    config
    57 Posts 9 Posters 33.3k Views 7 Watching
    • G
      geo
      totally totally out of my depth and do not understand why my config.js is empty and why the text editor is missing.sorry
      • G
        geo @sdetweil
        @sdetweil hi i think i am back on track.you say to cut,is that the same as copy,because when i right click on your config all i see is copy.cheers
          sdetweil @geo
          @geo cut/paste is the generic term for the operations of marking the source, and transferring it to the destination
          copy is the non destructive form of cut
          • G
            geo
            @geo said in config:
            geo
            this is what i have
            /* Magic Mirror Config Sample
             * MIT Licensed.
             * MIT Licensed.
             * See https://github.com/MichMich/MagicMirror#configuration/*
             * MIT Licensed.
            var config = {
            	port: 8080,
            	language: "en",
            	timeFormat: 24,
            	units: "metric",
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_left"
            			header: "GB Holidays",
            						symbol: "calendar-check",
            						url: "webcal://www.calendar/embed?src=en.uk%23holiday%40group.v.calendar.google.com"					}
            			module: "compliments",
            			position: "lower_third"
            			module: "currentweather",
            			config:  {
            				locationID: "53.9576",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            				appid: "76b503a29647f3a01dd9ba1055daea6d",
            			module: "weatherforecast",
            			header: "Weather Forecast",
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title:  "BBC",
            						url: "http://WWW.BBC.com/services/xml/rss/bbc/HomePage.xml",
            				showSourceTitle: true,
            				showPublishDate: true,
            				broadcastNewsFeeds: false,
            				broadcastNewsUpdates: true,
              sdetweil @geo
              @geo ok… does it work?
              G 1 Reply Last reply
              • G
                geo @sdetweil
                @sdetweil no
                • G
                  geo
                  hi i thought i had managed to copy the config you sent but obviosly not as mirror still will not open ,cheers
                  • L
                    La7dan @geo
                    I will make it works dont worry!
                    First reinstall:
                    1- Run this command:
                    sudo rm -R MagicMirror
                    (that will rmove the Magic mirror from your system.
                    2- Run this command:
                    bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
                    to install the new MagicMirror again.
                    3- make sure the config .js is there if not
                    run this command
                    nano MagicMirror/config/config.js
                    then copy between lines:
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	language: "en",
                    	timeFormat: 24,
                    	units: "metric",
                    			module: "alert",
                    			position: "top_bar"
                    			module: "clock",
                    			header: "US Holidays",
                    						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                    				locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                    				locationID: "5128581",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                    			module: "newsfeed",
                    				feeds: [
                    						title: "New York Times",
                    				broadcastNewsFeeds: true,
                    end: dont copy the line above ( you can fin the file in config dirctory under the name of config.js.sample. Just save it as config.js without sample)
                    4- start your Magic Mirror
                    First: cd MagicMirror
                    (to navigate to the Magic Mirror dirctory)
                    second run : npm start
                    Check if it works!
                    I will be helping you step by step even if you wants to add some modules.
                    Good luck!!!
                    S Mykle1M G 3 Replies Last reply
                      sdetweil @La7dan
                      @La7dan please use the updated installer
                      see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                      it will be part of the next release
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @La7dan
                        @La7dan
                        Please read and use this guide regarding posting code on the forum. Peace!
                        https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                        L 1 Reply Last reply
                        • G
                          geo @La7dan
                          @La7dan hi the mirror is up and running.the next problem is to have the weather and news modules changed to Gb
                          • cowboysdudeC
                            Cannot express this enough… if you have a working config make a copy of it before you make changes that way you can either
                            a. compare the working with the non-working config
                            or
                            b. switch back to the working config.
                            G 2 Replies Last reply
                            • L
                              La7dan @geo
                              @geo give me the name of the module and the location I will help you to make it works! thank you
                              • L
                                La7dan @Mykle1
                                @Mykle1 Thank you thats help a lot.
                                • G
                                  geo @cowboysdude
                                  @cowboysdude hi thx for that when you say make a copy where is it saved to.cheers
                                  • G
                                    geo @La7dan
                                    @La7dan hi again firstly the mm no longer opens on boot.
                                    i have the calander but with us hols.i would like uk weather and news.cheers
                                    • L
                                      La7dan @geo
                                      @geo did you install pm2 ? and follow the instructions ?
                                      https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                                      show me your config so I could fix it. im online for an hour we could get it done
                                        sdetweil @La7dan
                                        @La7dan if you use one of the installer scripts… listed on the MM github page, or mine listed here in the forums (see here https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                                        it will setup pm2, and turn off the screensaver…as part of the mm install…
                                          sdetweil @geo
                                          @geo where? its up to you…
                                          copy it to the same folder as config.js.saved
                                          or to another folder
                                          or to a server disk,
                                          or to a drop box , or google drive
                                          depends on how ‘safe’ you want to be…
                                          its just a copy command
                                          cp config.js config.js.save
                                          • G
                                            geo @cowboysdude
                                            @cowboysdude can it be copied to the config sample
                                            • 2 / 3
