    Problems with calender and Nextcloud
    44 Posts 6 Posters 28.8k Views 6 Watching
      sdetweil @Pakmann
      @Pakmann
      but I said
      wget -o  your nextcloud_url
      whatever the https://… nextcloud thing is in config.js
        Pakmann
        yes, i try the complete URL for download die ICS file from nextcloud kalender. Include credentials inside the link:
         wget -O https://USER:PASSWORD@DOMAIN/remote.php/dav/calendars/USER/personal/?export
        wget: URL fehlt
        Aufruf: wget [OPTION]... [URL] …
          sdetweil @Pakmann
          @Pakmann just remove the -o parm
            Pakmann
            of course :-) i uses O (not zero)
              sdetweil @Pakmann
              @Pakmann just do wget nextcloud-url
                Pakmann
                looks like the direction to find the root cause is good.
                Get following response:
                GnuTLS: A TLS fatal alert has been received.
                GnuTLS: received alert [70]: Error in protocol version
                Now i remember, a few months ago i configure the nginx to TLS1.3. Maybe its not compatible with MM ?
                  sdetweil @Pakmann
                  @Pakmann wget is not MM, and it also fails
                    Pakmann
                    hmm… each other devices are running:
                    Phone, Tablet or try to download the ICS directly in a desktop browser. Should be sometink on the PI ?
                      sdetweil @Pakmann
                      @Pakmann where did u configure tls3? may have to do the same on pi
                        Pakmann
                        nextcloud is hostet on a separate pi. here the nginx is configured for TLS1.3
                        MM is on another PI.
                          sdetweil @Pakmann
                          @Pakmann so the nginx system is the gateway… all things must speak tls3…
                          so you now need to config MM pi to peak tls3
                            Pakmann @sdetweil
                            Today i solved the problem regarding TLS1.3 connection. Wget is working fine and i can download the ICS data.
                            On MM side i have the same issue like before. No data is shown in calender. When i start the MM its still the same error message :-(
                              sdetweil @Pakmann
                              @Pakmann looks like you will have to add a parameter to the launcher to enable tls 1.3
                              https://developer.ibm.com/blogs/migrating-to-tls13-in-nodejs/
                              my adding this to the script starting MM (either mm.sh or run-start.sh)
                              Enable TLS1.3 using CLI options
                              With Node.js 11.x or 10.x, you can use the --tls-max-v1.3 CLI option to enable TLS1.3 by default. It can be provided directly on the command line, or set in the environment with NODE_OPTIONS=–tls-max-v1.3. The option can also be specified to Node.js 12.x, even though its already the default.
                              export NODE_OPTIONS=--tls-max-v1.3
                                Pakmann @sdetweil
                                for a first try i set the option directly via termine and start MM. Same result like before - i got an error message for SSL.
                                pi@MagicMirror:~/MagicMirror $ NODE_OPTIONS=–tls-max-v1.3
                                pi@MagicMirror:~/MagicMirror $ npm start
                                Anythink wrong here ? Any idea how i can check if the option was accepted correctly?
                                On buster stable nodejs 10.17.0 is availble. But i found the binaries for v12. Obviously after an update i have other problems :D Therefore its better with v10 so far
                                  sdetweil @Pakmann
                                  @Pakmann said in Problems with calender and Nextcloud:
                                  you must export the env variable, else it is not passed to children processes,
                                  issue this command from the terminal window
                                    Pakmann
                                    it could so easy… :-(
                                    pi@MagicMirror:~/MagicMirror $ export NODE_OPTIONS=--tls-max-v1.3
                                    node: --tls-max-v1.3 is not allowed in NODE_OPTIONS
                                      sdetweil @Pakmann
                                      @Pakmann looks like that only works with node 10.16 and above… love when they leave out that little detail!..
                                      https://stackoverflow.com/questions/57839965/how-to-use-tlsv1-3-with-nodejs-10-x
                                      you don’t know if what you read is real or needs 4 hours more of investigation…
                                        Pakmann @sdetweil
                                        @sdetweil i know what you mean. this is what i really hate on linux side. A lot of dependencies… you have to update on package? Welcome on highway to hell.
                                        Netherleless, on buster stable Node 10.17.0 is installed. This is the version what i used. Obviously wont work.
                                        Found this: https://github.com/nodejs/node/issues/27666
                                        When i understood it right the feature is not implemented on 10.x ? The ticket for the implementation is still open
                                        It could be a solution to update Nodejs to v11 or v12. Any estimation if MM is compatible so far? Or other ideas?
                                          sdetweil @Pakmann
                                          @Pakmann the installers (my new one and the current) are both forcing node V10.
                                          we haven’t tried 11/12 as far as I know… wanna test!?
                                          download my script,
                                          curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=1
                                          edit the NODE_TESTED=“v10.1.0” at the top to V11.1.0 or V12.1.0
                                          and give it a try… of course this is a re-install, so rename the current MM folder out of the way
                                            Pakmann @sdetweil
                                            short overview what i did…
                                            cp -r /home/pi/MagicMirror/ /home/pi/MagicMirrorOLD/
                                            suro rm -r /home/pi/MagicMirror/
                                            Download script and change NODE_TESTED = “v12.1.0”
                                            Update to NodeJS V12:
                                             curl -sL https://deb.nodesource.com/setup_12.x | sudo bash -
                                             sudo apt-get install -y nodejs
                                            Install new MM
                                             bash raspberry.sh
                                            Copy old config
                                            cp /home/pi/MagicMirrorOLD/config/config.js /home/pi/MagicMirror/config/
                                            I delete all modules, only standard configuration with weather etc. Calender of course.
                                            Set TLS1.3 and start MM:
                                            npm start
                                            Result: In your link from IBM is written in NodeJS 12 TLS1.3 is configured by default. It doesnt matter if i set the export expression or not. I still get an error message regarding TLS. Same like before.
                                            I could not finde somethink how i can check if TLS1.3 is really configured in NodeJS.
                                            • 2 / 3
