    config
    57 Posts 9 Posters 27.3k Views 7 Watching
    • G Offline
      geo
      hi when i try to boot mm meesage on screen asking me to create config.it was working and i was fiddling with the weather but dont know what i have done wrong.
      i am not comp savvy and its taken me a long time to get here.
      cheers
      geo
      • FoziF Offline
        Fozi Project Sponsor
        I‘m 100% sure you have a syntax error in your config, very likely a missing comma or a bracket. The error message is some what misleading. Post your config and we‘ll look on it.
        S G 2 Replies Last reply Reply Quote 0
          sdetweil @Fozi
          @Fozi @geo
          do
          npm run config:check
          fix each error, starting from the top, make one change, rerun
          the error is usually reported on the line AFTER the problem
          unexpected token is usually a missing comma on the line before, or missing matched quotes
          • G Offline
            geo @Fozi
            @Fozi hi i am now really embarassed,how do i post tme config.
            i should explain i thought the mirror would be a great project but did not realise ,for me, how complicated it was.
            cheers
            geo
              BD0G
              Stick with it! Its a great learning experience. Just take your time and dont rush.
              Here is how you post your config entries.
              Open the MagicMirror/config/config.js file in a text editor. Highlight the entries in the config file. CTRL-C or copy command. Then come back to the forum and start a reply post. When you want to paste your code click on the little </> icon above the post. You will see a notification in the posting then that reads Code Here. Highlight that Code Here and choose CTRL-V or paste command. That will paste the code. Choose Submit! Done.
              • G Offline
                geo
                code_text
                ```/* Magic Mirror Config Sample
                 * MIT Licensed.
                var config = {
                	port: 8080,
                	language: "en",
                	timeFormat: 24,
                	units: "metric",
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_left"
                			header: "GB Holidays",
                						symbol: "calendar-check",
                						url: "webcal://www.calendar/embed?src=en.uk%23holiday%40group.v.calendar.google.com"					}
                			module: "compliments",
                			position: "lower_third"
                			module: "currentweather",
                			config:
                				locationID: "53.9576",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                				appid: "76b503a29647f3a01dd9ba1055daea6d",
                			module: "weatherforecast",
                			header: "Weather Forecast",
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title:  "BBC",
                						url: "http://WWW.BBC.com/services/xml/rss/bbc/HomePage.xml",
                				showSourceTitle: true,
                				showPublishDate: true,
                				broadcastNewsFeeds: false,
                				broadcastNewsUpdates: true,
                brobergB S 2 Replies Last reply Reply Quote 0
                • brobergB Offline
                  broberg Project Sponsor @geo
                  you were missing a { after config: under the module currentweather
                  and also one to many , under the module weatherforecast
                  Corrected code :
                    sdetweil @geo
                    @geo said in config:
                      	config:
                    should be
                    			config:  {    // < ---- missing open brace
                    this
                    should be
                    				//,   < ---  remove extra comma
                    • G Offline
                      geo
                      hi and thx again.still no joy and i have poated the latest config```
                      code_text
                       * MIT Licensed.
                      var config = {
                      	port: 8080,
                      	language: "en",
                      	timeFormat: 24,
                      	units: "metric",
                      			module: "alert",
                      			position: "top_bar"
                      			module: "clock",
                      			config:  {
                      			module: "newsfeed",
                      			config:
                      				feeds: [
                      						title:  "BBC",
                      S L 2 Replies Last reply Reply Quote 0
                        sdetweil @geo
                        @geo missing the /* as the 1st line
                        • 1 / 6
