    config
    57 Posts 9 Posters 31.5k Views 7 Watching
    • FoziF Offline
      Fozi Project Sponsor
      I‘m 100% sure you have a syntax error in your config, very likely a missing comma or a bracket. The error message is some what misleading. Post your config and we‘ll look on it.
      S G 2 Replies Last reply Reply Quote 0
        sdetweil @Fozi
        @Fozi @geo
        do
        npm run config:check
        fix each error, starting from the top, make one change, rerun
        the error is usually reported on the line AFTER the problem
        unexpected token is usually a missing comma on the line before, or missing matched quotes
        • G Offline
          geo @Fozi
          @Fozi hi i am now really embarassed,how do i post tme config.
          i should explain i thought the mirror would be a great project but did not realise ,for me, how complicated it was.
          cheers
          geo
            BD0G
            Stick with it! Its a great learning experience. Just take your time and dont rush.
            Here is how you post your config entries.
            Open the MagicMirror/config/config.js file in a text editor. Highlight the entries in the config file. CTRL-C or copy command. Then come back to the forum and start a reply post. When you want to paste your code click on the little </> icon above the post. You will see a notification in the posting then that reads Code Here. Highlight that Code Here and choose CTRL-V or paste command. That will paste the code. Choose Submit! Done.
            • G Offline
              geo
              code_text
              ```/* Magic Mirror Config Sample
               * MIT Licensed.
              var config = {
              	port: 8080,
              	language: "en",
              	timeFormat: 24,
              	units: "metric",
              			module: "alert",
              			module: "updatenotification",
              			position: "top_bar"
              			module: "clock",
              			position: "top_left"
              			header: "GB Holidays",
              						symbol: "calendar-check",
              						url: "webcal://www.calendar/embed?src=en.uk%23holiday%40group.v.calendar.google.com"					}
              			module: "compliments",
              			position: "lower_third"
              			module: "currentweather",
              			config:
              				locationID: "53.9576",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              				appid: "76b503a29647f3a01dd9ba1055daea6d",
              			module: "weatherforecast",
              			header: "Weather Forecast",
              			module: "newsfeed",
              			position: "bottom_bar",
              				feeds: [
              						title:  "BBC",
              						url: "http://WWW.BBC.com/services/xml/rss/bbc/HomePage.xml",
              				showSourceTitle: true,
              				showPublishDate: true,
              				broadcastNewsFeeds: false,
              				broadcastNewsUpdates: true,
              B S 2 Replies Last reply Reply Quote 0
                broberg Project Sponsor @geo
                you were missing a { after config: under the module currentweather
                and also one to many , under the module weatherforecast
                Corrected code :
                  sdetweil @geo
                  @geo said in config:
                    	config:
                  should be
                  			config:  {    // < ---- missing open brace
                  this
                  should be
                  				//,   < ---  remove extra comma
                  • G Offline
                    geo
                    hi and thx again.still no joy and i have poated the latest config```
                    code_text
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	language: "en",
                    	timeFormat: 24,
                    	units: "metric",
                    			module: "alert",
                    			position: "top_bar"
                    			module: "clock",
                    			config:  {
                    			module: "newsfeed",
                    			config:
                    				feeds: [
                    						title:  "BBC",
                    S L 2 Replies Last reply Reply Quote 0
                      sdetweil @geo
                      @geo missing the /* as the 1st line
                        @geo here is the fixed up config
                        run thru npm run config:check til no errors
                        missing comma and open {
                         * MIT Licensed.
                        var config = {
                        	port: 8080,
                        	language: "en",
                        	timeFormat: 24,
                        	units: "metric",
                        			module: "alert",
                        			position: "top_bar"
                        			module: "clock",
                        			config:  {
                        			module: "newsfeed",
                        				feeds: [
                        						title:  "BBC",
                        • G Offline
                          geo
                          npm ERR!     /home/pi/.npm/_logs/2019-11-16T14_09_4
                          code_text
                            sdetweil @geo
                            @geo needs to be done from inside the MagicMirror folder…
                            • G Offline
                              geo @sdetweil
                              @sdetweil hi after another attempt i find the config is empty all that is available is the sample
                                sdetweil @geo
                                @geo i posted the corrected config.js above, cut/paste it back into the ~/MagicMiror/config/config.js file
                                • G Offline
                                  geo @geo
                                  @geo would it be better to delete and re install
                                    sdetweil @geo
                                    @geo no… just missing the config file…
                                    select the text in my post above, right click mouse, select copy,
                                    then open an editor on the file and right click mouse paste
                                    i use ssh and BitVise ssh client so I can access and edit files thru my windows machine
                                    • G Offline
                                      geo @sdetweil
                                      @sdetweil hi sorry but i am stuck config.js is empty and cant find text editor
                                        sdetweil @geo
                                        @geo nano is a text editor
                                        you can also do
                                        cp config.js.sample config.js
                                        to copy the initial
                                        • G Offline
                                          geo
                                          totally totally out of my depth and do not understand why my config.js is empty and why the text editor is missing.sorry
                                          • G Offline
                                            geo @sdetweil
                                            @sdetweil hi i think i am back on track.you say to cut,is that the same as copy,because when i right click on your config all i see is copy.cheers
