Unsolved Problems with calender and Nextcloud
@Pakmann said in Problems with calender and Nextcloud:
pi@MagicMirror:~/MagicMirror $ NODE_OPTIONS=–tls-max-v1.3
you must export the env variable, else it is not passed to children processes,
issue this command from the terminal windowexport NODE_OPTIONS=--tls-max-v1.3
it could so easy… :-(
pi@MagicMirror:~/MagicMirror $ export NODE_OPTIONS=--tls-max-v1.3 pi@MagicMirror:~/MagicMirror $ npm start node: --tls-max-v1.3 is not allowed in NODE_OPTIONS
@Pakmann looks like that only works with node 10.16 and above… love when they leave out that little detail!..
https://stackoverflow.com/questions/57839965/how-to-use-tlsv1-3-with-nodejs-10-xyou don’t know if what you read is real or needs 4 hours more of investigation…
@sdetweil i know what you mean. this is what i really hate on linux side. A lot of dependencies… you have to update on package? Welcome on highway to hell.
Netherleless, on buster stable Node 10.17.0 is installed. This is the version what i used. Obviously wont work.
Found this: https://github.com/nodejs/node/issues/27666
When i understood it right the feature is not implemented on 10.x ? The ticket for the implementation is still openIt could be a solution to update Nodejs to v11 or v12. Any estimation if MM is compatible so far? Or other ideas?
@Pakmann the installers (my new one and the current) are both forcing node V10.
we haven’t tried 11/12 as far as I know… wanna test!?
download my script,
curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=1
edit the NODE_TESTED=“v10.1.0” at the top to V11.1.0 or V12.1.0
and give it a try… of course this is a re-install, so rename the current MM folder out of the way -
short overview what i did…cp -r /home/pi/MagicMirror/ /home/pi/MagicMirrorOLD/ suro rm -r /home/pi/MagicMirror/
Download script and change NODE_TESTED = “v12.1.0”
Update to NodeJS V12:
curl -sL https://deb.nodesource.com/setup_12.x | sudo bash - sudo apt-get install -y nodejs
Install new MM
bash raspberry.sh
Copy old config
cp /home/pi/MagicMirrorOLD/config/config.js /home/pi/MagicMirror/config/
I delete all modules, only standard configuration with weather etc. Calender of course.
Set TLS1.3 and start MM:export NODE_OPTIONS=--tls-max-v1.3 npm start
Result: In your link from IBM is written in NodeJS 12 TLS1.3 is configured by default. It doesnt matter if i set the export expression or not. I still get an error message regarding TLS. Same like before.
I could not finde somethink how i can check if TLS1.3 is really configured in NodeJS.
@Pakmann booooo
today i reconfigured the cloud system to TLS1.2 to make a check. Its working.
I check the access log also and found the request:"GET /remote.php/dav/calendars/USER/personal/?export HTTP/1.1" 200 79020 "-" "Mozilla/5.0 (Node.js 10.2) MagicMirror/2.9.0 (https://github.com/MichMich/MagicMirror/)"
Very curious here is the information about the request with Nodejs 10.2. On the system 10.2 should not be available. When i check the version, v12 is visible.
Do you have any dependencies in MM Code to the old NodeJS ?
Its just a stro, but maybe here is the root cause ?
@Pakmann I got no clue… we are using the latest request module (2.88.0)
it does say special parms required for SSL 3 (and there is currently no way to pass something like this into be used)
https://www.npmjs.com/package/request#tlsssl-protocol
I do see in the calendar code, setup for the request id info
"User-Agent": "Mozilla/5.0 (Node.js "+ nodeVersion + ")
Hey,
3 month later and no solution?
i tried with newest version. wget nextcloud_calender_url get the calender in special format. The Name is “7863TJr9N2JJRgfG?export” and not *.ics.i tried official documentation. Add i “auth” with copy and paste, i get a config error.
in the newest build of Nextcloud i can copy a abo-link. i can download the “.ics” with this link without credentials.
how i can use it for mm calender? its a puplic calender link now but i dont get any calender infos.
my config:
{ module: "calendar", header: "Kalender", // see help for more information position: "top_left", config: { colored: true, coloredSymbolOnly: false, calendars: [ { url: 'https://domain.tld/nextcloud/remote.php/dav/public-calendars/7812hello1232JJRgfG?export', symbol: 'calendar' }, ], } },
