MMM-MyCommute - installation error
Any idea what is going on with the installation here…?
pi@magicmirror:~/home/pi/MagicMirror/modules/MMM-MyCommute $ npm install npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates. > pre-commit@1.2.2 install /home/pi/MagicMirror/modules/MMM-MyCommute/node_modules/pre-commit > node install.js > spawn-sync@1.0.15 postinstall /home/pi/MagicMirror/modules/MMM-MyCommute/node_modules/spawn-sync > node postinstall npm WARN grunt-stylelint@0.12.0 requires a peer of stylelint@^11.0.0 but none is installed. You must install peer dependencies yourself. npm WARN stylelint-config-standard@19.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself. npm WARN stylelint-config-recommended@3.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself. added 576 packages from 394 contributors and audited 2959 packages in 154.144s -
@davidkmcw no errors… all warnings… u can ignore them…
they added checking for issues if people from outside are using your system…
@sdetweil Thanks
