    config
    57 Posts 9 Posters 32.4k Views 7 Watching
      sdetweil @La7dan
      @La7dan please use the updated installer
      see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
      it will be part of the next release
        Mykle1 Project Sponsor Module Developer @La7dan
        @La7dan
        Please read and use this guide regarding posting code on the forum. Peace!
        https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
        • G Offline
          geo @La7dan
          @La7dan hi the mirror is up and running.the next problem is to have the weather and news modules changed to Gb
          • cowboysdudeC Offline
            Cannot express this enough… if you have a working config make a copy of it before you make changes that way you can either
            a. compare the working with the non-working config
            or
            b. switch back to the working config.
            G 2 Replies Last reply Reply Quote 0
            • L Offline
              La7dan @geo
              @geo give me the name of the module and the location I will help you to make it works! thank you
              • L Offline
                La7dan @Mykle1
                @Mykle1 Thank you thats help a lot.
                • G Offline
                  geo @cowboysdude
                  @cowboysdude hi thx for that when you say make a copy where is it saved to.cheers
                  • G Offline
                    geo @La7dan
                    @La7dan hi again firstly the mm no longer opens on boot.
                    i have the calander but with us hols.i would like uk weather and news.cheers
                    • L Offline
                      La7dan @geo
                      @geo did you install pm2 ? and follow the instructions ?
                      https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                      show me your config so I could fix it. im online for an hour we could get it done
                        sdetweil @La7dan
                        @La7dan if you use one of the installer scripts… listed on the MM github page, or mine listed here in the forums (see here https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                        it will setup pm2, and turn off the screensaver…as part of the mm install…
                          sdetweil @geo
                          @geo where? its up to you…
                          copy it to the same folder as config.js.saved
                          or to another folder
                          or to a server disk,
                          or to a drop box , or google drive
                          depends on how ‘safe’ you want to be…
                          its just a copy command
                          cp config.js config.js.save
                          • G Offline
                            geo @cowboysdude
                            @cowboysdude can it be copied to the config sample
                              sdetweil @geo
                              @geo you do not want to copy over the sample…
                              • G Offline
                                geo @La7dan
                                @La7dan hi,mm not opening now on boot.
                                i have the cal and clock on uk time with us hols,would like the news to be uk,i dont have the weather.
                                thx
                                S L 2 Replies Last reply Reply Quote 0
                                • L Offline
                                  La7dan
                                  try
                                  pm2 start 0
                                  is the magicmirror working ?
                                  S G 2 Replies Last reply Reply Quote 0
                                    sdetweil @geo
                                    @geo has it always not been opening on boot?
                                    use this script to fix that
                                    see here
                                    https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
                                    if the mm won’t start at all, that is a different problem
                                    new on uk… which news source do you want? open their page, and scroll down to the bottom… thy usually list rss feeds
                                      sdetweil @La7dan
                                      @La7dan just use pm2
                                      • L Offline
                                        La7dan @sdetweil
                                        @sdetweil true service could be confusing
                                        • L Offline
                                          La7dan @geo
                                          @geo http://rss.cnn.com/services/podcasting/cnn10/rss.xml
                                          this is an example for CNN news/.
                                            sdetweil @La7dan
                                            @La7dan use the search feature on your favorite news site… here from the bbc, to find an rss feed to put into the news config
                                            https://www.bbc.co.uk/search?q=rss
                                            G 1 Reply Last reply Reply Quote 1
                                            • 2 / 3
