    config
    57 Posts 9 Posters 33.3k Views 7 Watching
    • G
      geo @sdetweil
      @sdetweil hi after another attempt i find the config is empty all that is available is the sample
      S G 2 Replies Last reply
        sdetweil @geo
        @geo i posted the corrected config.js above, cut/paste it back into the ~/MagicMiror/config/config.js file
        • G
          geo @geo
          @geo would it be better to delete and re install
            sdetweil @geo
            @geo no… just missing the config file…
            select the text in my post above, right click mouse, select copy,
            then open an editor on the file and right click mouse paste
            i use ssh and BitVise ssh client so I can access and edit files thru my windows machine
            G 1 Reply Last reply
            • G
              geo @sdetweil
              @sdetweil hi sorry but i am stuck config.js is empty and cant find text editor
                sdetweil @geo
                @geo nano is a text editor
                you can also do
                cp config.js.sample config.js
                to copy the initial
                • G
                  geo
                  totally totally out of my depth and do not understand why my config.js is empty and why the text editor is missing.sorry
                  • G
                    geo @sdetweil
                    @sdetweil hi i think i am back on track.you say to cut,is that the same as copy,because when i right click on your config all i see is copy.cheers
                      sdetweil @geo
                      @geo cut/paste is the generic term for the operations of marking the source, and transferring it to the destination
                      copy is the non destructive form of cut
                      • G
                        geo
                        @geo said in config:
                        geo
                        this is what i have
                        /* Magic Mirror Config Sample
                         * MIT Licensed.
                         * MIT Licensed.
                         * See https://github.com/MichMich/MagicMirror#configuration/*
                         * MIT Licensed.
                        var config = {
                        	port: 8080,
                        	language: "en",
                        	timeFormat: 24,
                        	units: "metric",
                        			module: "alert",
                        			module: "updatenotification",
                        			position: "top_bar"
                        			module: "clock",
                        			position: "top_left"
                        			header: "GB Holidays",
                        						symbol: "calendar-check",
                        						url: "webcal://www.calendar/embed?src=en.uk%23holiday%40group.v.calendar.google.com"					}
                        			module: "compliments",
                        			position: "lower_third"
                        			module: "currentweather",
                        			config:  {
                        				locationID: "53.9576",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                        				appid: "76b503a29647f3a01dd9ba1055daea6d",
                        			module: "weatherforecast",
                        			header: "Weather Forecast",
                        			module: "newsfeed",
                        			position: "bottom_bar",
                        				feeds: [
                        						title:  "BBC",
                        						url: "http://WWW.BBC.com/services/xml/rss/bbc/HomePage.xml",
                        				showSourceTitle: true,
                        				showPublishDate: true,
                        				broadcastNewsFeeds: false,
                        				broadcastNewsUpdates: true,
                          sdetweil @geo
                          @geo ok… does it work?
                          • G
                            geo @sdetweil
                            @sdetweil no
                            • G
                              geo
                              hi i thought i had managed to copy the config you sent but obviosly not as mirror still will not open ,cheers
                              • L
                                La7dan @geo
                                I will make it works dont worry!
                                First reinstall:
                                1- Run this command:
                                sudo rm -R MagicMirror
                                (that will rmove the Magic mirror from your system.
                                2- Run this command:
                                bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
                                to install the new MagicMirror again.
                                3- make sure the config .js is there if not
                                run this command
                                nano MagicMirror/config/config.js
                                then copy between lines:
                                 * MIT Licensed.
                                var config = {
                                	port: 8080,
                                	language: "en",
                                	timeFormat: 24,
                                	units: "metric",
                                			module: "alert",
                                			position: "top_bar"
                                			module: "clock",
                                			header: "US Holidays",
                                						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                                				locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                				locationID: "5128581",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                			module: "newsfeed",
                                				feeds: [
                                						title: "New York Times",
                                				broadcastNewsFeeds: true,
                                end: dont copy the line above ( you can fin the file in config dirctory under the name of config.js.sample. Just save it as config.js without sample)
                                4- start your Magic Mirror
                                First: cd MagicMirror
                                (to navigate to the Magic Mirror dirctory)
                                second run : npm start
                                Check if it works!
                                I will be helping you step by step even if you wants to add some modules.
                                Good luck!!!
                                S Mykle1M G 3 Replies Last reply
                                  sdetweil @La7dan
                                  @La7dan please use the updated installer
                                  see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                                  it will be part of the next release
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @La7dan
                                    @La7dan
                                    Please read and use this guide regarding posting code on the forum. Peace!
                                    https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                                    L 1 Reply Last reply
                                    • G
                                      geo @La7dan
                                      @La7dan hi the mirror is up and running.the next problem is to have the weather and news modules changed to Gb
                                      • cowboysdudeC
                                        Cannot express this enough… if you have a working config make a copy of it before you make changes that way you can either
                                        a. compare the working with the non-working config
                                        or
                                        b. switch back to the working config.
                                        • L
                                          La7dan @geo
                                          @geo give me the name of the module and the location I will help you to make it works! thank you
                                          • L
                                            La7dan @Mykle1
                                            @Mykle1 Thank you thats help a lot.
                                            • 2 / 3
