    Blank screen with error in terminal upon start.
    8 Posts 3 Posters 2.0k Views 3 Watching
      sdetweil @dcarls91
      @dcarls91 if u added back modules, did u check and run npm install in the module folders where they had a package.json file?
      if you do npm start from a terminal window, you might get some error messages…
      I would go back to the base config.js and start adding one module at a time…
        dcarls91 @sdetweil
        @sdetweil I will do that. I went into all of my modules and and ran npm install as well
          dcarls91
          It may also be an electron issue
          • lavolp3L Offline
            lavolp3 Module Developer @dcarls91
            @dcarls91 I’m not sure if what you did was right.
            For me the best way and proven a hundred times is:
            • sit at an external device (laptop/PC)
            • SSH into the mirror
            • npm start dev
            • open the mirror’s page on a browser on the laptop/PC (http://IP.OF.THE.MIRROR:8080)
            • check the shell console (where you did the npm start dev) as well as the developer’s console of the browser for errors.
            There will be something that will help you find the error
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
              sdetweil @dcarls91
              @dcarls91 said in Blank screen with error in terminal upon start.:
              IF they do NOT have a package.json file as part of a module, then there is a bad side effect or a required file beging deleted
              you can check
              ls modules/node_modules/node_helper/index.js
              if the file is there, all good,
              if not do this
              git checkout modules/node_modules/node_helper/index.js
