    config
    57 Posts 9 Posters 32.4k Views 7 Watching
    • G Offline
      geo
      npm ERR!     /home/pi/.npm/_logs/2019-11-16T14_09_4
      code_text
        sdetweil @geo
        @geo needs to be done from inside the MagicMirror folder…
        • G Offline
          geo @sdetweil
          @sdetweil hi after another attempt i find the config is empty all that is available is the sample
          S G 2 Replies Last reply Reply Quote 0
            sdetweil @geo
            @geo i posted the corrected config.js above, cut/paste it back into the ~/MagicMiror/config/config.js file
            • G Offline
              geo @geo
              @geo would it be better to delete and re install
                sdetweil @geo
                @geo no… just missing the config file…
                select the text in my post above, right click mouse, select copy,
                then open an editor on the file and right click mouse paste
                i use ssh and BitVise ssh client so I can access and edit files thru my windows machine
                • G Offline
                  geo @sdetweil
                  @sdetweil hi sorry but i am stuck config.js is empty and cant find text editor
                    sdetweil @geo
                    @geo nano is a text editor
                    you can also do
                    cp config.js.sample config.js
                    to copy the initial
                    • G Offline
                      geo
                      totally totally out of my depth and do not understand why my config.js is empty and why the text editor is missing.sorry
                      • G Offline
                        geo @sdetweil
                        @sdetweil hi i think i am back on track.you say to cut,is that the same as copy,because when i right click on your config all i see is copy.cheers
                          sdetweil @geo
                          @geo cut/paste is the generic term for the operations of marking the source, and transferring it to the destination
                          copy is the non destructive form of cut
                          • G Offline
                            geo
                            @geo said in config:
                            geo
                            this is what i have
                            /* Magic Mirror Config Sample
                             * MIT Licensed.
                             * MIT Licensed.
                             * See https://github.com/MichMich/MagicMirror#configuration/*
                             * MIT Licensed.
                            var config = {
                            	port: 8080,
                            	language: "en",
                            	timeFormat: 24,
                            	units: "metric",
                            			module: "alert",
                            			module: "updatenotification",
                            			position: "top_bar"
                            			module: "clock",
                            			position: "top_left"
                            			header: "GB Holidays",
                            						symbol: "calendar-check",
                            						url: "webcal://www.calendar/embed?src=en.uk%23holiday%40group.v.calendar.google.com"					}
                            			module: "compliments",
                            			position: "lower_third"
                            			module: "currentweather",
                            			config:  {
                            				locationID: "53.9576",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                            				appid: "76b503a29647f3a01dd9ba1055daea6d",
                            			module: "weatherforecast",
                            			header: "Weather Forecast",
                            			module: "newsfeed",
                            			position: "bottom_bar",
                            				feeds: [
                            						title:  "BBC",
                            						url: "http://WWW.BBC.com/services/xml/rss/bbc/HomePage.xml",
                            				showSourceTitle: true,
                            				showPublishDate: true,
                            				broadcastNewsFeeds: false,
                            				broadcastNewsUpdates: true,
                              sdetweil @geo
                              @geo ok… does it work?
                              • G Offline
                                geo @sdetweil
                                @sdetweil no
                                • G Offline
                                  geo
                                  hi i thought i had managed to copy the config you sent but obviosly not as mirror still will not open ,cheers
                                  • L Offline
                                    La7dan @geo
                                    I will make it works dont worry!
                                    First reinstall:
                                    1- Run this command:
                                    sudo rm -R MagicMirror
                                    (that will rmove the Magic mirror from your system.
                                    2- Run this command:
                                    bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
                                    to install the new MagicMirror again.
                                    3- make sure the config .js is there if not
                                    run this command
                                    nano MagicMirror/config/config.js
                                    then copy between lines:
                                     * MIT Licensed.
                                    var config = {
                                    	port: 8080,
                                    	language: "en",
                                    	timeFormat: 24,
                                    	units: "metric",
                                    			module: "alert",
                                    			position: "top_bar"
                                    			module: "clock",
                                    			header: "US Holidays",
                                    						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                                    				locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                    				locationID: "5128581",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                    			module: "newsfeed",
                                    				feeds: [
                                    						title: "New York Times",
                                    				broadcastNewsFeeds: true,
                                    end: dont copy the line above ( you can fin the file in config dirctory under the name of config.js.sample. Just save it as config.js without sample)
                                    4- start your Magic Mirror
                                    First: cd MagicMirror
                                    (to navigate to the Magic Mirror dirctory)
                                    second run : npm start
                                    Check if it works!
                                    I will be helping you step by step even if you wants to add some modules.
                                    Good luck!!!
                                    S Mykle1M G 3 Replies Last reply Reply Quote 0
                                      sdetweil @La7dan
                                      @La7dan please use the updated installer
                                      see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                                      it will be part of the next release
                                        Mykle1 Project Sponsor Module Developer @La7dan
                                        @La7dan
                                        Please read and use this guide regarding posting code on the forum. Peace!
                                        https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                                        • G Offline
                                          geo @La7dan
                                          @La7dan hi the mirror is up and running.the next problem is to have the weather and news modules changed to Gb
                                          • cowboysdudeC Offline
                                            Cannot express this enough… if you have a working config make a copy of it before you make changes that way you can either
                                            a. compare the working with the non-working config
                                            or
                                            b. switch back to the working config.
                                            • 2 / 3
