    config
    57 Posts 9 Posters 31.5k Views 7 Watching
    • cowboysdudeC Offline
      Cannot express this enough… if you have a working config make a copy of it before you make changes that way you can either
      a. compare the working with the non-working config
      or
      b. switch back to the working config.
      G 2 Replies Last reply Reply Quote 0
      • L Offline
        La7dan @geo
        @geo give me the name of the module and the location I will help you to make it works! thank you
        • L Offline
          La7dan @Mykle1
          @Mykle1 Thank you thats help a lot.
          • G Offline
            geo @cowboysdude
            @cowboysdude hi thx for that when you say make a copy where is it saved to.cheers
            • G Offline
              geo @La7dan
              @La7dan hi again firstly the mm no longer opens on boot.
              i have the calander but with us hols.i would like uk weather and news.cheers
              • L Offline
                La7dan @geo
                @geo did you install pm2 ? and follow the instructions ?
                https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                show me your config so I could fix it. im online for an hour we could get it done
                  sdetweil @La7dan
                  @La7dan if you use one of the installer scripts… listed on the MM github page, or mine listed here in the forums (see here https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                  it will setup pm2, and turn off the screensaver…as part of the mm install…
                    sdetweil @geo
                    @geo where? its up to you…
                    copy it to the same folder as config.js.saved
                    or to another folder
                    or to a server disk,
                    or to a drop box , or google drive
                    depends on how ‘safe’ you want to be…
                    its just a copy command
                    cp config.js config.js.save
                    • G Offline
                      geo @cowboysdude
                      @cowboysdude can it be copied to the config sample
                        sdetweil @geo
                        @geo you do not want to copy over the sample…
                        • G Offline
                          geo @La7dan
                          @La7dan hi,mm not opening now on boot.
                          i have the cal and clock on uk time with us hols,would like the news to be uk,i dont have the weather.
                          thx
                          S L 2 Replies Last reply Reply Quote 0
                          • L Offline
                            La7dan
                            try
                            pm2 start 0
                            is the magicmirror working ?
                            S G 2 Replies Last reply Reply Quote 0
                              sdetweil @geo
                              @geo has it always not been opening on boot?
                              use this script to fix that
                              see here
                              https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
                              if the mm won’t start at all, that is a different problem
                              new on uk… which news source do you want? open their page, and scroll down to the bottom… thy usually list rss feeds
                                sdetweil @La7dan
                                @La7dan just use pm2
                                • L Offline
                                  La7dan @sdetweil
                                  @sdetweil true service could be confusing
                                  • L Offline
                                    La7dan @geo
                                    @geo http://rss.cnn.com/services/podcasting/cnn10/rss.xml
                                    this is an example for CNN news/.
                                      sdetweil @La7dan
                                      @La7dan use the search feature on your favorite news site… here from the bbc, to find an rss feed to put into the news config
                                      https://www.bbc.co.uk/search?q=rss
                                      G 1 Reply Last reply Reply Quote 1
                                      • G Offline
                                        geo @La7dan
                                        @La7dan hi sorry for the delay the mm is up and running
                                        • G Offline
                                          geo @sdetweil
                                          @sdetweil hi can you tell me how and where i can backup the config to in case i make more mistakes cheers
                                            sdetweil @geo
                                            @geo open a terminal window
                                            Then do
                                            cd ~/MagicMirror/config
                                            That saves your current config.js to another file
                                            • 2 / 3
