Unsolved MagicMirror Newsfeed continually "loading"...
Just reinstall this modules
i things solved this problemcd ~/MagicMirror/modules/default/newsfeed/ npm install
@Parvez no. no package.json there
that is part of the base mm
@sdetweil can you help me … install problem MMM Hotword
Welcome to Hotword v2.4.0 Checking OS... OS Detected: linux-gnueabihf (raspbian 10 armv7l) Do you want to execute automatic intallation ? [Y/n] Your choice: N npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142 npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm ERR! code E404 npm ERR! 404 Not Found - GET https://registry.npmjs.org/@bugsounet%2flpcm16 - Not found npm ERR! 404 npm ERR! 404 '@bugsounet/lpcm16@^1.0.1' is not in the npm registry. npm ERR! 404 You should bug the author to publish it (or use the name yourself!) npm ERR! 404 It was specified as a dependency of 'MMM-Hotword' npm ERR! 404 npm ERR! 404 Note that you can also install from a npm ERR! 404 tarball, folder, http url, or git url. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2020-10-03T05_32_52_379Z-debug.log
@Parvez hotword has been removed, and is no longer available.
to use GoogleAssistant you have to install MMM-GoogleAssistant
.also bugsounet has removed some of his modules
