    Problems with calender and Nextcloud
    44 Posts 6 Posters 24.2k Views 6 Watching
      Pakmann
      hmm… each other devices are running:
      Phone, Tablet or try to download the ICS directly in a desktop browser. Should be sometink on the PI ?
        sdetweil @Pakmann
        @Pakmann where did u configure tls3? may have to do the same on pi
          Pakmann
          nextcloud is hostet on a separate pi. here the nginx is configured for TLS1.3
          MM is on another PI.
            sdetweil @Pakmann
            @Pakmann so the nginx system is the gateway… all things must speak tls3…
            so you now need to config MM pi to peak tls3
              Pakmann @sdetweil
              Today i solved the problem regarding TLS1.3 connection. Wget is working fine and i can download the ICS data.
              On MM side i have the same issue like before. No data is shown in calender. When i start the MM its still the same error message :-(
                sdetweil @Pakmann
                @Pakmann looks like you will have to add a parameter to the launcher to enable tls 1.3
                https://developer.ibm.com/blogs/migrating-to-tls13-in-nodejs/
                my adding this to the script starting MM (either mm.sh or run-start.sh)
                Enable TLS1.3 using CLI options
                With Node.js 11.x or 10.x, you can use the --tls-max-v1.3 CLI option to enable TLS1.3 by default. It can be provided directly on the command line, or set in the environment with NODE_OPTIONS=–tls-max-v1.3. The option can also be specified to Node.js 12.x, even though its already the default.
                export NODE_OPTIONS=--tls-max-v1.3
                  Pakmann @sdetweil
                  for a first try i set the option directly via termine and start MM. Same result like before - i got an error message for SSL.
                  pi@MagicMirror:~/MagicMirror $ NODE_OPTIONS=–tls-max-v1.3
                  pi@MagicMirror:~/MagicMirror $ npm start
                  Anythink wrong here ? Any idea how i can check if the option was accepted correctly?
                  On buster stable nodejs 10.17.0 is availble. But i found the binaries for v12. Obviously after an update i have other problems :D Therefore its better with v10 so far
                    sdetweil @Pakmann
                    @Pakmann said in Problems with calender and Nextcloud:
                    you must export the env variable, else it is not passed to children processes,
                    issue this command from the terminal window
                      Pakmann
                      it could so easy… :-(
                      pi@MagicMirror:~/MagicMirror $ export NODE_OPTIONS=--tls-max-v1.3
                      node: --tls-max-v1.3 is not allowed in NODE_OPTIONS
                        sdetweil @Pakmann
                        @Pakmann looks like that only works with node 10.16 and above… love when they leave out that little detail!..
                        https://stackoverflow.com/questions/57839965/how-to-use-tlsv1-3-with-nodejs-10-x
                        you don’t know if what you read is real or needs 4 hours more of investigation…
                        • 3 / 5
