    Problems with calender and Nextcloud
    44 Posts 6 Posters 28.8k Views 6 Watching
      sdetweil @Pakmann
      @Pakmann just do wget nextcloud-url
        Pakmann
        looks like the direction to find the root cause is good.
        Get following response:
        GnuTLS: A TLS fatal alert has been received.
        GnuTLS: received alert [70]: Error in protocol version
        Now i remember, a few months ago i configure the nginx to TLS1.3. Maybe its not compatible with MM ?
          sdetweil @Pakmann
          @Pakmann wget is not MM, and it also fails
            Pakmann
            hmm… each other devices are running:
            Phone, Tablet or try to download the ICS directly in a desktop browser. Should be sometink on the PI ?
              sdetweil @Pakmann
              @Pakmann where did u configure tls3? may have to do the same on pi
                Pakmann
                nextcloud is hostet on a separate pi. here the nginx is configured for TLS1.3
                MM is on another PI.
                  sdetweil @Pakmann
                  @Pakmann so the nginx system is the gateway… all things must speak tls3…
                  so you now need to config MM pi to peak tls3
                    Pakmann @sdetweil
                    Today i solved the problem regarding TLS1.3 connection. Wget is working fine and i can download the ICS data.
                    On MM side i have the same issue like before. No data is shown in calender. When i start the MM its still the same error message :-(
                      sdetweil @Pakmann
                      @Pakmann looks like you will have to add a parameter to the launcher to enable tls 1.3
                      https://developer.ibm.com/blogs/migrating-to-tls13-in-nodejs/
                      my adding this to the script starting MM (either mm.sh or run-start.sh)
                      Enable TLS1.3 using CLI options
                      With Node.js 11.x or 10.x, you can use the --tls-max-v1.3 CLI option to enable TLS1.3 by default. It can be provided directly on the command line, or set in the environment with NODE_OPTIONS=–tls-max-v1.3. The option can also be specified to Node.js 12.x, even though its already the default.
                      export NODE_OPTIONS=--tls-max-v1.3
                        Pakmann @sdetweil
                        for a first try i set the option directly via termine and start MM. Same result like before - i got an error message for SSL.
                        pi@MagicMirror:~/MagicMirror $ NODE_OPTIONS=–tls-max-v1.3
                        pi@MagicMirror:~/MagicMirror $ npm start
                        Anythink wrong here ? Any idea how i can check if the option was accepted correctly?
                        On buster stable nodejs 10.17.0 is availble. But i found the binaries for v12. Obviously after an update i have other problems :D Therefore its better with v10 so far
                          sdetweil @Pakmann
                          @Pakmann said in Problems with calender and Nextcloud:
                          you must export the env variable, else it is not passed to children processes,
                          issue this command from the terminal window
                            Pakmann
                            it could so easy… :-(
                            pi@MagicMirror:~/MagicMirror $ export NODE_OPTIONS=--tls-max-v1.3
                            node: --tls-max-v1.3 is not allowed in NODE_OPTIONS
                              sdetweil @Pakmann
                              @Pakmann looks like that only works with node 10.16 and above… love when they leave out that little detail!..
                              https://stackoverflow.com/questions/57839965/how-to-use-tlsv1-3-with-nodejs-10-x
                              you don’t know if what you read is real or needs 4 hours more of investigation…
                                Pakmann @sdetweil
                                @sdetweil i know what you mean. this is what i really hate on linux side. A lot of dependencies… you have to update on package? Welcome on highway to hell.
                                Netherleless, on buster stable Node 10.17.0 is installed. This is the version what i used. Obviously wont work.
                                Found this: https://github.com/nodejs/node/issues/27666
                                When i understood it right the feature is not implemented on 10.x ? The ticket for the implementation is still open
                                It could be a solution to update Nodejs to v11 or v12. Any estimation if MM is compatible so far? Or other ideas?
                                  sdetweil @Pakmann
                                  @Pakmann the installers (my new one and the current) are both forcing node V10.
                                  we haven’t tried 11/12 as far as I know… wanna test!?
                                  download my script,
                                  curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=1
                                  edit the NODE_TESTED=“v10.1.0” at the top to V11.1.0 or V12.1.0
                                  and give it a try… of course this is a re-install, so rename the current MM folder out of the way
                                    Pakmann @sdetweil
                                    short overview what i did…
                                    cp -r /home/pi/MagicMirror/ /home/pi/MagicMirrorOLD/
                                    suro rm -r /home/pi/MagicMirror/
                                    Download script and change NODE_TESTED = “v12.1.0”
                                    Update to NodeJS V12:
                                     curl -sL https://deb.nodesource.com/setup_12.x | sudo bash -
                                     sudo apt-get install -y nodejs
                                    Install new MM
                                     bash raspberry.sh
                                    Copy old config
                                    cp /home/pi/MagicMirrorOLD/config/config.js /home/pi/MagicMirror/config/
                                    I delete all modules, only standard configuration with weather etc. Calender of course.
                                    Set TLS1.3 and start MM:
                                    npm start
                                    Result: In your link from IBM is written in NodeJS 12 TLS1.3 is configured by default. It doesnt matter if i set the export expression or not. I still get an error message regarding TLS. Same like before.
                                    I could not finde somethink how i can check if TLS1.3 is really configured in NodeJS.
                                      sdetweil @Pakmann
                                      @Pakmann booooo
                                        Pakmann
                                        today i reconfigured the cloud system to TLS1.2 to make a check. Its working.
                                        I check the access log also and found the request:
                                        "GET /remote.php/dav/calendars/USER/personal/?export HTTP/1.1" 200 79020 "-" "Mozilla/5.0 (Node.js 10.2) MagicMirror/2.9.0 (https://github.com/MichMich/MagicMirror/)"
                                        Very curious here is the information about the request with Nodejs 10.2. On the system 10.2 should not be available. When i check the version, v12 is visible.
                                        Do you have any dependencies in MM Code to the old NodeJS ?
                                        Its just a stro, but maybe here is the root cause ?
                                          sdetweil @Pakmann
                                          @Pakmann I got no clue… we are using the latest request module (2.88.0)
                                          it does say special parms required for SSL 3 (and there is currently no way to pass something like this into be used)
                                          https://www.npmjs.com/package/request#tlsssl-protocol
                                          I do see in the calendar code, setup for the request id info
                                          	"User-Agent": "Mozilla/5.0 (Node.js "+ nodeVersion + ")
                                            Corin Corvus
                                            Hey,
                                            3 month later and no solution?
                                            i tried with newest version. wget nextcloud_calender_url get the calender in special format. The Name is “7863TJr9N2JJRgfG?export” and not *.ics.
                                            i tried official documentation. Add i “auth” with copy and paste, i get a config error.
                                            in the newest build of Nextcloud i can copy a abo-link. i can download the “.ics” with this link without credentials.
                                            how i can use it for mm calender? its a puplic calender link now but i dont get any calender infos.
                                            my config:
                                            	header: "Kalender", // see help for more information
                                            		colored: true,
                                            		coloredSymbolOnly: false,
                                            				url: 'https://domain.tld/nextcloud/remote.php/dav/public-calendars/7812hello1232JJRgfG?export',
                                            				symbol: 'calendar'
                                            • 2 / 3
