    MagicMirror Newsfeed continually "loading"...
    24 Posts 4 Posters 11.7k Views 4 Watching
      sdetweil @ForeverBrewing
      @ForeverBrewing said in MagicMirror Newsfeed continually "loading"...:
      Thank you so much for your time with this btw
      no problem… like to help…
      but the output doesn’t match the config at all… there should be more info about the other modules and errors if they were not found…
      • F Offline
        ForeverBrewing @sdetweil
        Well I guess installing a fresh copy wont be too much hassle! Its not like I cant work out how to get the google assistant to work anyway, so I’ll probably just keep it completely vanilla. Even I cant balls that up too much…
          @ForeverBrewing use the updated installer… see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
          you should rename the current MM folder out of the way… then u can copy files over if need be
          • F Offline
            Will do, thanks for your help :)
              spblat
              For those googling this problem, consider whether you added the module to your config file but didn’t stop and restart the software. Many config changes can take effect just by saving the config file and reloading the browser window, but adding and removing modules…not so much :-)
                sdetweil @spblat
                @spblat if the module has a node_helper.js, you need to restart MM for any changes to take place
                • ParvezP Offline
                  Parvez
                  Just reinstall this modules
                  i things solved this problem
                  cd ~/MagicMirror/modules/default/newsfeed/
                  npm install
                  Parvez Ahmed
                    sdetweil @Parvez
                    @Parvez no. no package.json there
                    that is part of the base mm
                    • ParvezP Offline
                      Parvez
                      @sdetweil can you help me … install problem MMM Hotword
                      Welcome to Hotword v2.4.0
                      Checking OS...
                      OS Detected: linux-gnueabihf (raspbian 10 armv7l)
                      Do you want to execute automatic intallation ? [Y/n]
                      Your choice: N
                      npm ERR! code E404
                      npm ERR! 404 Not Found - GET https://registry.npmjs.org/@bugsounet%2flpcm16 - Not found
                      npm ERR! 404
                      npm ERR! 404  '@bugsounet/lpcm16@^1.0.1' is not in the npm registry.
                      npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                      npm ERR! 404 It was specified as a dependency of 'MMM-Hotword'
                      npm ERR! 404
                      npm ERR! 404 Note that you can also install from a
                      npm ERR! 404 tarball, folder, http url, or git url.
                      npm ERR!     /home/pi/.npm/_logs/2020-10-03T05_32_52_379Z-debug.log
                      Parvez Ahmed
                        sdetweil @Parvez
                        @Parvez hotword has been removed, and is no longer available.
                        to use GoogleAssistant you have to install MMM-GoogleAssistant
                        .also bugsounet has removed some of his modules
