    Trashday modules based on ICAL
    4 Posts 2 Posters 992 Views 2 Watching
    • ScrewyoudriverS Offline
      Screwyoudriver
      I see enough trash day moduls based on excel documents etc.
      The garbage collector here uses ICAL
      Is there a module based on ICAL? Or does someone else have a good idea? or has made one?
      I could not find anything that is based on ICAL.
      Thanks!
      *Random link to garbage collector website ical *
      https://inzamelkalender.hvcgroep.nl/ical/0441200000002545
      • lavolp3L Offline
        lavolp3 Module Developer
        If you just want to show the day the trash is picked up you could as well include the ical into the calendar module…
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        ScrewyoudriverS 1 Reply Last reply Reply Quote 0
          Screwyoudriver @lavolp3
          @lavolp3 That’s right, I already have that. I only want it in a separate module. Because that’s nicer.
          • lavolp3L Offline
            lavolp3 Module Developer @Screwyoudriver
            @Screwyoudriver OK makes sense. I thought about some module like this as well.
            BTW: Another workaround would be to fetch the notification that is distributed by calendar:
            	broadcastEvents: function () {
            		var eventList = [];
            		for (var url in this.calendarData) {
            			var calendar = this.calendarData[url];
            			for (var e in calendar) {
            				var event = cloneObject(calendar[e]);
            				event.symbol = this.symbolsForUrl(url);
            				event.calendarName = this.calendarNameForUrl(url);
            				event.color = this.colorForUrl(url);
            				delete event.url;
            				eventList.push(event);
            		eventList.sort(function(a,b) {
            			return a.startDate - b.startDate;
            		this.sendNotification("CALENDAR_EVENTS", eventList);
            calendar could do the conversion work for the trash module, and the trash module could just fetch and filter the events for trash-related ones.
