    Config File Help (Camera, Voice Control, Spotify)
    4 Posts 2 Posters 1.3k Views 2 Watching
      ricardoyen
      Hi All,
      Complete Newbie here, I have managed to install the following modules.
      Raspotify
      MMM-Spotify
      MMM-Remote-Control
      MMM-AlarmClock
      MMM-Hotword
      MMM-AssistantMk2
      and everything works, then I installed
      Camera, Voicecontrol, (created & retrieved the sound files, ShowCamera, HideCamera and Selfie) but I’m stuck now on the config file…
      and I’m not sure how to get the triggers to work !! ( Voice commands to work)
      I would like to do the following.
      1. Using MMM_AssistantMk2, control spotify
      2. Use the camera and voicecontrol
      Below is my Config.file, with location and ID omitted. Please help !!
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	address: "0.0.0.0", // Address to listen on, can be:
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      		  module: "MMM-Spotify",
      		  position: "bottom_left",
      		    style: "mini", // "default" or "mini" available
      		    control: "default", //"default", "hidden" available
      		    updateInterval: 1000,
      		    onStart: null, // disable onStart feature with `null`
      		    allowDevices: [], //If you want to limit devices to display info, use this.
      		    // allowDevices: ["RASPOTIFY", "My iPhoneX", "My Home speaker"],
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "SA Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.officeholidays.com/ics/ics_country.php?tbl_country=South%20Africa"					}
      		    module: 'camera',
      		    position: 'top_center',
      			selfieInterval: 3,  // Time interval in seconds before the photo will be taken.
      				emailConfig: {
      					service: 'Hotmail', // Email provider to use to send email with a photo.
      					auth: {
      						user: '<name@email.com>', // Your email account
      						pass: '<password>'        // Your password for email account
      			module: 'voicecontrol',
      			position: 'bottom_left',
      				models: [
      						keyword: "Show Camera",
      						description: "Say 'Show Camera' to display camera",
      						file: "ShowCamera.pmdl",
      						message: "SHOW_CAMERA"
      						keyword: "Hide Camera",
      						description: "Say 'Hide Camera' to hide camera",
      						file: "HideCamera.pmdl",
      						message: "HIDE_CAMERA"
      						keyword: "Selfie",
      						description: "Say 'Selfie' when camera is visible",
      						file: "Selfie.pmdl",
      						message: "SELFIE"
      	module: 'MMM-Remote-Control',
      	disabled: false,
      		customCommand: {},
      		customMenu: 'custom_menu.json',
      		showModuleApiMenu: 'true',
      		apikey: '',
        module: "MMM-Remote-Control-Repository",
      			  module: 'MMM-AlarmClock',
      			  position: 'top_right',
      			    sound: 'blackforest.mp3',
      			    format: 'dddd, h:mm a',
      			    timer: 60000,
      			    volume: 1.0,
      			    touch: false,
      			    fade: false,
      			    alarms: [
      				time: '19:02',
      				days: [1,2,3,4,5,6,7],
      				title: 'Morning Alarm',
      				message: 'Get Up! and train like a beast!'
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "XYZ",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "XYZ"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				appid: "XYZ"
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "News ",
      						url: "XYZs"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      	module: "MMM-Hotword",
      	position: "bottom_right",
      		chimeOnFinish: null,
      		mic: {
      			recordProgram: "arecord",
      			device: "plughw:1"
      		models: [
      				hotwords    : "smart_mirror",
      				file        : "smart_mirror.umdl",
      				sensitivity : "0.5",
      		commands: {
      			"smart_mirror": {
      				notificationExec: {
      					notification: "ASSISTANT_ACTIVATE",
      					payload: (detected, afterRecord) => {
      						return {profile:"default"}
      				restart:false,
      				afterRecordLimit:0
      	module: "MMM-AssistantMk2",
      		deviceLocation: {
      			coordinates: {
      				latitude: xx.xxx, // -90.0 - +90.0
      				longitude: yy.yyyy // -180.0 - +180.0
      		record: {
      			recordProgram : "arecord",
      			device        : "plughw:1",
      		play: { // Full values are in `FOR EXPERTS` section.
      		      playProgram: "mpg321", // recommended.
      		    // --- OPTIONAL / not important but customizable for your usage
      		    responseVoice: true, // If available, Assistant will response with her voice.
      		    responseScreen: true, // If available, Assistant will response with some rendered HTML
      		    responseAlert: true, // If available, Assistant will response with Alert module of MM
      		    // Sometimes, any response might not be returned. responseAlert is useful for displaying error.
      		    screenZoom: "80%", // Adjust responseScreen to your mirror size.
      		    screenDuration: 0, // milliseconds. How long responseScreen will be shown after speech.
      		    //If you set 0, Screen Output will be closed after Response speech finishes ASAP.
      		    youtubeAutoplay: true, //If set as true, found Youtube video will be played automatically.
      		    pauseOnYoutube:true, //If set as true, You cannot activate Assistant during youtube playing. Recommended for the performance (Because permanent hotword detecting might make performance lower)
      		    youtubePlayerVars: { // You can set youtube playerVars for your purpose, but should be careful.
      		      "controls": 0,
      		      "loop": 1,
      		      "rel": 0,
      		    youtubePlayQuality: "default", //small, medium, large, hd720, hd1080, highres or default
      		notifications: {
      			ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
      			ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
      		useWelcomeMessage: "brief today",
      		profiles: {
      			"default" : {
      				lang: "en-US"
        sdetweil @ricardoyen
        @ricardoyen said in Config File Help (Camera, Voice Control, Spotify):
        MMM_AssistantMk2
        so, what you want are recipes.
        https://github.com/eouia/MMM-AssistantMk2/wiki/Usage#recipes as individual files in the module folder. this will make the config file change very small
        basically little files that take a spoken word/phrase and then take some action, execute some ‘command’ (command could be to Magic Mirror or to the system …)
        so, you could write down what you need the system to do…
        if I say this … then this is what should happen
        i don’t know anything about the 'Camera, Voicecontrol, (created & retrieved the sound files, ShowCamera, HideCamera and Selfie) ’ thing…
          ricardoyen @sdetweil
          Ok, suppose I manage to get the receipe,
          Which file in which directory do I modify to make it work…
          I was to start spotify, stop spotify, next track, pause etc.
            @ricardoyen
            u create a file in the MMM-AssistantMK2 folder for each distinct recipe. (distinct action, start spotify, stop spotify, etc,etc)
            then in config you put those in a single list
            and then connect the command to the recipe
            so for each recipe, you would determine WHAT you need to do, then get the system operations for HOW to do that (issue this command, change this file, … whatever)…
            I believe no one has done all this yet
