    Cannot find module './snowboy/lib/node/index.js'
    8 Posts 4 Posters 2.0k Views 4 Watching
    • A
      AliensExist
      After installing MagicMirror and google assistant, I get this error and the screen is blank. it does not display anything
      Please help. I am doing this for my school project. Thank you.
      magicmirror@2.9.0 start /home/pi/MagicMirror
      sh run-start.sh
      Starting MagicMirror: v2.9.0
      Loading config …
      Loading module helpers …
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘./snowboy/lib/node/index.js’
      App threw an error during load
      at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
      at Function.Module._load (internal/modules/cjs/loader.js:528:25)
      at Module.require (internal/modules/cjs/loader.js:658:17)
      at require (internal/modules/cjs/helpers.js:20:18)
      at Object. (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:11:18)
      at Object. (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:234:3)
      at Module._compile (internal/modules/cjs/loader.js:711:30)
      at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
      at Module.load (internal/modules/cjs/loader.js:620:32)
      Whoops! There was an uncaught exception…
      { Error: Cannot find module ‘./snowboy/lib/node/index.js’
      at Module.load (internal/modules/cjs/loader.js:620:32) code: ‘MODULE_NOT_FOUND’ }
      Launching application.
      Shutting down server…
      Stopping module helper: updatenotification
      Stopping module helper: calendar
      Stopping module helper: newsfeed
      ? 1 Reply Last reply
        mrdenmark
        did you mak a copy of the original config file? if you us that one wnat happens?
          A Former User @AliensExist
          @AliensExist
          You probably made a mistake with installing MMM-Hotword. Did you follow the installation instruction on github repository?
          A 1 Reply Last reply
          • A
            AliensExist @Guest
            @Sean Yes, I installed the MMM-Hotword properly, without any mistakes. I have had this problem for a week now, so I decided to start fresh and do everything again (installing the MagicMirror and everything), I did everything over again three times, but I still have the same problem.
              @AliensExist
              But the error log says your installation was not completed.
              Check whether the file and folder exist.
              cd ~/MagicMirror/modules/MMM-Hotword
              ls ./snowboy/lib/node/index.js
              It should return ./snowboy/lib/node/index.js. If not, your installation was failed for some reason.
              A 2 Replies Last reply
              • A
                AliensExist @Guest
                @Sean thank you for your replay.
                Yes, you are right. There is problem with he installation. ./snowboy/lib/node/index.js does not shuow up.
                I’ll try installing it again the fourth time. Lets see how it goes. Thank you again
                I’ll update here on how it goes.
                • A
                  AliensExist @Guest
                  @Sean Ok, so i was able to fix it by re-installing everything again. But now after I run the command ‘npm start’ the mirror starts for 1 sec or 2, and then closes by itself. I am not sure what the problem here is. I tried debugging with ‘npm start dev’ but it crashes after 2 seconds.
                  This is everything after I run the command ‘npm start’ (if it helps)
                  sh run-start.sh
                  Loading config …
                  Module helper loaded: MMM-Hotword
                  Module helper loaded: MMM-AssistantMk2
                  All module helpers loaded.
                  Starting server on port 8080 …
                  Server started …
                  Starting module: newsfeed
                  Connecting socket for: MMM-Hotword
                  [HOTWORD] MMM-Hotword starts
                  Connecting socket for: MMM-AssistantMk2
                  Sockets connected & modules started …
                  Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                  Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                  [AMK2] Recipe is loaded: hide_and_show_all_modules.js
                  [AMK2] Recipe is loaded: reboot.js
                  [AMK2] Recipe is loaded: screen_onoff.js
                  [AMK2] Recipe is loaded: shutdown.js
                  [AMK2] Temporal storage directory is clearing.
                  [HOTWORD] No model to load
                  [AMK2] assistant ready
                  /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
                  npm ERR! code ELIFECYCLE
                  npm ERR! syscall spawn
                  npm ERR! file sh
                  npm ERR! errno ENOENT
                  npm ERR! magicmirror@2.9.0 start: sh run-start.sh
                  npm ERR! spawn ENOENT
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.9.0 start script.
                  npm ERR! /home/pi/.npm/_logs/2019-11-15T21_50_03_527Z-debug.log
                    sdetweil @AliensExist
                    @AliensExist see this post for the instructions on how to fix this problem
                    https://forum.magicmirror.builders/topic/11430/error-when-trying-to-run-mmm-assistantmk2/5
