    config
    57 Posts 9 Posters 33.3k Views 7 Watching
    • G
      geo
      hi and thx again.still no joy and i have poated the latest config```
      code_text
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "GB Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendar/embed?src=en.uk%23holiday%40group.v.calendar.google.com"					}
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      			config:  {
      				locationID: "53.9576",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "76b503a29647f3a01dd9ba1055daea6d",
      			module: "weatherforecast",
      			header: "Weather Forecast",
      			module: "newsfeed",
      			position: "bottom_bar",
      			config:
      				feeds: [
      						title:  "BBC",
      						url: "http://WWW.BBC.com/services/xml/rss/bbc/HomePage.xml",
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: false,
      				broadcastNewsUpdates: true,
      S L 2 Replies Last reply
        sdetweil @geo
        @geo missing the /* as the 1st line
          @geo here is the fixed up config
          run thru npm run config:check til no errors
          missing comma and open {
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          			module: "alert",
          			position: "top_bar"
          			module: "clock",
          			config:  {
          			module: "newsfeed",
          				feeds: [
          						title:  "BBC",
          G 2 Replies Last reply
          • G
            geo
            npm ERR!     /home/pi/.npm/_logs/2019-11-16T14_09_4
            code_text
              sdetweil @geo
              @geo needs to be done from inside the MagicMirror folder…
              • G
                geo @sdetweil
                @sdetweil hi after another attempt i find the config is empty all that is available is the sample
                S G 2 Replies Last reply
                  sdetweil @geo
                  @geo i posted the corrected config.js above, cut/paste it back into the ~/MagicMiror/config/config.js file
                  • G
                    geo @geo
                    @geo would it be better to delete and re install
                      sdetweil @geo
                      @geo no… just missing the config file…
                      select the text in my post above, right click mouse, select copy,
                      then open an editor on the file and right click mouse paste
                      i use ssh and BitVise ssh client so I can access and edit files thru my windows machine
                      G 1 Reply Last reply
                      • G
                        geo @sdetweil
                        @sdetweil hi sorry but i am stuck config.js is empty and cant find text editor
                          sdetweil @geo
                          @geo nano is a text editor
                          you can also do
                          cp config.js.sample config.js
                          to copy the initial
                          • G
                            geo
                            totally totally out of my depth and do not understand why my config.js is empty and why the text editor is missing.sorry
                            • G
                              geo @sdetweil
                              @sdetweil hi i think i am back on track.you say to cut,is that the same as copy,because when i right click on your config all i see is copy.cheers
                                sdetweil @geo
                                @geo cut/paste is the generic term for the operations of marking the source, and transferring it to the destination
                                copy is the non destructive form of cut
                                • G
                                  geo
                                  @geo said in config:
                                  geo
                                  this is what i have
                                  /* Magic Mirror Config Sample
                                   * MIT Licensed.
                                   * MIT Licensed.
                                   * See https://github.com/MichMich/MagicMirror#configuration/*
                                   * MIT Licensed.
                                  var config = {
                                  	port: 8080,
                                  	language: "en",
                                  	timeFormat: 24,
                                  	units: "metric",
                                  			module: "alert",
                                  			position: "top_bar"
                                  			module: "clock",
                                  			config:  {
                                  			module: "newsfeed",
                                  				feeds: [
                                  						title:  "BBC",
                                    sdetweil @geo
                                    @geo ok… does it work?
                                    • G
                                      geo @sdetweil
                                      @sdetweil no
                                      • G
                                        geo
                                        hi i thought i had managed to copy the config you sent but obviosly not as mirror still will not open ,cheers
                                        • L
                                          La7dan @geo
                                          I will make it works dont worry!
                                          First reinstall:
                                          1- Run this command:
                                          sudo rm -R MagicMirror
                                          (that will rmove the Magic mirror from your system.
                                          2- Run this command:
                                          bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
                                          to install the new MagicMirror again.
                                          3- make sure the config .js is there if not
                                          run this command
                                          nano MagicMirror/config/config.js
                                          then copy between lines:
                                           * MIT Licensed.
                                          var config = {
                                          	port: 8080,
                                          	language: "en",
                                          	timeFormat: 24,
                                          	units: "metric",
                                          			module: "alert",
                                          			position: "top_bar"
                                          			module: "clock",
                                          			header: "US Holidays",
                                          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                                          				locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                          				locationID: "5128581",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                          			module: "newsfeed",
                                          				feeds: [
                                          						title: "New York Times",
                                          				broadcastNewsFeeds: true,
                                          end: dont copy the line above ( you can fin the file in config dirctory under the name of config.js.sample. Just save it as config.js without sample)
                                          4- start your Magic Mirror
                                          First: cd MagicMirror
                                          (to navigate to the Magic Mirror dirctory)
                                          second run : npm start
                                          Check if it works!
                                          I will be helping you step by step even if you wants to add some modules.
                                          Good luck!!!
                                          S Mykle1M G 3 Replies Last reply
                                            sdetweil @La7dan
                                            @La7dan please use the updated installer
                                            see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                                            it will be part of the next release
