                          to reflect the same dates . If I left
                          as the default date then the recycle nor the landscape can would show up.
                          1. Changing the size of the cans. Initially the can size on my MagicMirror were way too big and I needed to modify the
                          MagicMirror/modules/MMM-DumpsterDay/MMM-DumpsterDay.css file.
                          I changed the value for height from 120 px (I think this was the default size -maybe 200px) to 70px and that turned out to be a good size.
                          .basicDiv{
                          	height:70px; // I changed this line to 70px
                          	width:20%;
                          	background-image: url(imgs/basic.png);
                          	overflow: auto;
                          .landscapeDiv{
                          	width:20%;
                          	background-image: url(imgs/landscape.png);
                          	overflow: auto;
                          .plasticDiv{
                          	height:70px;  //I changed this line to 70px
                          	width:20%;
                          	overflow: auto;
                          D 1 Reply Last reply
                            mrdenmark @BD0G
                            @BD0G
                            fantastic,thankyou,the helpfulness of people on tghis forum never ceases to surprise me!
                              BD0G @mrdenmark
                              @mrdenmark So I take it that worked as intended? :)
                              You are welcome. I have just been focused on getting this module to work. Trash day is in 2 days. LOL!
                              Hopefully we can have @DeanoNoire add the red trashcan to the github repository under images just in case someone else wants that color for thier trash can as well.
                              D M 2 Replies Last reply
                                BD0G
                                What I have yet to figure out is how to get the basic trash can and the landscape can to be shown with less space between them. It appears as if there is enough space between those 2 cans to show the recycle can and since its set to false it is not shown onscreen , but there is a blank space between the cans for it to fit.
                                I want the 2 cans centered and with less space between them.
                                Here is the current spacing
                                DropBox Link
                                  DeanoNoire @BD0G
                                  @BD0G
                                  Please note the date format in the config should be DD.MM.YYYY, the only format making sense :P
                                  If you were testing this on 11.11.2019, the month and day commutable :D
                                    BD0G @DeanoNoire
                                    @DeanoNoire Thats not how the default dates in the MagicMirror/config/config.js were listed from what I recall. They were/are MM.DD.YYYY.
                                    Here is the sample entry that is on the github repository and it lists 24.10.2019 which has to be MM:DD:YYYY. There is no 24th month. :)
                                    	basicStartDate: "24.10.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
                                    	basicDateDiff_1: 14,			// Trashday reoccurance - Default: 14 (every 14 days)
                                    	enableLandscape: false,			// Same values as basic but for Landscape
                                    	landscapeStartDate: "29.10.2019",
                                    	landscapeDateDiff_1: 28,
                                      DeanoNoire @BD0G
                                      @BD0G That would be playing with the width of the elements in the css file. I will check the options of making it a config key as well. But later today - just got to work :)
                                      Thanks for all the ideas and work done! :)
                                        DeanoNoire @BD0G
                                        @BD0G
                                        added :)
                                          BD0G @DeanoNoire
                                          @DeanoNoire Just saw that! Thanks!
                                          Error in spelling of the word clone in the instructions. Its spelled colne.
                                          Just FYI.
                                            DeanoNoire @BD0G
                                            @BD0G Exactly: 24 = DD, 10=MM, 2019=YYYY, so 24.10.2019 is DD.MM.YYYY, an European standard format :)
                                            What I quoted from your post: 11.13.2019 is not applicable as there is no 13th month :)
                                            var startDateYear = startDate.substring(6,10);
                                            var startDateMonth = startDate.substring(3,5);
                                            var startDateDay = startDate.substring(0,2);
                                            That’s the exact code that cuts the date to year, month and day variables, so day is the first two numbers, month are another two numbers and year are last four numbers :)
                                            • 2 / 5
